Question about Kenmore Dehumidifiers
The kenmore 30 dehumidifier
The #s i took off the back of the model are c675-25730-1x and the type #s are d30q-xkeado im looking for a printable manual and the #s dont seem to match up to anything. what do i do or can you tell me the accual model #s or a site i can visit. thanks andre
  • 184 Answers
SOURCE: kenmore dehumidifier 33 model c675-25133
that might be the wrong model #
the first 3 digits should be 580._ _ _ _ _ _ _ _
Posted on Mar 28, 2008
INSUB
  • 15 Answers
SOURCE: Help for old kenmore dehumidifier
Hello Sandy,
On mine, the filter is in the front. Behind the grill. To remove it, you have to remove the bucket first. Then you can see two tabs sticking down that say "Filter Front". You can reach your fingers up & behind it, grab the lip, and pull straight down. For me it requires more force than expected. With the filter out, put the bucket back in and turn it on. Make sure that there is air blowing out the back to verify that the fan still works. I hope this helps.
InSub.
Posted on Aug 05, 2008
Dittoz
  • 3 Answers
SOURCE: Dehumidifier headaches!
There are three things that must be working to extract water. The 'coil' (a finned metal part that allows air passage) if it's filled with dust and obstructions, no air can move...no water. There is a blower motor that mus move the air. If it is seized up an not blowing air...very little or no water. The compressor uses condensation from the air moving across its coils (like the moisture than forms on a cold glass on a humid day) to extract the water from the air. If it's not working then no water.
So, if there is air blowing out of the dehumidifier the blower is working. If the air is room temp the compressor is not working. If it's real hot air, and the humidifier keeps cycling on and off quickly, the coil is dirty. Those are the 3 things that need to be working.
Posted on Jul 31, 2009
  • 4736 Answers
SOURCE: Hi, Kenmore Dehumidifier 4254501. Brand new last
Now that you've had a chance to vent your frustration, Mike. Did you check the outlet the unit is plugged into, to make sure that it's working? Amazingly enough, I answer questions like yours all the time. And, you know what? 80% of the time, the problem is with the outlet. It's either the circuit breaker was tripped or the interior of the receptacle was damaged. And that's not counting a loose wire connection on the receptacle. So, either test the receptacle or plug the unit into another one, that's on a different circuit.
If by chance you have to replace any parts, your Kenmore Dehumidifier was manufactured for Sears, by Whirlpool. So, parts are interchangeable. And, as my son says, "If all else fails, read the Owner's Manual.
Posted on Jun 09, 2011
Did you find the parts for your dehumidifier already?
Posted on Jun 24, 2011
Why is my Kenmore Energy Star 50 pint model 251-50501012 dehumidifier leaking water after I disconnected the drain hose
If you reconnect the drain hose, make sure that it lays flat from the dehumidifier and into the sump pump hole. I did that and it solved my problem of water leaking onto the floor.
Jun 15, 2014 | Kenmore 50 Pint Dehumidifier Electronic...
How to set timer on 2014 Kenmore 50 pt Dehumidifier
if you hold mode button down does it not cycle thru timer settings?
May 24, 2014 | Kenmore 30-Pint EnergyStar Dehumidifier
I don't understand the timer on a Kenmore Dehumidifier
I do believe this one of those models that uses one display for both setting of humidity level and the timer , make sure you are viewing the timer function and not the humidity function , this is a very common complaint with these type as many times one sets the on time correct but then sets what they believe to be off time when they really are adjusting the humidity room level , there should be tiny lights that show function you are adjusting
Feb 18, 2014 | Kenmore 30-pint Dehumidifier with...
Our dehumidifier is no longer pulling moisture out of the air. I took the back off and the fan is still running. So motor or condenser? And is it worth fixing? The machine is approximately 6 years old.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Nov 28, 2010 | Kenmore 54501 Dehumidifier
I have a kenmore 54351 model dehumidifier. It wont come back on the auto shut off light keeps flashing. The tank has been emptied. Its not even a year old yet.
There is a switch that is activated when you slide the tank back into the unit after you empty it. If the tank is not in just right it will not activate this swith. You might look for it and try pressing it with your finger to see if it is working. Not sure about your model but be careful not to shock youself! The switch should be insulated and is really just an interlocked relay...
Sep 10, 2010 | Kenmore 54351 Dehumidifier
Dehumidifier model#5641 fan seems to not operate but frees up after a long period of time. Then works ok. But freezes up again
I just picked up a used one for $5...fan didnt work,,took it apart,,two places to add oil to fan,, Very very small holes,,one is toward the back if the fan cover and one is on the front,,right behind the blades..Hope this helps..Its running great now,, :) What a deal!!!
May 24, 2010 | Kenmore 54501 Dehumidifier
I have a Kenmore 54701 Dehumidifer that quit working is there any thing to look for or just throw it out and buy a new one
Is it not powering at all? Remove cabinet and check glass fuse on power supply board
Is it running but no water?
Check to see if fan is blowing; if not then thermosenser on fan motor blown
Fan and compressor running but no water? Maybe the room is already dry; if not than probably have coolant leak - not worth fixing
Dec 04, 2009 | Kenmore 54701 Dehumidifier
I have a Kenmore 50 pint dehumidifier Model 580.54501400
It looks like it is simple to get the filter out but we are finding it to be imposible. How can we take it out. It doesn't just pull down.
Jul 09, 2009 | Kenmore Dehumidifiers
My dehumidifier does not collect any water.
One of two things is happening here.
1. Either the compressor isn't running or...
2. The water is not being routed to the collection bucket properly. This dehumidifier has an option to connect to a hose that can be routed to a drain. Look in the back of the unit to see if you see a connection that could accomidate a garden hose. If you see this and there is no hose connected you may be dumping the water on the floor instead of the bucket. This could explain why your carpets are damp.
Jun 18, 2009 | Kenmore 54501 Dehumidifier
Dehumidifier
IS THE ROOM HUMIDITY LOW. IF IT IS BELOW 30% THE HUMIDISTAT WILL SHUT DOWN THE UNIT. THE AMMBIENT TEMP SHOULD BE ABOVE 65 DEGREES AND THE HUMIDITY SHOULD BE ABOVE 50 %.
Mar 26, 2008 | Kenmore 53301 Dehumidifier
Dehumidifiers Logo
101 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
