Question about NetGear WGPS606 (WGPS606NAR) Print Server
Connectivity I am having a problem setting up my WGPS606, Netgear wireless print server. It was connected to my WNDR3300, netgear wireless router and 4 port switch. I could not tell you why it stopped working. I can run the print server utility and it can see my network I do put in my 64 bite WEP key but it will not connect. I did take down the protection (WEP) on my network but that did not work. I have verified the WEP key many times. The router is running both G and N band networks and I have changed the channels on both incase it is interference. No luck Any advice?
  • mwheelock May 22, 2009
    no IP conflict. It does not even get to that point. Thank though
  • 112 Answers
Perhaps an ip conflict. If so, assign server an ip outside of normal client range.
Posted on May 22, 2009
Wireless connection with a wireless router (Netgear WNDR 4000) a pc and a laptop.
I assume you connect your printer to the desktop with the USB cable.
I assume the laptop is connected to the Wifi network.
First you need to setup the printer to connect to the wireless network. Follow the printer installation instructions to do that.
Next insert the install Disc into the laptop and follow the installation instructions. Use the network installation section.
The printer has a built-in server for printing.
If UPNP is enabled on the router then you should be able to browse the printer on the network.
Sep 30, 2017 | NetGear WGPS606 (WGPS606NAR) Print Server
Security key passphrase for netgear
Your wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
May 07, 2010 | NetGear WGPS606 (WGPS606NAR) Print Server
How do I connect with my WGPS606 if there is no setup cd and the default ip does not work? My router has encryption and the WGPS needs the info.
you need to set your print server for dhcp, you need to log in and verify the settings OR just set it back to default because dhcp is default. gl
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Nov 06, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Hi there, can I use the WGPS606 as an AP ? Many Thanks
I understand that you want to use the print server WGPS606 as an access point. Regarding the concern, please note that it is not possible to configure or use this device as AP. This device however can act as as wireless bridge. It can connect wirelessly to the wireless network of your wireless router/ap and provide wired connection.
Hope this helps.
Sep 24, 2009 | NetGear WIRELESS PRINT SERVER 54MBPS...
Connecting the WGPS606 to Dell AIO 962
Try installing a lower end printer to the same port. For example HP LaserJet 3.
Mar 30, 2009 | NetGear WIRELESS PRINT SERVER 54MBPS...
Can't connect WGPS606 wireless printer server to cable router
suggest plugging print server directly into p.c via blue ethernet cable during setup. Then run setup program and then pick an ip address that works with your router (in same network ip range of router) that does not clash . I would use print server as a switch if it is close to the router by ethernet cable between router and wireless print server. Then both should work
Wireless to server and other wired computers as well .
Feb 06, 2018 | NetGear WGPS606 (WGPS606NAR) Print Server
Installation assistant cannot detect print server
Results of attempting to connect the Netgear Wireless Print Server WGPS606 and the Canon MF6550 multifunction laser printer. I was on the phone for several hours last evening (March 9, until about midnight EDT) with a very competent support agent from Netgear (actually in the Philippines). The Netgear setup Wizard software would not connect the Print Server to my Verizon FiOS wireless G router automatically, so the Netgear support agent walked me through it manually. The Print Server connected that way, for sure. Then we manually attempted to connect the Print Server to my Canon MF6550 and subsequently, my HP 932C Deskjet. Neither printer is on the WGPS606 compatible list, nor is either on the known incompatible list. Now we know - both printers are INCOMPATIBLE with the Netgear WGPS606. I bought both the Netgear Print Server and the Canon MF6550 at Staples on Sat., March 8, 2008, based upon the assurance from Staples staff that it would all work. The question now is whether ANY brand of wireless Print Server will work with the Canon MF6550, or do I have to return this printer and get either a Canon with built in networking (ethernet or wireless) or switch to the Brother equivalent (MFC 8870DW). If I get a (multi-function) printer with built-in Ethernet networking, does the Ethernet capability bypass the USB incompatibility problem, or will the problem remain?
Mar 10, 2008 | NetGear WIRELESS PRINT SERVER 54MBPS...
Printer server, wireless, detached cable now won't print
It is because the WiFI connection is more than likely on another IP address ie: Cable:192.168.0.1 type thing. WiFi:10.1.1.1 Type thing... so ya have to configure ya access and point ya printer in the right direction, so reinstall ya printer & driver and when it asks where the network printer is, point it to the correct address of the router's port..
Aug 08, 2007 | NetGear WGPS606 (WGPS606NAR) Print Server
Open Questions:
NetGear WGPS606 (WGPS606NAR) Print Server Logo
213 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
