My Visioneer 8650 flatbed scanner with auto document feed gives a message when I try to scan a document, telling me to move the switch on the bottom from the "locked" to "unlocked" position. The lock is designed to keep the moving parts in the scanner (not the ADF) from moving during transit. However, once I set the scanner up years ago it has always been unlocked. After this problem appeared a week ago, I have tried to fix by moving the switch from unlocked to locked, and back. I have done this many times, yet the scanner will not recognize that it is in the "unlocked" position. As a result, I cannot scan anything, whether in "reflective" mode or using the auto document feeder. I would appreciate any help you can provide.
Actually a very common problem. Try the following:
1. Power down then re-power up the scanner.
2. Try slightly moving scanner. Sometimes a small change works to fix.
3. Change one of your scan setting to flatbed scan (not adf). Do a test scan under this setting. This will usually kick start scanner unit to unlock.
4. Last resort, by does also work...give it a medium slap on the side, sometimes unjams the scanner light.
5. Super last resort, power down over night, it almost always works the next day. (could be that lock up is heat related to scan lamp, dont know but just a guess).
Excellent scanner, so worth the effort to try these fixes.
Posted on Feb 10, 2010
EVERYTIME I TRY TO SCAN IT TELLS ME THAT MY SCANNER IS LOCKED BUT IT IS NOT. HOW DO I FIX THIS
Scanners have a button for shipping look harder.
A slide switch normally on the bottom.
Jan 09, 2010 | Visioneer OneTouch 8100 Flatbed Scanner
How do you unlock a visoneer scanner 5800 I got back from a trip and tried to scan something and the bar is locked now and won't move more than an inch. The error message says to unlock it but I can't find...
Ensure you are using the power supply that was provided with the scanner.
The power through the strip may be fluctuating and causing the problem.
Download and install the driver provided on the 5800 USB support website.
http://www.visioneer.com/support/flatbed/5800downloads.asp
Jul 13, 2009 | Visioneer OneTouch 5800 Flatbed Scanner
Scanner is locked
Pls try locking and unlocking when power is off. S. Mohan
Feb 05, 2009 | Visioneer OneTouch 8600 Flatbed Scanner
Power won't turn on at all.
would suggest to start testing at the power adapter if the power adapter is not working properly you will need to replace it with a matching power output adapter or exact same model if you can find.
if the power adapter is not the problem, its probably not worth the repair, up to you, I haven't looked into your scanner to see if its valuable or not.
Well a new scanner / all in one printer with a scanner goes around 50usd.
Jan 05, 2009 | Visioneer OneTouch 8650 Flatbed Scanner
How to unlock Visioneer OneTouch 5800 Scanner
i was getting this message when i was using the wrong power supply, i used a diffrent power supply and restarted the computer and it no longer says it, so i couldnt tell you exactly which one made it work, but now i get a box telling me i dont have enough disk space??? any anwsers for that??
Jun 25, 2008 | Visioneer OneTouch 5800 Flatbed Scanner
Visioneer 4400 usb
rod i'm going throught the same difficulty wit mine as soon as an answer arise I'll holla back.
Jan 05, 2008 | Visioneer 4400 Flatbed Scanner
Unlock
Most scanners shipped have a lock on them to prevent the top from opening up and damaging the glass. This is a screw type mabey other but a penny fits in mine. This may not be the case for you but look in your manual to find the unlock device.
This will also in some scanners prevent the stepper motor from moving in transit . The stepper motor is the device thats makes the bar slide up and down to scan the page.
Hope this helped some.
Kevin
Dec 30, 2007 | Visioneer OneTouch 5800 Flatbed Scanner
Hardware Internal Fault
This looks like a hardware fault. I hope (by now) that you have got an RMA and had it replaced.
Oct 13, 2007 | Visioneer 9450 Flatbed Scanner
Error message
Get another scanner. Check whether the lock has not been enabled at the bottom of the scanner. This has happened with me as well and a known Visioneer problem.
Sep 19, 2007 | Visioneer OneTouch 8920 Flatbed Scanner
Visioneer scanner light barely moves HELP!
first u need to install proper drivers for ur . If installed then this may cause due to scanner hardware problem. This can be repaired . Go to ur scanner Provider for reparing. Thank you.
Aug 14, 2007 | Visioneer OneTouch 7100 Flatbed Scanner
122 people viewed this question
jasbo
jasbo
