Question about E-Machines eMachines Desktop PC
Black screen on my desktop, and connect pins are broken & bent
My Emachines T2245 desktop computer when I press the power button on the CPU the pc will boot up, but my monitor screen is black. No Emachines screen or Windows XP screen and I am unable to get to my Windows XP desktop or my start menu. I can't see anything it 100% black. Yesterday, I had carry-in my CPU to Best Buy and GeekSquad did a System Analysis, the tech told me the motherboard and the modem is working propertly. When I check my monitor cable cords. I seems like the connector pins are bent or broken. Could this be the cause of me not be able to get to my Windows XP screen?
  • 112 Answers
You'll get either no signal or missing color(s) if pins are bent or missing.
Carefully bend pins back with small needle-nose pliers. Pin 9 is missing by default - if any other pins are missing or broken, you'll need an expert to wire a new VGA plug.
Posted on May 22, 2009
Emacnine monitor is 100% black. I bought a new monitor and its not receiving any signal. Can you help?
Posted on Jul 20, 2009
  • E-Machines Master
  • 5,660 Answers
Geek Squad! lol! (Sorry, I don't have much faith in them) If they did a 'System Analysis', they could have just plugged in a monitor, and seen if your monitor was the problem! YOU can too!
(They should have told you that your computer was fine, and plugging a good working monitor in, is all you need)
Yes, bent, and/or broken pins in a monitor cable, will result in your findings.
Computer off, and unplugged. See if any broken pins are present in the VGA connector on your motherboard. These need to be removed, if so.
This is a photo of a VGA connector,
http://en.wikipedia.org/wiki/File:VGA_port.jpg
(If the above link doesn't work for you, go here,
http://en.wikipedia.org/wiki/VGA
Top right photo -> DE15F- VGA Port)
If your monitor cable pins are broken, and it is attached directly to your monitor, this cable will have to be replaced by a pro. This is the pinout for
a VGA connector,
http://pinouts.ru/Video/VGA15.shtml
If no pins are broken, you can try to straighten them out. Use CAUTION, as bending them too far, or too much bending back, and forth, will break them off! I use a mechanical pencil, (Like an EverSharp for example), with the lead removed.
It fits over the pins nicely! Move slow, and ease the bent pin back to a vertical position.
  • E-Machines Master
  • 5,568 Answers
All modern monitors will display some kind of screen in the absence of an input signal. Unfortunately, you didn't include the make/model number of the monitor itself but those supplied with eMachines systems will display a message telling your that the monitor is OK but not receiving any input signal. Leaving the video cable disconnected should cause the message to appear, sometimes after a delay but generally immediately. Pressing the 'Menu'  button on the front panel of the unit should also cause a display. If you are not getting any display, the monitor itself has probably failed.
If you have a small portable radio, tune it across the AM band while holding it close to the monitor. This should create a good bit of static if the high voltage (horizontal) circuit is running. If it isn't, the monitor will remain black.
I have black screen in my computer, whats the problem?
There is a button in ur keyboard for projector / TV press the button and your screen will come.
You may have to press the function key and that button together. That button usually stay with the F keys
Oct 31, 2014 | eMachines E442 E442-v133 15.6" Notebook...
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
The yellow power led light blinks on front of the emachine w2646. The CPU Fan works. The power button will not turn the PC on or off, you just have to plug in the power cord to turn it on. The monitor just...
Did you flash the main board ??
1.) remove battery
2.) press and hold the power button for 10 - 30 seconds
3.) replace battery.
4.) when the system boots it will say press XX (e.g F2) to load defaults and continue ,, press that key.
It could also be the power button is stuck!.
find were it connects to the main boad and unplug it
bridge the 2 pins it jacks into to turn the computer on. if it works u will need to replace that button or the case.
Feb 26, 2010 | E-Machines eMachines Desktop PC
I have a emachines t2984 i press the power button and doesnt turn on i replaced the power supply with different ones and nothing and the light turns on (power button) but the when i press the button the...
Ok, test the power button pins. First disconnect any power source to the computer. Then, find the power pins on your motherboard (the one that your case's power button connects to. Usually two wires, one red and the other black). Grab a jumper a connect it to those two pins, they usually have the letters "pwr" or "power" printed next to them. Then, once you've done this, with the jumper connected, connect the power cord to your power supply. It should turn on by it self. If it does, then the problem is the power button. If it does not do it, then the problem is the motherboard. Good luck.
Jan 22, 2010 | E-Machines eMachines Refurbished EMA...
My computer says no signal
Check you rmnitor data cable from CPU its not connected
Oct 05, 2009 | E-Machines eMachines W2686 PC Desktop
The PSU fan does not run, computer shutsdown.
Check the CPU fan, it may be faulty and causes the CPU to overheat and shut down.
Sep 02, 2009 | E-Machines eMachines Desktop PC
Monitor only has a black screen, when i turn it on the power button turns from blue to orange and the screen says no signal and then turns black
First open cpu cabinet Refix RAM memory .
Then pull cmos cell from motherbord for 10 minutes so all settings are defaults.
Then when power up the computer press F8 key then enter in enable vga mode.
Then go to control panel and display proeprty then settings change screen resolution to 1024*768 then apply and ok.
Then restart the computer.
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | E-Machines eMachines Desktop PC
I have similar problem on an eMachines W1500
Thats your powersupply cable. look for a 4pin sloth on your mobo that looks kind of like that switch and plug it in
Jun 16, 2009 | E-Machines eMachines Desktop PC
Emachine W2047 No BIOS Start Screen
You can test the power button. Remove the wires from the power on pins on the motherboard. Momentarily jump the two pins with a small screwdriver. If the computer starts the power button is bad. If it still doesn't start then something else is wrong. Did you test the memory? Also do all of the fans work, especially the CPU fan? It can't hurt to test with the other PSU. You know the HDD is good. Test one piece of hardware at a time and hopefully you will find the problem.
Jan 07, 2009 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
339 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
