Question about Dell PowerEdge 2500 Server
Where to plug power button into mother board
"the site given was great for board info but its doesn't show which connector is for power button" i need to know where to plug a power button on the board of a poweredge 6450 and poweredge 2500
  • Anonymous Mar 27, 2014
    how to find out which fan is out.
  • 59 Answers
Open the case of the server, and look on the side panel that you removed. It should have all of the server options detailed right on the inside of the case for you.
Posted on Jan 03, 2010
I have a Dell N5040 that has no power. When you plug charger in the light on the charger box goes out. Any help would be appreciated.
this is problem with mother board
try this
remove all power connections
remove battery
press and hold power button for 30-40 seconds
and just plug power connector with out battery
if it power on go to bios and restore defalts
try to are three times
or chaing mother board
Oct 28, 2013 | Dell Inspiron N5040 Black New
I was given a presario S3000NX with all power supply cables unpluged. Have place for all but a 4-pin square connector. Any idea where it may go or is it needed?
1. for what you describe could be the sound card cable from the DVD or CD ROM
not sure without a physical look at the cable. there should be a black connector either at the
top corner of the mother board or by the pci slots that the connector is placed.
If you have a sound card mounted in a PCI slot then there is a connector on that board
for this cable.
I hope this helps. Have great day!
Oct 07, 2010 | HP Compaq Presario S3000nx (DC475A#ABA) PC...
I need to see where to plug in the start button plug on my ht2000 mother board as i changed towers?
Try this site and download the manual.
http://www.supermicro.com/Aplus/support/resources/results.cfm
The info. you want is page 2-6. The bottom two pins on the diagram are for power on.
Sep 09, 2009 | Computers & Internet
For laptop: Toshiba Satellite A105: My battery won't charge/computer won't turn on when plugged in. No lights show when plugged in. Don't know if it's a problem with the chord or the computer. Don't want...
Start by trying another power outlet.
The power adapter should have its own light. If it doesn't light up then the adaper is bad. Kensington.com sells very inexpensive universal power adapters. You might also find a good deal on eBay.
If the adapter lights up then it may be your battery. Notebook batteries are only good for 2-3 years. If you let them sit for a long time without a charge they may only last 1-2 years.
Vote for this solution if it helps.
Aug 18, 2009 | Toshiba Satellite A105 Notebook
Need picture of mother board for Emachine C2825
I've built a PC myself, each connector had text on it to say what it was and one arrow on it in relief, don't know wether that indicated plus or minus anymore.
Anyway, I recommend you just plug them in, and try to boot the PC. If it doesn't boot, switch the Power SW connector around, then it should boot. Do the same with the LED connectors, and it should work just fine!
Good luck,
Yannick.
Jul 13, 2009 | Intel D845GVSR Motherboard
Connectors
i think this is enough which is given on the msi site itself contains all info about the connectors
http://msi.com/index.php?func=proddesc&maincat_no=1&prod_no=1438
download manual from this link
Jul 04, 2009 | Intel Motherboard
Mother board problem ,and i dont wana buy a new 1!
IN order for the machine to power up properly. make sure you have correct memories specified by the motherboard manufacturer.
insert them as instrcited and connected a VGA (analog-old stype) monitor to the 15 pin connector. and power it up.
if it comes up great, continue with what ever you are going to do. if not, post back in this thread.
Mar 03, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Will not power up unless I move the display back and forth
Sorry I lost my password. This is a common problem with the 610 and other laptops. This repair is not for a Novice. Please get the maintance manual from dell go to dell support its free and know the disassembly procedures for tearing your laptop apart. Remove the bezel on top of your keyboard. The start button is on a small pc board. The problem is on the connector on the bottom of this board that commects to the Mother board of your computer. Remove all external, and plug in devices to your laptop. including the battery. After removing the keyboard, the top plastic cover, the start pc board, ect. you can see the connector from the start board that connects to the mother board. Look carefully and gently see if this connector is loose. The mother board connector is supported by 2 silver looking braces on each end. gently see if they are loose. I bet that one end has broken loose from the mother board. re solder the loose end to the mother board. be careful not to damage anything as I said this is not for the novice. (with the laptop in pieces put the startup pc board back in, temporairly put the battery in and push the start button. If the led's glow, this is where the problem is. While your laptop is apart check for dust ect. You may need to remove the heat sink , and a back support brace to get to the mother board connector to re solder it.
This has been a problem on 3 of my friends laptops Pushing on a button harder and harder doesn't solve the problem. It's not the button .Now you know the rest of the story.
http://support.dell.com/edocs/system/latd610/en/sm_en/index.htm
Hopes this helps just remember where all the extra screws go when you re assemble your laptop
Dec 11, 2008 | Dell Latitude D610 Notebook
Got dvd burner cant get it working
plugged to ur mother board by connect it to a IDE Connector cable just like ur HDD and a power connector aswell
if this not helping u dont rate me and temm me more info
Aug 17, 2008 | Computers & Internet
Mother board
about the small connectors, there is white text printed into the motherboard showing what goes where.
about the drives, check your cables.
May 03, 2008 | Computers & Internet
Open Questions:
Dell PowerEdge 2500 Server Logo
497 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
