Question about Mtd Garden
STARTING PROBLEMS MY MTD RH115 RIDE ON LAWN MOWER WILL NOT START, I BOUGHT A NEW STARTER SOLENOID BUT I DONT KNOW WHICH WAY ROUND THE WIRES WERE. I CAN START IT BY JUMPING STRAIGHT TO THE STARTER, BUT NOTHING THROUGH THE IGNITION SWITCH. THE SOLENOID DOES NOT EVEN CLICK CSN SOMEBODY PLEASE HELP ME.
  • hydrawiz May 22, 2009
    It was runnig fine last weekend, my son was cutting the grass, i got on 5 mins later, the solenoid clicked, then nothing so i bought a new solenoid but my son had allready removed the wire & we dont know which way round they go. have tried several different ways but nothing.
  • 11,896 Answers
Either the igniton is bad or the wires are backwards. You can bypass the ignition and touch the wires together to see if the solenoid turns. You can also use an ohmmeter/voltmeter to check the current.
Posted on May 22, 2009
  • Nate Stansfield
    Nate Stansfield May 22, 2009
    Try both ways. It will not hurt the solenoid..
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
How do i install a starter cylonoide on a toro timecutter rear engine lawn mower that has a kawasaki 22 hp motor i dont know were the green and blue wires go
do you mean a solenoid? if so then the 2 wires fix to the spade terminals on the solenoid just below where the 2 large red ires are bolted to the solenoid
May 06, 2015 | Toro Garden
Have a mtd 13a3762f700 blowing a fuse
You must have a short somewhere in the ignition/starting wiring.
Jun 28, 2014 | Mtd Lawn Mower Solenoid Starter Replaces...
I have a MTD ride-on about 3 years old which has an electrical problem. When trying to start the mower the engine doesn't crank. I can hear a "clicking" noise from below the seat. I would have thought this...
If you know that the battery is good, then it is the Magneto, (This is the part responsible for recharging your battery as you use the mower.)
However, your battery may be bad and no longer receiving a charge. Take it to a local auto parts store and they can test it for free.
Good Luck!
Jim
Sep 13, 2010 | Mtd 46" Dozer Blade, Fits All & Yard -...
How do I know which post is "in from battery" and "out to starter"? Thanks.
Just guess and hook up the two heavy wires. If it doesn't work, reverse them. You won't hurt anything. BUT---Make sure you have removed one cable from the battery (either one) before making or removing connections to the solenoid.
good luck
Jun 09, 2010 | Mtd Lawn Mower Solenoid Starter Replaces...
Starting problems with my cub cadet 2166 lawn mower? Battery is good, not turning over, sometimes it clicks? I can jump start but it is a pain. I have taken this to a dealer last year for this problem....
If it works when jump started, then I would suspect a bad battery or lose or corroded connection. check wires from battery to starter relay also known as solenoid to starter,if it is making a click,the ignition is most likely ok . safety start switch is ok ,I still suspect Battery..can you have it load tested or try a known good one?PS if above test OK, then starter or starter solenoid /relay.Hope this helped you fix it. please let us know if this helped.thank you.
Mar 22, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Mower will not start, battery cgarged up but onlhy
Check all the wiring connections on the starting system. Start at the battery. Both posts. Then, check where the ground goes to the body of the tractor. Make sure it's not rusty and making a good connection. Check the wire from the battery to the solenoid. If worse comes to worse, you can take a jumper cable and go from the battery + side and jump right to the starter post where an electrical cable connects. This will let the engine turn over, but make sure you have the mower in neutral and brakes set, with blades OFF!
Jan 28, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Ride on mower mtd will not start
Use a jumper cable from the battery to the post on the starter where the wire from the solonoid connects, if it spools up normal its the cable to the starter motor, if it continues to turn slow remove the starter and clean up the places where the starter and engine case contact each other (to ensure a good ground). If none of these solutions correct the issue the starter could be dragging and need to be replaced.
May 26, 2009 | Mtd LAWN MOWER PART # 16998A DECK...
Garden Logo
546 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
