Sharp 32lf-92h picture problem
I have the above mentioned tv and the picture is permanently stuck in what i can only describe as zoomed in mode. I have tried to view the menus but get the top half only but have played about and am able to adjust stretch, zoom etc but this makes no difference. The problem has gradually got worse over time. When in menu it seems to be low on the screen and zoomed in
  • 2 more comments
  • Anonymous Dec 19, 2007
    I'm having the same problem. it's still watchable at the moment. Does it get worse? Have you resolved the problem anyway. I'd be interested to know.
    Thanks
  • miket4246 Dec 19, 2007
    I'm having the samw problem. Its still watchable at the moment. Does it get worse? Have you found a solution to the problem? I'd be intersted to know.
    Thanks
  • jasperream Feb 15, 2008
    same here
  • vivatriado May 19, 2008
    I have same problem as well, can't see my sky+ menu properly
Any ideas on this problem?
As i have it now.
Posted on May 25, 2008
Hi, I have this TV that i love, recently i see the picture is bigger and i cant see the subtitle and or words around picture like Channel name or ads running below picture
See page 24 of the included manual The view mode button is just above the channel change button. The manual shows how the screen will zoom etc as you right size the view for you. I've included an image of page 24 in the event you can't read the PDF file.
It is east to mis the channel scan and not realizing it change the aspect ratio
I hope that this helps.
https://content.abt.com/documents/37621/LC60LE830U_manual.pdf
Jan 10, 2016 | Sharp Aquos LC40LE830U 40-inch 1080p 120Hz...
Sharp view area
This has something to do with the setting. Try resetting through remote and see.
Aug 21, 2012 | Televison & Video
I have a HD Visio and I lost my TV remote, my TV is stuck on Zoom Out and I cannot play my new Nintendo WII game becasue the TV picture is to large, I went into menu and could not see anything to zoom,...
Sorry u can't fix this zoomming mode problems without the tv original remote.This tv zoomming mode function it is have it only on the tv original remote function only no where else.Try website like Remotes.com to buy the tv original remote to use.
Sep 22, 2011 | Vizio m420nv 42 in. LCD HDTV
Just recently my sharp aquos lc 40 e is stuck in stretch of wide screen and the heads or top of things are being cut off. When i go to view mode it only gives me 4 options wide, stretch dot to dot or zoom...
Not all TV programs are broadcast in 1080. When you use zoom or stretch on a program in 720 or 480 and a 1080 program is viewed you have to go back and take off zoom and stretch to get a correct picture.
Aug 29, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Hight less
Hello
You have only stated that the height of the picture of your TV is less. Check whether your TV is working on "wide" mode. The mode should be set to "normal" for a full screen picture. There may option to turn the mode; through remote control handset of your tv. Select it, after entering into menu option and check. There are normally 3 modes will be displayed. "NORMAL, WIDE, ZOOM". You have to select "Normal" mode. If this does not helps, your TV needs height adjustments. It can be done only through some code send to the tv via remote. It is known as "service code". It is uneque code, and can be had only with the help of a well experienced technicin. If the problem pereists contact any one of such mentioned above.
gopakumarg43@ymail.com
gopakumar1@hotmail.com
Oct 19, 2010 | Zenith C27A24T 27" TV
Sharp TV LCD experiencing black screen with lines update
hmmm does seem like the backlight inverter is bad there but if ya hold up a light to the screen and your seeing colors and movement then it was the backlight thats gone bad but if ya see nothing after shining a light at an angle at the screen then the picture board has gone bad with it
Apr 21, 2017 | Sharp LC-32AV22U 32 in. LCD TV
PIcture does not fit on TV
TV must be set to zoom, take the zoom setting off
Mar 06, 2010 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
TV in permanent zoom
The left and right arrows on the RCA remote control are the picture format buttons.....
Apr 12, 2008 | RCA P61939 61" Rear Projection Television
Picture larger than screen...
If you go to 4:3 mode and the picture is still cutoff then i would assume the tv has a problem with the horizontal or the pinchusion correction circuit . This would be the only two areas that would cause this problem . Check the format section of your menu to make sure it is not in zoom mode or otherwise if it is not then you have a problem with one of two above mentioned circuit problems . Good luck
Feb 01, 2008 | Sanyo DS31520 31" TV
Sharp TV - 32LW92H - Zoomed in
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Nov 05, 2007 | Sharp 32F640 32" TV
Televison & Video Logo
186 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
