Question about Whirlpool Refrigerators
How do i hook up fridge to sink so we can have water and Ice
We just got a whirlpool. Just need to know how to hook it up to water source. THanks
    Guru:
  • 1,524 Answers
Ice Maker Kit comes with a self tapping saddle valve.
Posted on May 22, 2009
Ice tastes bad
If It were me I would change the filter in the fridge, that always worked on mine.
Dec 03, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
Whirlpool ice maker not working
Ice makers are some of the most worked part of a refrigerator and have about a five year lifespan. There are just too many things that can go wrong that can stop the ice making process. To explain the process of a Whirlpool ice maker I am going to post a Whirlpool Ice Maker Troubling pdf and a short YouTube Icemaker Repair toutorial. If you have any questions I will be here to assist you, Thanks Sea Breeze
May 23, 2012 | Whirlpool Refrigerators
Do i have to hook up my refrigerater to the sink to get water an ice
Yes you have to connect the water pipe from sink to refrigerator back.hen turn ON the water valve o run the water from fridge to freezer section.Form freezer section to water inlet valve at the back of ice maker.Then only ice maker and water dispenser will function.Other wise only freezer and fridge will work.-------------- If you dont have water tube and water valve then You can get required parts from www.repairclinic.com or from online sears part site. If you are not aware of how exactly to set and connect water valve and water tube then local plumber or fridge repair technician can do it for you.Its not at all hard job and can be easily done.It will take near to 15 minutes to connect all parts.------------- Thank you.
Jan 31, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Plum in a Amana fridge freezer
hello. I am assumming that your model has the ice and water dispenser. Not all models do. On the rear of these models with the ice and water feature you will find a small [1/4 inch] line that has to be connected to a cold water supply source. If you go to most any hardware store you can get the little kit necessary to make this connection. The kit consists of a length of 1/4 inch tubing, the connector to attach to the tube at the rear of your appliance, a valve and a tapping kit to tap into your closest cold water source. If the fridge is near the kitchen sink, you may choose to connect under the sink. If not, make sure you purchase a kit with enough 1/4 inch tubing to reach your nearest cold water pipe. J.
Jul 20, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Water supply very slow to the ice maker.
Is the water slow coming out of the water dispenser? Your fridge should have the same water pressure as any sink in your house. Most of the time low water supply is from thw water valve in your basement or under the sink or wherever your is hooked up. Most people use piercing valves and they always plug up
Sep 11, 2009 | Whirlpool ED5VHGXM Side by Side...
Water leaking into the fridge. I think it is coming from the ice maker. If I turn the ice maker off inside the freezer, then the water problem is worst. So, is there a way to cut of the supplier of...
There should be a cutoff valve on the line going to the fridge. This will cutoff water dispenser, as well, if it has one. It may be behind the fridge or under the sink, or???
More help?, let me know.
May 09, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water won't pump to the ice maker.
No button to push. It sounds like the solenoid valve which opens to fill the ice tray is not working. Not getting power, stuck, faulty.
May 08, 2009 | Refrigerators
I have a whilpool ed22rf fridge the icemaker cycles but no water goes to the icemaker. i have water @ the fridge,dispenser,and @ the valve
hi thanks for the question. A small tube goes in the ice maker it directs the water in the tray .Some times it will freeze up . check that if not frozen the ice maker water valve is the source of the problem thanks the appliance doc
Sep 29, 2008 | Whirlpool Refrigerators
Icemaker and water
Check to see if the line valve to the fridge is open. It should be at the nearest main water source (Kitchen sink)
Jul 25, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
61 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
