Question about Radio Shack TRC-503 CB Radio
The cigarette outlet in my Audi TT is too small to accomodate the power plug from my Garman GPS. Is there an adapter I can purchase? Thanks.
  • mwallace66 May 11, 2010
    Is this a GPS unit, or a CB radio, please clarify.
Go to sturdevants auto (or possibly another auto store, but i got mine from sturdevants) and get a single to double outlet adapter. make sure it has separate wires to each one, then wrap it around the nearest knee pad support thing to make it stay in place. works great for me. the wires on mine are about 6 inches to each new outlet.
Posted on Jun 13, 2009
Audi tt not communicating with obd scanner
Check for battery voltage in the bottom right hand pin on the DLC. If the voltage is not there , check for blown fuses that power the power outlet or cigarette lighter.
Feb 25, 2015 | Audi Cars & Trucks
Is there an adapter that can be used on a car cigarette lighter for plugging in appliances?
Your best bet is to check on eBay for an adapter - the Asians make all sorts of stuff for cars now & i'm sure there is an adapter out there suited for your purposes. P.S. It may sound silly but are you sure you are using the actual cigarette lighter socket & Not a power outlet socket that many cars are now fitted with as standard?, my phone charger fits the cigarette socket but not the power outlet?, you never know?
Sep 13, 2012 | 2004 Kia Rio
I have a 1999 Buick Century. When I plug my GPS power adapter into the cigarette lighter outlet, I blow the fuse. ---Can you suggest a solution? ---How many amps are in that...
Probably a 15 to 20 amps..If you use the cigarette lighter does it also blow the fuse ,you may have a short in the circuit..It should be able to handle the GPS..Dont increase the fuse size,you can cause bigger problems
Sep 05, 2011 | 1999 Buick Century
How do you get started... where do you plug in the gps in my toyota avalon? I have a 5045
Hello, If i understand correctly, you are just trying to set up your Magellan gps into your Toyota Avalon. First of depending on the kit you got for the bracket to hold the unit, it normally will have a suction cup, that secures the bracket, put the bracket on the window, normally to the right of driver view and toward bottom of window, then after putting mounting (suction cup and gps holder) on window, then mount gps in to bracket, now your gps is mounted at this point on window. Now, of course you have to plug it in. GPS kits when you buy them normally have a 110 power plug ( to plug into home outlet) and some will have with the kit, a 12 volt cigarette type of plug to plug in your car (which is 12 volt power) In your home of course you can charge the gps off your 110 power, and gps will run off internal battery for a few hours, but you will find out like with mine, that your better off to plug into car for power, because the internal battery does not last very long. I have a Magellan as well, and they are great units. NOW this being said, if you did not get with your gps a 12 volt car adapter for your gps, you will have to get one. ( unless you have a power converter, which takes 12 volt and converts it to 110 power, but that's another story and only recommended for devices that do not have 12 volt adapter capabilities)
In conclusion if you have the 12 volt adapter to plug in your gps, all you do is find your cigarette lighter, take out your cigarette lighter, put in glove box for storage, and plug your gps in your cigarette lighter, or any other 12 volt cig lighter plugin. That's all there is to it, and now you have power running off your car. Thanks mike , hope this helps
Jul 23, 2011 | Magellan Roadmate 5045 3065 3055 3045-LM...
Just got my TTone, confused about when to use the charger
To avoid an eventual loss of power while you are driving and the subsequent unsafe fumbling with the machine, you can plug the TT in the cigarette lighter during your ride. This will supply power to the GPS and recharge the battery.
Alternatively, before going on a trip plug the TT in a USB port of a computer and it will recharge the battery. With a fully charged battery and the car power adapter/battery charger you will not run out of power.
Dec 31, 2009 | Tomtom ONE 130 GPS Receiver
Fuse blown on cigarette lighter Saturn 2001
It sounds like you have a bad charging cable for the GPS or the cable is overloading the cigarette lighter.
The cigarette lighter is designed for less power then a 12v power outlet.
Therefore it is easy to blow the fuse for the cigarette light if you install something that draws too much power.
Jul 07, 2009 | 2001 Saturn S-Series
GPS plug do not fit in car cigarette lighter
Buy a adapter for your cigarette lighter socket that has multiple sockets with one that will fit the Garmin adapter.
I've never heard of a problem you are having??
Are you using a Garmin plug?
If not get one.
May 08, 2009 | Garmin Nuvi 660 GPS Receiver
Auatomobile adaptor not working
Thanks for letting me assist with your problem. Does your vehicle have another lighter or utility plug? If it does, try and plug your One into a different one. If you only have one, try it in a friends vehicle and see if the problem continues. If it stops cycling on and off, then it's the lighter outlet in your vehicle. If it doesn't then it could be the plug on the vehicle adapter. If my help has been satisfactory, I'd appreciate a rating. Thanks for using FixYa.
Jan 29, 2009 | Tomtom ONE GPS Receiver
WE CHARGE THE MAGELLAN GPS AND TURN IT OFF. BUT WHEN WE GO TO USE IT AGAIN IT IS DEAD. I ONLY HAVE THE LIGHTER OUTLET TO HOOK UP FOR POWER SO WHEN I NEED TO PROGRAM IT IN THE HOUSE I DO NOT HAVE A WAY TO...
Hello kdiltzbook,
Most GPS units can be charged three different ways:
1. Connection to a computer via USB port
2. Connection to a automobile via cigarette lighter plug
3. Connection to a wall outlet via an AC adapter
Typically most GPS devices these days include only the USB cord. Some GPS units also include the cigarette lighter plug. For most GPS units the cigarette lighter plug and AC adapter are optional accessories have to be purchased in addition to the GPS.
You don't mention which model of Magellan GPS you have so I am not sure which cords your GPS should have included. It sounds like you have the cigarette lighter cord and the USB cord? I am sure that Magellan has an AC adapter available for your GPS. You will want to contact them directly (their website is http://www.magellangps.com) or visit an electronics store that sells Magellan GPS receivers (such as Best Buy™) to purchase the adapter.
However, most GPS receivers can be charged from the USB programming cord on the computer. However, ensure you are plugging the cord directly into a USB 2.0 on the computer itself NOT a port on a USB hub. (A USB hub may not output enough power to actually power and charge the GPS.)
You will also want to check and replace the fuse on the automobile plug.
I believe that both the USB and automobile cords should be charging the GPS. If neither adapter is charging the unit then the problem may be the GPS unit itself. The GPS may have a bad battery or problem with its charge circuitry. If that’s the case the unit may require factory service as the battery pack is generally not considered to be end user replaceable.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | GPS
Radio Shack TRC-503 CB Radio Logo
148 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
