Question about Maytag MER5730 Electric Kitchen Range
Element on stove wont heat up
Replaced element and still doesnt work. where do i go now or what is my next step? merh752baw maytag
    Problem Solver:
  • 12 Answers
If this is an electronically controlled range, then sadly the problem is probably in the Electronic Oven Control and the only repair is to replace the EOC. We are at the mercy of poorly made electronics. AJ
Posted on May 22, 2009
Maytag MIR8890AS0 6.2 cu.ft. induction range w/true convection. Takes an hour or more for oven to pre heat, doesn't maintain heat. 4 yrs old. Induction top OK.
I don't know, but it sounds like one of the heating elements are burnt out/no longer working. I had a similiar problem 5 years ago.. they're pretty easy to replace yourself if you are handy and have a screw driver. I think the one for my stove cost $18 to replace (5 years ago) here's the trouble shooting guide online for you model:
Maytag Range Stove Oven MIR8890AS0Troubleshooting Repair Help
Dec 07, 2016 | Maytag Kitchen Ranges
Three of the four stove stop heating elements thermostate doesnt work. It is either on fully or have to turn off to manage heat. remedy ?
Hi, You will have to replace the switch with a new one. That is all that is needed . Good luck.
Jan 12, 2016 | Dryers
Maytag neptune dryer doesnt heat
On the housing the element mounts in is a couple of safetys The smaller one is rated for 300f and the bigger one is rated for 250f. If the smaller one is tripped obviously you replace them both, making sure the vent to outside is clear. Them fuses blow or trip because of air restrictions.
Aug 04, 2012 | Maytag Dryers
Maytag accellis 2x stove won't heat-up, does power-up, light comes on but no heat
Buy a new stove element. If you open the stove look in the back. It should be black. It might have a crack or be clearly broken. This is a cheap fix. If you want to be sure that it is working at the connection unplug the element and pull it out. Put a volt meter into the prongs. Turn stove on and see if its putting out voltage.
Jun 02, 2012 | Maytag Stove / Oven / Range Cooktop -...
Maytag performa model per4311acw
The oven's element may be defective. Take a look at the heating element and look to see if there are any unusual 'marks' on the element.
It is a simple fix.
Unplug the stove, unscrew the screws holding the element to the back of the stove, gently pull the element a few inches towards you, pop off the connectors, take the element out and take with you to the store. It is a good idea to take the model nukber with yoy when you go to the store.
To replace, just reverse the steps above.
Sep 07, 2009 | Maytag PER5710 Performa Electric Kitchen...
Faceplate on a new Maytag stove pushed in...
Appliancepartspros.com has an excellent exploded view diagram of your stove that you can reference. Just type in the model number you provided and look under the Control Panel/Top Assembly section. I believe you may have a broken clock bracket (item 2), but you will need to remove the BACK of the control panel to access everything to inspect. Make sure you UNPLUG the stove before servicing. If you have questions, let me know. I hope this helps you.
May 05, 2009 | Maytag MER5770 Electric Kitchen Range
8'' electric stove top element not working
timer on what ? make, model and age of unit might be useful in forming a coherent response.
Mar 07, 2017 | General Electric Stove/Oven/Range Chrome...
HOTPOINT ELECTRIC STOVE
two things---when you open the oven door do you see a button on the right or left side?if so thats a door switch and if its bad you will get no voltage to the element.the next thing is your hi limit is bad.this is a sensor that monitors the temp of the oven and if its bad you wont get any heat.some hi limits reset themselves others you have to manually reset them.let me know.
Jul 30, 2007 | GE JKP15 Electric Single Oven
Maytag MER5730 Electric Kitchen Range Logo
460 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
