HI THERE, Unplug machine for 5 minutes for a reset and try a spin /drain cycle. It is too simple but why not try. Now that your hopes of an easy fix are shot unplug machine and let the fun begin. The screen is located behind a door at the bottom of the left front of washer. Open door. Remove door. Grab a good size shallow pan and a large rag. Pull plug to drain machine. Once water is out remove screen - it is part of the round knob in that area. Some water will come with it. Clean screen. I use acid to remove build up on the screen from well water. Inspect entire area. A small dental mirror can be helpful. Junk can get caught up in impeller to pump. I had a shaft break on mine and had to replace pump about two months ago - $40,00. Remember something is stopping the water. If filter / screen was really full and you found something plugging the drain - Replace filter / screen and hose plug. Plug in to wall and try a rinse and spin.
Hint if water will not drain from hose. pull machine away from wall lean it back against wall. This will hopefully allow you to open screen filter to remove it. I had a plugged hose once. it was a pain to do. I could not tilt my machine because of space. I used a shop vac to drain filter by slowly opening the filter / screen. I was able to then with a wire remove clog from hose. If things are really bad you can tilt machine and reach up under machine and pull small drain hose. IF YOU TO REMOVE PUMP - YOU TUBE. TRY TO REMOVE IT FROM UNDERNEATH. IF YOU CANT, THE HARDEST PART IS THE TUBE GASKET SPRING. VISE GRIP NEEDLE NOSE PLIERS AND ANOTHER REGULAR NEEDLE NOSE PLIERS WORK WELL. I SECOND SET OF HANDS WITH A UNDERSTANDING MIND ARE MUCH NEEDED. IT IS JUST MACHINE - IT HAS NO SOUL- OR FEELINGS. YOU CAN SCREAM AT IT ALL DAY.
Remove bottom front panel(remove 2-3
screws in the bottom) Pull bottom of panel out and down to remove.
Towards
the center bottom you will see the pump. On the front is a round thing
that resembles a filter. This is the pump filter screen...
Get a shallow
pan to put under screen. Turn lid counter clockwise to remove(turn
slowly and allow water to drain. As you may need to dump pan several
times before all water is drained out. Be careful or you could end up
with water everywhere. Once the water is drained pull out screen and
remove the debris and objects stuck in screen and filter housing you
should also be able to see the impeller on the pump inspect for debris.
Once everything is cleaned out reverse removal procedures put back
together.
Good Morning Friend, this is Z. I am happy to assist you!
I see that your question is listed under Frigidaire electric dryer and that you are requesting information on how to remove and clean the filter. Generally speaking, dryers have a lint screen/filter. The screen is typically located at the bottom of the door opening. You can remove this by pulling straight up and removing the lint. Then replace the screen/filter. Hope this helps! If you need further assistance or are enquiring about a different appliance or model number please, please feel free to reconnect.
you can flush or by removing the pan, on the side of transmission. it has no filter,per se, it was what we call filter screen. you don't need to replace the filter, simply clean it.
clean the basket-filter-screening of your Singer Juice Giant Model 774:
First, unplug the juicer from the power source and disassemble it.
Remove the pulp container and the juice jug.
Locate the basket-filter-screening and gently twist it counterclockwise to remove it from the juicer.
Rinse the basket-filter-screening under running water to remove any pulp or debris.
Use a soft-bristled brush to scrub away any remaining residue.
Rinse the basket-filter-screening again and dry it with a clean towel.
Reassemble the juicer.
If you need more detailed instructions, you can refer to the manual for your product
To Replace: This is done with the hood opened and located at the bottom of the windshield on the passenger side.
Note: The fasteners are reusable. Remove the right side of the cowl vent screen. Remove the two-part pin-type retainers and separate the Velcro attachment of the rubber hinge cover to the rear outboard corner of the cowl vent screen. Pull up the cowl vent screen to release the lower clips. Push on the RH corner of the filter to release the clip. Release the LH clip and remove the cabin air filter. To install, reverse the removal procedure
To Reset:
Press the STATUS control to access the System Check function, the message center will display A/C FILTER XXX% RESET FOR NEW.
Press and hold the RESET control to set to 100% , the message center will display IF NEW FILTER HOLD RESET.
After a successful reset, the message center will display A/C FILTER LIFE SET TO 100%.
Check fluid level every 12 months or 7500 miles, whichever comes first. Transmission fluid and filter should be changed every 100,000 miles. On THM 250C transmissions, intermediate (front) band requires adjustment every 60,000 miles, or as required.
1. With vehicle on level surface, apply parking brake and let engine run at curb idle. Move selector lever through all ranges, ending in "PARK".
Remove dipstick and wipe clean, reinstall, then remove again and check fluid level mark on dipstick. Fluid level should check between "ADD 1 PT." and "FULL HOT" marks on dipstick.
RECOMMENDED FLUID
Use only Dexron II or equivalent automatic transmission fluid.
CAUTION:If vehicle has been operated for an extended period of time at high speed, or in city traffic in hot weather, or if vehicle has been pulling a trailer, an accurate fluid level cannot be determined until fluid has cooled down (approximately 30 minutes after vehicle has been parked). So let's get started...1. With vehicle raised and drain pan placed under transmission, remove front and side transmission oil pan bolts. Loosen rear pan bolts approximately 4 turns each. 2. Carefully pry pan loose with screwdriver, allowing fluid to drain. Remove remaining bolts and oil pan with gasket. Remove screen/filter-to-valve body bolts and remove screen/filter with gasket. 3. Thoroughly clean pan and screen with solvent and dry with compressed air. Paper type filters should be replaced. Install new gasket or "O" rings, lubricated with clean oil, into screen/filter assembly. 4. Install screen/filter assembly to transmission. Use new pan gasket and install pan. Add proper amount of fluid to transmission through filler tube. 5. Start engine with shift selector lever in "PARK" position and with parking brake set. Check fluid level and add as required. CAUTION: DO NOT overfill. Best of luck :)
On some models (KitchenAid) you lift off the spray arm and then lift the filter up. It is fastened with spring clips. On other models removing the spray arm reveals screws at the top of the filter housing that need to be removed to get the filter up. If you have the manual there will be instructions for removing the filter.
the pollen filter is usually under the cowl vent screen at the base of the windshield. You have to remove the screen for access.
Call your dealer service dept and ask location & how much to install it. Should be about $25
