Question about Pentax ZX-7 QD 35mm SLR Camera
Pentax AX-7 does not take picture
After getting low battery indicator, I replaced with brand new batteries and then was able to take 4 pictures and immediately after 4th picture I could not get it to shoot another picture. It focuses and appears to lock the image, selecting a picture mode but the shutter appears stuck as the shoot button does not trigger a shot. Is this film related or camera? Thanks, David
  • Pentax Master
  • 5,412 Answers
If you just put in standard AA batteries, they do not have enough power to drive the camera. Use high power ones, or better still 2300 mAh or 2500 mAh rechargeable batteries
Posted on Aug 27, 2017
jackboy
  • 2985 Answers
SOURCE: Shutter wont' release
Well either the relase switch has failed or another projection device has stalled it. Check through you menu of the back screen to be sure and then call Pentax technical support on thier web site.
Posted on May 27, 2007
poolseman
  • 206 Answers
SOURCE: Pentax zx-50 Shutter Problems?
I really think this is the classic zx - 50 shutter motor problem : small motor on the side of the mirror box is not cocking the shutter . This is very repairable but unfortunately it requires fair amount stripping down of the camera to get to the fault and so you will have to take it in for repairs.
Posted on Sep 03, 2007
CameraRepair
  • 60 Answers
SOURCE: Sticking shutter/unable to advance film
Probably. That camera has several rubber bumpers and gaskets in the mirror mechanism that have a tendency to turn into sticky gooey sludge causing the levers in the shutter and mirror mechanisms to get sluggish. The only real solution is to completely disassemble the camera to clean out the old goop and replace them with newer neoprene fittings. My suggestion would be to find a replacement body since the repair is probably going to cost between $80 to $90 and you can probebly find a good used body for less than that.
CameraRepairs
Posted on Aug 11, 2008
Ostewart2102
  • 41 Answers
SOURCE: Mirror locked up
Older cameras like this are notorious for locking up after not being used for quite some time. Though, it is an easy fix, it does require some steady hands and a good memory of where everything was after you're taken it out or apart. The best solution for this is, once you've taken it apart and have access to the mirror, is to have a q-tip with a little vasoline on the tip, apply a thin (very thin) layer along all springs and joints surround the mirror and around the edges of the mirror opening, while avoiding getting any vasoline on the mirror itself. I've worked with cameras all my life and have worked at camera shops, and what I've explained here is exactly what a camera repair place would do. But, if you don't feel comfortable with small parts and tiny screws, a camera shop will gladly fix it for you, and not at a bad price.
So, Good luck! Hope this helps. I hope you're out taking photos soon!
Olivia~*
Posted on Dec 01, 2008
  • 185 Answers
SOURCE: shutter
kirstyanne00,
open the film door and check the shutter blades. did you accidentally push the blades in when loading the film? if so take the camera to a camera repair shop, the technician may be able to reset the blades while you wait.
or send it to pentax repair center for an estimate cost to repair.
Posted on Dec 11, 2008
I have a Pentax ZX-7 camera that takes awesome pictures. About a year ago is the last time I was able to take pictures though, as now the camera is not working. I can turn the camera on and the modes...
Clean the battery contacts with a soft rubber pencil eraser. It doesn't take much corrosion -- due to moisture, or skin oil deposited on the posts -- to create resistance enough to keep the camera from getting a full supply of power.
Apr 20, 2017 | Pentax ZX-7 QD 35mm SLR Camera
I have a Pentax K100D and occasionaly when I push to button to take a picture it does not work. I have to turn off the camera and then try it again. It is in Auto mode. Is this a "fixable issue"...
When this happens, does the battery indicator show no battery power? If so, this is a common issue and most owners check the battery indicator first before snapping and if it shows empty, they do the "turn off/on" routine. The newer cameras (K7, Kx, Kr,K5) do not seem to have this problem.
Nov 11, 2010 | Pentax Cameras
Battery indicator reads empty when batteries are fully charged
It looks like your question was cut short... all I see is "Battery indicator reads empty when batteries are..."
With my experience with the Pentax *ist DL, I think the problem is probably that brand new batteries still show "empty" on the indicator.
Chances are that you are not using the CR-V3 camera batteries in your *ist DL. I have tried 2400mAh NiMH rechargable batteries and brand new alkaline batteries in an attempt to save money.
Neither lasted anywhere near as long as the CR-V3 batteries! While you may be paying $15-$20 for two CR-V3 batteries, they last a LONG time!
One of the advantages of DSLRs (and digital cameras in general) is that you save money by no longer buying film and paying for developing/prints. But, even at $20 for two CR-V3 batteries, I save money! I am able to take several hundred photos on a pair of batteries (I think the manual says 500+) instead of $10-$15 ($2-$7 for film + $8 dev/print) for every 24-36 photos!
May 29, 2010 | Pentax *ist DL Digital Camera
My camera indicates that the batteries are low and won't power on. But, when I put new batteries in, it still indicates low battery. What can I do?
Chances are that you are not using CR-V3 camera batteries in your *ist DL. I have tried 2400mAh NiMH rechargable batteries and brand new alkaline batteries in an attempt to save money.
One of the advantages of DSLRs (and digital cameras in general) is that you save money by no longer buying film and paying for developing/prints. But, even at $20 for two CR-V3 batteries, I save money! I am able to take several hundred photos on a pair of batteries (I think the manual says 500 ) instead of $10-$15 ($2-$7 for film $8 dev/print) for every 24-36 photos!
May 09, 2010 | Pentax *ist DL Digital Camera
Pentax k200d BATTERY PROBLEM
The battery charge indicator is temperature sensitive. If you switch off and on again, do you still get the low battery warning? Have you tried with a second set of batteries - either rechargeable, or lithium or alkaline. I would do this in a warm room, and try it with new alkaline cells. You lose some of the functions, but if the indicator say charged, and you can take a shot, then the body is OK.
Call me old-fashioned, but I use a multimeter on all NEW batteries to make sure they are functional - I bought a card of cheap LR44s and the first three were either dead or low on voltage.
Oct 25, 2009 | Pentax K200D 10 Megapixel Digital SLR...
My pentax camera keeps
I thyink there is a recommended brand for this camera and they should be Duracell.
Sep 02, 2009 | Pentax Optio 50 Digital Camera
The camera we purchased won't take more than 4 0r5 pictures before it says low battery and won't take more pictures. recentlu when we put in new batteries it says low battery.
You did not say what kind of batteries you are using. If they are AA rechargeables they need to be recharged if they havenot neen used for a while. Say if you took 4 or 5 pictures, the batteries died, you charged them but did on use the camera again for several weeks. When you do they will be dead again, that in the nature of rechargables, they lose charge just sitting there. Solution find the Sanyo Enteloop or Rayovac Hybrid brands, these next generation rechargables have a shelf life similar to NiCads.
Jul 23, 2008 | Samsung Cameras
Low battery indicator
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Jun 17, 2008 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
Won't take pictures after batteries died
no u can't do that stupids never take out tha card now u messesd up big time sorry
Nov 12, 2007 | Fuji FinePix E510 Digital Camera
Pentax ZX-7 QD 35mm SLR Camera Logo
600 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
