Question about Dell Latitude C840 Notebook
Can't turn on SVGA Output
Using SVGA output on Dell C840. How do you turn on the SVGA output on the Dell C840?
  • homeworkshan May 23, 2009
    I tried the fn-F8 toggle. I don't have a monitor plugged into the VGA port and I'm not able to specify anyting but a plug-n-play monitor in control panel for the second monitor. As soon as I try to toggle, the LCD goes blank for about 2 seconds then comes back on. Do I have to have a monitor plugged into the VGA port?
  • Dell Master
  • 4,806 Answers
Hi there.
The keyboard toggle keys are Fn-F8, that should switch to external monitor.
Please post back with the results and for any additional advice.
Good luck and thanks for using FixYa!!
Posted on May 22, 2009
  • Lee Hodgson
    Lee Hodgson May 23, 2009
    H there.
    Yes you do need to have the external monitor plugged in to the VGA output to switch screens, you can't specify a secondary monitor until thats done.
    Good luck
Hi i'v bought a LG LD 310 lcd tv and i want to
I tried this.. and it works perfect for the video.. but there is no audio.
Is there any specific setting to be made in TV or my laptop?
I have Dell laptop with Win7, because I dont see any option to enable audio..
Aug 01, 2011 | LG Televison & Video
Adapter does not chanrge
make sure its plugged in correctly and the wall plug is plugged tightly. I had a Dell C840 when the
charger got power it had a green diode that lit up. You could test your power supply with a volt ohm
meter. if the VOM is not showing any power coming from the power supply (assuming you have the
VOM setup to match the power output of the power supply) then the power supply is probably bad.
If it works then it could be the computers connection or battery.
May 14, 2011 | Dell l 1X917 310-2860 DA65NS0-00 DF261...
How to connect my pc to my tv & use it as a monitorbaxterstead000@hotmail.com
-get a vga cable(usually both ends are male) - connect it to the vga port on the laptop then the other end to your tv -press fn+f2 to switch the display to your tv( this is model/brand dependent, check your user's manual for more info)
Oct 23, 2010 | Computers & Internet
Cursor jumps while using touchpad.
> try to go to touchpad properties,you will be able to see there an option for tapping,you will be able to see there an option where you can turn off tapping while typing
Jun 21, 2010 | Dell Latitude C840 24X CD-R W/ DVD Combo...
How to turn my wifi on on my dell latitude c840?
most dell laptops you hold the FN and F1 button down the outher way is go into Network Connections right click on the wireless and then enable hope this works.
Dec 29, 2009 | Dell Latitude C840 Notebook
Can I go from VGA to SVGA?
If the question is can I convert my composite video output to a super video input then the answer is NO,
The composite is coaxial (2 wires) the S-Video uses 4pins and there is no S-Video output on a Presario 1200 laptop.
You can however use a Multi-AV SCART adaptors with Input/Output signal switch where you plug in the composite video output into the top video and 3.5 mm jack stereo audio into the mono audio connections on top.( via a stereo to mono cable)
http://upload.wikimedia.org/wikipedia/en/thumb/a/a7/Multiconnector-scart-chti.jpg/200px-Multiconnector-scart-chti.jpg
Hope this is the answer you are looking for !
Sep 27, 2009 | Compaq Presario 1200XL103 (155726-163) PC...
Does the dell dimension 2400 has an output to connect the to tv
You will either need a new video card with a compisite (yellow connector) or a s-video connector (looks like the end of a mouse), or somthing called a scan converter. Either of these products will allow you to use your telivison as a monitor for your computer. The last option is to get a telivision with a monitor connection on it. They are called SVGA connectors. If you go this way, you will need a Male to Male SVGA cable. Good Luck!
Jan 29, 2009 | Dell Dimension 2400 PC Desktop
Laptop to TV
I dont believe that you can hook that model up to a TV you have to have a certin video output and it also would depend on your tv as well. But i am about 100% sure that series does not have the output you need you usally can connect via S-cable
Dec 04, 2008 | Dell Inspiron 2200 PC Notebook
Setting up S video out on Dell Inspiron 8200
I do this all the time with my ATI powered laptops... Right click the desktop, select properties, choose settings then advanced. You should have 3 screens. Laptop, Monitor and TV (I only get 'multiple monitors' no matter what I try...) You must have it connected before it will allow you to 'activate it' Once its activated theres a place for you to click to make the s-video / tv output your DEFAULT... Keep in mind that with some media players (windows for example) the movie image will only appear on the default screen- the other screen will be blank. So if you are intending to record to your VCR make sure that your TV is the Default.
Dec 31, 2007 | Dell Inspiron 8200 Latitude C840 Laptop...
Dell Latitude C840 Notebook Logo
161 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
