Question about Easy Flo EF1400 Central System Vacuum
Easy-Flo 1525 will not turn off
It was working fine but this five year old machine would on occasion start screeching in the garage and I'd go down and turn off the switch at the motor and let it rest for a couple of minutes and then turn the switch back on. It would be ok. It has been doing this "Screeching" similar to a loud whistle since it was new.
Today I went down to turn it off at the motor to stop the screeching and then my wife continued but now it can't be turned off at the vacuum handle...the wand or broom whatever it is called. Now it must be turned off at the motor/tank in the garage. Help please.
Thanks,
Fil
  • ffil246 May 29, 2009
    Thanks Dees 421!! Good info you provided which I will keep for the future. What I found through exhaustive trial and error was tat the hose part which plugs into the wall, and by making contact with the two little contacts, would turn on the vacuum. It was not because there was corrosion/dirty/foreign substance on both the hose end and on the contacts. Thouroughly cleaned and it works.
    Thank you for your response!
    Fil
  • 50 Answers
There is a relay back on the master unit. When the hose is plugged into the inlet the metal on the coupling completes the electrical circuit to the relay. In your case the coupling has a split and the circuit continues to the switch in the handle. As long as there isn't any conductive surface left across any of the contacts in any of the inlets, the relay is hung up. I never heard of that happening until today when I responded to the exact same problem on a different machine. The relay needs to be replaced.
The "screeching" on the other hand should have nothing to do with the relay. That sounds like a motor bearing without proper lubication and/or going bad.
Posted on May 29, 2009
Easy Flo SQ9020 stopped working - what should I check to identify what the problem is?
I am assuming you have checked the breaker that it is on? Have you tried using it at a different outlet?
Jan 10, 2015 | Easy Flo Vacuums
Central vac system is 18 years old. Recently started to shut down during vacuuming. Motor may be over heating. Electrolux has been out and is pushing a new system but not sure if it is necessary.
The motor can be replaced for a lot less than the cost of a new machine. A new motor comes with a one year warranty if installed by the service tech. A new CV unit alone may be over three times as much, but does have a five year warranty.
At 18 years, there are other things that could be getting worn out as well. If you happen to need to replace them over the next year or two, then you would have been better off getting a new machine. Just the motor and hose can be over $600. Add the power module, power nozzle or parts, and wands, and the costs can end up being over $1000. So take a look at the hose and accessories. If they show a lot of wear and tear, then it might be better to replace the whole thing. A new machine carries a five year warranty, which also covers accessories.
Also, have you notice a loss of suction? This usually results from a worn out, leaky hose, and with a 30 foot hose can result in a tremendous loss of suction.
Just take all things into consideration.
Personally, I'd recommend a new canister vacuum. Depending on the model, they come with a five to twenty year warranty, with five on the accessories from the hose down.
Dec 01, 2010 | Electrolux Cs 3000 Central System Vacuum
I am buying a central vac system, can you tell me the better of the easy flo or nutone brand. I want the one with the least problems. It appears to me that the easy flo has fewer problems, thank you
between the two brands... stay away from the nutone. If you can get it, the Beam, Eureka, or even the Electrolux and Kenmore(sears) would still be better. The warranty would be better on the Beam and Eureka (7 or 10 and one model is even 15 years)
Good luck on your purchase.
Mark
Nov 09, 2010 | Easy Flo EF1525 Central System Vacuum
My easy flo built in system wont turn on when the
If there is a switch on your hose, it may be broken.
Your system powers on from the inlets via two low voltage wires that run from the inlets to the switch/relay at the power unit. Each inlet has 2 spring loaded pins attached to the low voltage wires. In the photo below you should see these pins at the bottom of the opening, just above the door hinge. The receptacle at the top of the inlet in this photo supplies 110 volts to power your power nozzle. Not all inlets have this option, but if yours does, exercise extreme caution. Your hose must have a completely metal end or if it is a plastic end, it must have a metal band in order to short the 2 low voltage wires together to trigger the switch.
You can manually short the two low voltage pins together by using a metal pipe or needle nose pliers, just touch both pins at the same time. CAUTION: stay away from the 110 volt receptacle if present.
If your system powers on with this manual method then it would seem that the problem is in your hose.
If your system does not power on; your low voltage wires may be disconnected from the power unit or disconnected somewhere else . It's also possible that you have a bad circuit/controller board in the power unit.
May 11, 2010 | Easy Flo EF1400 Central System Vacuum
I have an easy flo vacuum model # 199C and it won't shut off. It started out as an intermitent problem but now will not shut off when the hose is unplugged, nor when the off/on switch on the main unit is...
Remove the low voltage wires (top left) if the vac unit still runs the problem is with vacuum
if the Vac stops running then there is problem with the low voltage wires in the home possible short some where in the system Chech the inlet doors first. Easy Flo vacuums have a lifetime warranty call 1800 easy Flo.
Feb 13, 2010 | Easy Flo EF1500 Vacuum
Beater attachment has no suction.
Your hose issue is isolated from the garage. You have a switch problem in the handle of the hose.
If the hose has a swivel handle your problem will lie in the switch itself or the contact rings within the lower portion of the handle itself. If this is a light gray hose with swivel handle several years old switches were an issue from time to time . The problem can normally be fixed by replacing the internal wiring harness in the hose.
Oct 03, 2009 | Easy Flo EF1600 Central System Vacuum
Hi, I have a Sebo X4 which is almost 3 years old. I haven't had any problems with it until the last couple of days when I notice a slight screeching noise when in upright position, coming from the roller...
I dismantled the top part of the machine from the bottom and there stuck right down in the bowels of the tubes was a piece of card, a dress label! somehow it was only making a noise when the machine was in an upright position. It took a bit of stretching and maneurering but once it was out the problem was solved.
Jun 11, 2009 | Sebo X4 Bagged Upright Vacuum
Easy Flo Central vacuum will still work at about
Yes you can easily test for a clog, and a crack for that matter.
to test for a clog push a dry garden hose through the entire system until it comes out at the other end.
to test for a crack, Disconnect the pipe that comes from the house to the central vac unit. Turn on the unit and put your hand over the opening directly at the central vac unit.(Using the utility inlet at the unit will not accomplish the same thing.)
  • Step 2 If your suction is good, then reconnect the tubing and turn on the switch at the unit. If there is no switch, plug your central vacuum hose into one of your inlets to start the system. Then have someone completely seal the hose with their hand. While the unit is running go to the exhaust. With everything closed you should feel almost nothing coming from the exhaust. If you feel very little exhaust, then you do not have a leak
  • Jun 06, 2009 | Easy Flo EF2300 Central System Vacuum
    I have a 10 year old AirVac central vacuum system that has worked until this morning. As I was using it this morning, and turned it off for about five minutes it would not start again. The tank in the...
    Sounds like the motor finally siezed on you. Motor is trying to turn but won't thus the hum. Do not allow the vacuum to stay on like this as it may cause a fire. Requires a motor replacement.
    Nov 23, 2008 | M&S Systems ZX7000 Bagged Central System...
    Easy Flo EF1400 Central System Vacuum Logo
    229 people viewed this question
    Top Easy Flo Vacuums Experts
    JoeVacs
    Are you an Easy Flo Vacuum Expert? Answer questions, earn points and help others
