My living room a.c sparks when i put it on cold
Well when i cut my a.c on high fan it runs good but when i set it to cold for some reason it sparks in front of the control panal i opened up my a.c and found the problem that was causing the sparks i just want to know where can i order the fuse# cera-mite b11416-71 9934 its a blck round fat fuse where the power runs from one side to the other any help will b healpfull its getting hot out now and i want to stay cool u get what i mean lol
    Problem Solver:
  • 6 Answers
Check at wholesale supply or rodens. you have other problems if it sparks. maybe compressor.
Posted on May 22, 2009
Eco Quest Living Air XL 15S Classic Air Purifier Cleaner Ozone Ionizer USA
Ozone is not good for you. If you can smell it, it is set too high. Look at it in dark room and check for blue orange glow inside the fan louvers. If you see the glow, it is working
Jan 10, 2017 | Air Air Purifiers
Fan on outside unit cuts off for an hour or so while unit should
Hello Rett Check the fan selector switch setting on the thermostat.It should be set to AUTO position instead of ON.
Jul 15, 2010 | Heating & Cooling
Clockwise, counterclockwise which is the summer setting?
Ceiling Fan Direction These recommendations depend actually on the height and size of the room; the season; and the activity taking place in the room.
The basic fact of nature is that warm air rises to the top and cold air settles on the bottom. Air settles in layers from warm at the top to cold at the bottom, if left alone at equilibrium.
Ceiling fan recommendations:
In the winter
Set the fan to run counterclockwise (reverse; this looks clockwise as you are looking up). This will redirect the warm air from the ceiling and down the walls and into the living space where the people actually are. In a house, you would run the fan at a low speed so that you don't actually cool the warm air that you are moving downward. If you have a high ceiling, or are trying to heat a hall or a church, you may want to increase the fan speed so that the warm air will reach the living space as long as the fan speed does not create an unwanted downdraft at the people below. In the summer
In a room of normal height (8 - 10 ft), you should operate your fan so that it turns clockwise (this looks counterclockwise as you are looking up), causing a more directed downdraft, especially with the fan running slightly faster. This causes a wind-chill effect because the skin evaporates slight amounts of water from the sweat glands and thereby provides cooling through the skin's surface. However, the air is only moved but not cooled! You may find that you can turn your thermostat down a degree or two and save more money on energy costs. The air blowing down won't actually cool the room though, so you should turn the fan off when there are no people (or animals) in the room. In a high hall or church
It may be best NOT to run the fans at all in summer. This lowers the demand for cooling since the hot layer on top is an excellent insulation between the cool air near the floor (and the people) and the hot roof and outside.
A large, tall manufacturing hall would typically have different goals. There one would have a floor full of heat producing machinery plus the people operating it, working hard and welcoming a bit of a breeze. Then it would make sense to run the fans at fairly high speed to create a certain and directed downdraft. And with the shifts going throughout the days of the week, the fans should be running all the time and maybe in all seasons.
Finally, fans typically use 80-100 watts. When used properly, ceiling fans can really help to optimize the comfort level of the people and save energy and money.
Good Luck and please rate 4 thumbs up for the free answer
Jun 13, 2010 | Hampton Bay 13087 70450 Carousel II...
I have a HP M1270N Media Center PC. The CPU Fan
The CPU fan is designed to run constantly to prevent the CPU from overheating. The speed depends on temperature condition of the room; slow in cold and fast in a hot room. However if you suspect that it runs too fast them try re-seating the CPU. WARNING: Re-seating should only be done if you are know how to do; don't experiment.
If it is running noisy, you can apply one or two drops of machine oil to the fan's spindle.
Other reasons include deposits of dust; use a blower to remove dust from the heat-sink.
To make sure you CPU is not in a critical state, log in the BIOS and in the hardware monitoring tab check the CPU temperature. It should be near 60 deg Celsius or 140 Fahrenheit.
One thing more, do not apply thermal grease in excess; its a conductive compound and can short the motherboard if it melts and deposits on the motherboard due to high CPU temperature.
May 25, 2010 | HP Media Center m1270n (PP132AA#ABA) PC...
Brought new tv for bedroom freeview inc..set up
If you have got a good aerial, the high gain type- see image, it should run all the TV's you say. Make certain you have decent cable coming off the aerial (the stuff they use for satalite dishes). Then buy some high quality splitters, to feed the TV's. Don't split the cable outdoors!
Jan 25, 2010 | Televison & Video
Vegetable draw is getting too cold and freezing contents,
Good day,
Seems to be a common complaint when colder weather sets in.
This problem seems more acute when the rooms cool down, and the machine gets light usage.
The main reason, is the machine stays off for longer periods of time and the air stratifies in the fresh food compartment.
That is, the cold air tends to settle to the bottom of the compartment when the machine is off and the circulating fan is not running.
recommendations are to set the thermostat to a warmer setting..
Sounds good, however, there are techs who recommend setting it to a colder setting, to keep the fan running more frequently.
I know it sounds ludicrous, but it's primarily the result of trying to keep one compartment at 0 degrees and another at 37 degrees using only one compressor and one cooling fan.
Many years ago, many refrigerators had 2 fan motors, one for each compartment, and 2 thermostats. These machines never had this problem.
Dec 05, 2009 | Kenmore Refrigerators
The a/c keeps cutting off before the room gets cold. The fan stays on but now cold air.
check the timer settings on the control. they may be set to something you may not wish to be set..
Aug 29, 2009 | Heating & Cooling
Water not shutting off to begin wash cycle flooded room
Probably one of the water cut off solenoids not shutting off.
Do you use both hot AND cold water?
Try using only cold water first. If that works, maybe hot water solenoid is faulty.
Next, connect cold water to the HOT inlet, and try it again. This means you have now tried each of the solenoids, and maybe identified which one is faulty (assuming thats the problem!). If water wont cut off after trying this, the problem will be with whatever level sensing device it has, but I am not familiar with the model you have, so cant help there. Good luck.
Jun 01, 2009 | Washing Machines
Controller (s) not working
Someone used the pull chain on both units. Whenever you install a remote or wall-mounted dimmer, it's always best to cut the chains short (after setting the fan to high) to prevent someone who doesn't know any better from using them.
Download the installation sheets here:
http://www.lutron.com/cms400/PageBuyNow.aspx?id=16977&mn=1815
May 15, 2009 | Maestro Fan/light Dimmer Ma-lfqhw-wh...
Just a little question, guys!
The blower has absolutely nothing to do with outdoor air. Having the T-Stat set to auto lets the blower come on only when the A/C-heat comes on. With the switch in the ON position the blower simply runs all of the time. Depending on your living space (high ceilings, multi-level) having the blower on constantly while costing a small amount to run can actually save some money and make you more comfortable in the summer. However most people will leave it in auto in the winter so they don't feel as if they have a draft from the air movement as the blower is in high speed in fan on position and cool modes and low speed in heat mode. Many furnaces today are equipped with a setting that allows the blower to run constantly at a lower speed or simply run for a min. or two after the A/C=Heat have turned off.
Jan 17, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
