Question about Goodman CKL60AR60 Air Conditioner
The motor comes on, bur the air in the house does not cool down
The motor comes on, but the air in the house does not cool
  • Robert Moller
    Robert Moller May 11, 2010
    Compressor come on ?
  • Goodman Master
  • 8,220 Answers
The number one thing that fouls on these is the capacitor if it is swolen leaky oe both then it is probably bad.
Posted on May 22, 2009
Where is the thermostat
It is located on the left side of the front of the motor. Lift the hood, look at the front left side under the air intake (big black pipe connected to the filter box in the front left behind the headlight). You should see a 90 degree angled metal housing with a black hose coming off of it. Where the metal housing connects to the front of the motor block is where the thermostat is located. To access it / replace it your will need to remove air intake host and then the bolts on the metal housing. It will be messy - coolant will leak out so have some rags and a pan under the motor or drain the radiator some before pulling it off. Also - obviously make sure the motor is completely cooled down and the battery is disconnected before working on it.
May 19, 2014 | 2003 Toyota Sequoia
What should I do in order to make sure my dog house stays cool in the summer?
In order to keep your dog's house cool during hot summer days, consider to do the following:
  • Place the dog house in the shade so it doesn't get too hot from the sun.
  • Make sure that the house is ventilated so warm air can come out.
  • If it gets really hot inside the house, you should put a fan to cool the house down or buy a small air conditioning unit made for dog houses.
  • Place a cooling mat on the ground of the house. This will help the dog to cool down during the hot summer days.
Oct 25, 2012 | Dogs
My condensor fan and compressor on my Carrier AC (Model# 38ckc036350) stopped working, so I replaced my capacitor and they both work fine now. The problem is my house won't cool down. There is c
Often after a repair has been made, the air conditioner will take hours to readjust back to normal. When the system has been off for to long, not only does the heat in the house rise, but so does the humidity, which has to be pulled out of the air first before it really starts dropping in temp. You could have a low charge on refrigerant, dirty filters, etc. More than once I have ran into things that were just coincidence after a repair that showed up. Since you just replaced the capacitor, I would make sure the fan motor is turning in the right direction and there is nice air flow coming out of the condenser, some times if one wire is wrong, it can cause it to spin backwards, which will work, but just barely. The air needs to be pulled through the coils, not pushed. Hope this helps!
Jul 06, 2012 | Carrier 38CKC036 Air Conditioner
How to install a front blower motor in a 96 ford explorer
Blower Motor - REMOVAL & INSTALLATION
(see Figures 1 and 2)
Fig. 1: Exploded view of the blower motor mounting
Fig. 2: Exploded view of the blower motor and wheel (fan) assembly
Without Air Conditioning
  1. Disconnect the negative battery cable.
  2. Remove the air cleaner or air inlet duct, as necessary.
  3. If necessary, Remove the speed control module and the washer fluid reservoir.
Fig. 3: To remove the blower motor, first disconnect the electrical wire harness plug...
Fig. 4: ...then remove the blower motor cooling tube from the motor
  1. Disconnect the wire harness connector from the blower motor by pushing down on the connector tabs and pulling the connector off of the motor.
  2. Disconnect the blower motor cooling tube at the blower motor.
Fig. 5: Remove the blower motor attaching screws and the washer fluid reservoir...
Fig. 6: ...then slide the blower motor from the housing. Take care to not damage the blower wheel (arrow)
  1. Remove the 2 screws attaching the blower motor and wheel to the heater blower assembly.
  2. Holding the cooling tube aside, pull the blower motor and wheel from the heater blower assembly and remove it from the vehicle.
  3. Remove the blower wheel push-nut and/or clamp from the motor shaft and pull the blower wheel from the motor shaft.
To install:
  1. Install the blower wheel on the blower motor shaft.
  2. Install the hub clamp and/or push-nut.
  3. Holding the cooling tube aside, position the blower motor and wheel on the heater blower assembly and install the 2 attaching screws.
  4. Connect the blower motor cooling tube and the wire harness connector.
  5. Install the vacuum reservoir on the hoses with the 1 screws.
  6. If removed, install the speed control module and the washer fluid reservoir.
  7. Install the air cleaner or air inlet duct, as necessary.
  8. Connect the negative battery cable and check the system for proper operation.
With Air Conditioning
  2. In the engine compartment, disconnect the wire harness from the motor by pushing down on the tab while pulling the connection off at the motor.
  3. Remove the air cleaner or air inlet duct, as necessary.
  4. If necessary, remove the solenoid box cover retaining bolts and the solenoid box cover.
  5. Disconnect the blower motor cooling tube from the blower motor.
  6. Remove the blower motor mounting plate attaching screws and remove the motor and wheel assembly from the evaporator assembly blower motor housing.
  7. Remove the blower motor hub clamp from the motor shaft and pull the blower wheel from the shaft.
To install:
  1. Install the blower motor wheel on the blower motor shaft and install a new hub clamp.
  2. Install a new motor mounting seal on the blower housing before installing the blower motor.
  3. Position the blower motor and wheel assembly in the blower housing and install the attaching screws.
  4. Connect the blower motor cooling tube.
  5. Connect the electrical wire harness hard shell connector to the blower motor by pushing into place.
  6. If removed, position the solenoid box cover into place and install the 2 retaining screws.
  8. Connect the negative battery cable and check the blower motor in all speeds for proper operation.
Hope this help (remember comment and rated this).
Apr 23, 2010 | 1996 Ford Explorer
Cool air, but no fan, electrical smell inside house
most like it the motor windings are burn and you need to replace the blower motor
Sep 27, 2009 | Ruud UBHC Air Conditioner
Fan motor will not come on
That thing connected to the capacitor is a booster for the compressor .But if the outside fan doesn't work , the compressor will shutt off on overload because the high pressure in the condenser coil.
First try to replace the capacitor in the condensing unit (it's the only one that works for the compressor and the fan motor) ,but if the fan doesn't start, you need to replace the fan motor.
Sep 14, 2009 | Ruud UBHC Air Conditioner
Air condtioning unit
check capicitor on motor, fan motor bearings may be locking up when they get hot then when cooled the motor comes back on. Then you must replace fan motor.
Aug 11, 2009 | Heating & Cooling
After a cooling cycle, when the thermostat call for more cooling, it take up to 5 minutes after the air handler starts for the compressor motor to restart. The top fan operates on the outside unit, but...
No, this cycle cannot be shortened due to the simple fact that this feature is in place to protect your system. Even if it could be, I wouldn't recommend it.
Mat
Jul 17, 2009 | Coleman Heating & Cooling
Fan running slow
you sound like you have it
May 27, 2009 | Dometic Rooftop RV Air Conditioner
Air conditioner
Hi!!
It not uncommon for the condenser motor to blow out, if evertything else is ok. The unit will kick in normally and you'll start getting cold air inside. Since the condenser is not doing its job, the unit's thermal protection will cut off compressor until cools down and then will start again.
Replace condenser motor (around $100) ASAP and do not use unit until then, othewise, major damage to the unit can occur.
If helpful, click below. GOOD LUCK
Aug 04, 2008 | Intertherm P3RA-042K Air Conditioner
Goodman CKL60AR60 Air Conditioner Logo
105 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
