Question about Canon PowerShot S2 IS Digital Camera
Wont take pictures says memory card era but i replaced the memory card
My powershot s2 wont take pictures says memory card era
  • 11,896 Answers
Oh yes. It is time to change the memory card. Some cameras are tempermental with the memory cards. I would suggest removing and reinserting several times, but i'm sure you've tired that.
Also look at the contacts of the card and in the camera to make sure they are not black. If they are dirty, you can clean them with rubbing alcohol and cotton swab.
You will probably have to replace the memory card.
Posted on May 22, 2009
  • 4,806 Answers
Hi there
Make sure the write protect is switched off on the memory card, take the card out and unlock it, it will be at the side of the card like this wont take pictures says memory card era but i repl - 59a6de4.jpg .
Good luck and thanks for using Fixya!!
Cannon Powershot S2IS memory card slot will not work
What type and size memory card? The S2 works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Apr 12, 2013 | Canon PowerShot S2 IS Digital Camera
Canon S2 IS says memory card error"card locked" how do I unlock it?
Look at your memory card. SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 21, 2013 | Canon PowerShot S2 IS Digital Camera
Card locked shows of view finder, cannot take a picture it shows a't picture but won't take a picture
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 06, 2012 | Canon PowerShot S2 IS Digital Camera
Can I use a 4gb sd hc memory card in a canon powershot s2 1s? the screen says there's a memory card error
The Max. Memory Size of ur camera is : 2048Mb/2GB.........That is reason for which it says that there is a memory card error.
Feb 17, 2011 | Canon PowerShot S2 IS Digital Camera
I have a 4GB SD HC card that works well in my Powerhot SD750 but gives an error code "Memory Card Error" and "Card Locked!" on my PowerShot S2 IS. Is there a fix for this? Peter
The S2 IS uses SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. While you can use SDHC cards with the SD750, you will have to use SD cards, 2GB and smaller, with the S2 IS.
Oct 21, 2010 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Digital Camera will not highlight the format option so I can format my new SDHC memory card
The S2 IS is designed to work with SD cards, not SDHC cards. While an SDHC card will fit into the slot, it is electronically incompatible and will not work. You need to stay with SD cards, 2GB and smaller.
Oct 06, 2010 | Canon PowerShot S2 IS Digital Camera
format the memory card in standard ( FAT)mode into your pc ....and try again ...also try to clean the plug and the card for any dust or so ....if the card is not the original one ...see if the camera specifications includes this card model and size as a compatible one ...there is the posibility that you used the card for something ...and the data on it are not being readed by the camera ...so ...try to format it clean ...
May 30, 2009 | Canon PowerShot S2 IS Digital Camera
Canon powershot s2 IS suddenly does nothing when powered on
There appears to be an issue with the S2 IS after two years.  See the reviews on Canon's website: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=322&modelid=11368#ModelDetailAct
If yours is two years old then you are probably out-of-luck.  It would probably cost more to repair than to simply replace.
You can at least save your photos by removing the memory card and reading the files using a memory card reader on a PC or MAC.
Apr 19, 2009 | Canon PowerShot S2 IS Digital Camera
Canon powershot s2 Is
I just fixed mine. Put your memory card into your computer. Right click on it. Choose format. Reformat the memory card. You WILL lose all pictures stored on it.
Before putting the memory card into your camera, do the following.
Go to MENU and choose RESET ALL.
Choose reset to original settings.
When camera is done doing so, turn camera off.
Reinsert memory card after it is done being formated in your pc.
Then your camera and memory card should work great again. I just did it on my Canon Powershot A620.
Oct 24, 2006 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
74 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
