Question about OKI B4350 Laser Printer
When printing all I get is a message saying invalid data (printer B4300)
I have loaded the printer driver and when I try to print anything all it says is invalid data this is as soon as I press print
I had same problem and when I installed OKI B4350 (PCL) driver it started working fine.
Before I had OKI B4350(PS) driver installed and it gave me invalid data error everytime I've pressed print.
I hope this works for you too.
Cheers,
T
Posted on Jun 06, 2009
Hello, I ran into this problem and the only TRUE fix is as follows.
Control Panel> Click on Devices and Printers > Right Click on the Printer OKI 4300 > Click on Printer Properties > go to Advanced and click New Driver
>>>>>>Because Windows 7 loads the wrong driver you have to trick it using a different one<<<<<<<<<
Select HP Laserjet 4200/4300 PCL6
MAKE SURE TO CLICK APPLY!!!!!
and now your all set print your life away!!! LOL
Cheers!!
Shawn P
Posted on Aug 14, 2012
THANKS...it works
Posted on Oct 04, 2012
  • 1 more comment
  • Tizmy Hernndez
    Tizmy Hernndez Sep 01, 2014
    was searching for hours the solution, and finaly an thanks to you it works
  • Tizmy Hernndez
    thanks thanks thanks
  • Jorge Abraham
    Jorge Abraham Mar 19, 2017
    how about a OKI4600, someone now here?
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
HP 4350 ERROR MESSAGE: 49.2F90
"the printing operation has been aborted.
The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications.
Action :
1> Press Cancel Job to clear the print job from the printer memory.
2> Turn the printer off and then on to clear the error message.
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
If the above action does not solve the issue, contact HP or authorized service provider."
Mar 15, 2008 | Office Equipment & Supplies
What's a 016-799 error code mean?
016-799 Wrong combination of print parameters, like selecting to print on custom size paper and setting [Auto] for [Paper Source] on the printer driver and [Auto] for [Paper Size] in trays 1 to 4 on the control panel.
Check the print parameters.What we did is match the documents page size and paper type to the printers (A4) then we could print.
Oct 04, 2010 | Xerox WorkCentre 7328 Multifunction laser...
LaserJet 4350 Printer: HP 4350 printer, 49.2F9D service error...
1st thing to do is upgrade the firmware. Go to hp.com and look for the software and drivers. Drill down to the firmware and read the instructions.
May 16, 2010 | HP LaserJet 4350 Printer
Printer keeps saying ram check and will not do anything else. No error code or anything. Just keeps sayig ram check
from what i know, some printers have a memory ram disk that holds the information for printing.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats. also see if there is information in this icon settings page about memory settings.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Apr 29, 2010 | OKI B4300 Led Printer
Invalid data
try changing the usb cable to 2.0 type... this happen when there is some corruption in the data.. once cable is replaced and still having same problem.. you might need to reinstall the driver and change to another usb port in the cpu.. most cases I come across is due to the cable problem.
Feb 19, 2010 | Epson Aculaser C1100 Printer
Problem with our printer 5200tn ...error 49 4c02
From the Service Manual:
49.XXXXX ERROR
alternates with
To continue turn off then on
A critical firmware error has occurred that
caused the processor on the formatter to
abort operation. This type of error can be
caused by invalid print commands, corrupt
data, or invalid operations. In some cases,
electrical noise in the cable can corrupt data
during transmission to the printer. Other
causes include poor-quality parallel cable,
poor connections, or home-grown programs.
On rare occasions, the formatter is at fault
which typically appears as a 79 Service Error.
  1. Turn the printer off and then on.
  2. Press Stop to clear all print jobs from the printer memory.
  3. Turn the printer off and then on.
  4. Try printing a job using a different software program. If the job prints, try using the original software program to print a different job.
NOTE If the error message
only appears when using
certain software programs,
contact the software program
Dec 18, 2008 | HP LaserJet 5200tn Printer
Support
49.XXXX
PRINTER ERROR
abort the operation.
This type of error can be caused by invalid
print commands, corrupt data, or invalid
operations.
In some instances, electrical noise in the
cable can corrupt data during transmission
to the printer. Other causes include poorquality
parallel cables, poor connections, or
specific software programs.
Sometimes, the formatter itself is at fault,
which is usually indicated by a 79 Service
Error
1 Press CANCEL JOB to clear the print job
2 Turn the printer off and then on.
3 Go to www.hp.com/go/lj4200_software,
www.hp.com/go/lj4250_software,
www.hp.com/go/lj4300_software, or
www.hp.com/go/lj4350_software.
Select Download Drivers and
Software
. Check for the latest firmware
image version at the bottom of the
page. If this firmware image is newer
than the one installed on the printer
and the printer can receive a firmware
update, download the newer firmware
upgrade. Not all
HP LaserJet 4200/4300 printers can
receive firmware upgrades.
4 Try printing a job from a different
hope this helps you
pdouglasss
Dec 10, 2008 | HP LaserJet 2420dn Printer
OKI B4350 Laser Printer Logo
7,359 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
