Question about Ovens
Maytag elect. wall won't bake nor broil
The oven worked perfectly and all of a sudden one day the heating elements will not heat. The control panel display seems to work fine  and give no "warning" signal. clock works and oven-lock safety control works. Any ideas? Is there a fuse that just works with the heating rods? Thanks for your thoughts. - Rich
  • 323 Answers
Hi Rich,
The oven runs off 240 volts and normally a small 120 voly circuit is run off one of the 120 volts legs. However, this is not always the case and once in a great while there is a separate breaker for the things you mentioned above.
I would check the breaker box and determine that no breakers are tripped. The big double breakers are the 240 volt ones and are used for the range, the dryer, A/C, etc.
If one is tripped it will not be off but about half way between off and on. Turn it completely off (they are stiff) and then all the way back on. If there is no breaker tripped, turn the power to the oven off and examine the heating elements inside the oven.
Sometimes they break away from the connection that comes out of the oven wall. Sometimes there is a hole in one. Check both the upper and the lower. If they look okay, there is little you can do at this point unless you are well versed in electricity and 240 volt appliances.
You will have to call either an appliance technician on a service call, or an electrician. I'm assuming this is a slide in unit and not part of a free standing range.
Good luck,
Sirwriter
Posted on May 22, 2009
  • 11,896 Answers
I suggest checking the voltage going to elements. If there is no current, trace wires. Not exactly sure if there is a fuse/relay on your model. If there is current, than the elements may have gone bad.
Maytag Oven. The bake do not heat, the broil is ok. what is the problem ?
Look at the wiring diagram... The manual reset Thermal Limiter Switch (part number 74008715), located on the lower rear insulation retainer can keep both elements from working, not one at a time... I would inspect the back of the bake relay for a burnt/failing solder joint. Swapping the BAKE and BROIL leads is an acceptable test, but if you put the bake leads on the broil and still get no heat: check the control relay. If the broil leads will not heat the bake element, you have a bad element or bad connection. Be sure to do all testing of the elements with at least one wire detached so as not to red a back circuit.
Jun 19, 2016 | Maytag Ovens
Maytag oven won t heat up
the upper element only comes on when you broil or clean with selfcleaner. the bottom comes on when you are baking, it sounds like your bottom element is bad.
May 07, 2014 | Maytag Ovens
Oven
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas.
Apr 07, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Baking & broiling elements won't heat after baking element burned out and was replaced.
the surge from the original element burning out has destroyed the control board if you can't hear the relays on the board clicking when you power up the elements bake or broil then its either the low voltage side of the board,if you hear clicking then the relays are working but the contacts are burned out and can't pass the current to heat the oven or briol elements
Jan 04, 2013 | Jenn-Air Ovens
I have an 8 yr old thermador scd302 double wall oven. Top oven started not heating up (wouldnt go past 240), but then worked a couple of times. Now it just stays at 100. Broil and convection do not work...
THINGS TO CHECK:
the broil element
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start Oven Won Turn on
May 23, 2011 | Thermador Ovens
I have a Fridgidaire Model # PLEB30S8CCC wall oven. The broiler works fine. The oven is very slow to heat up, 20 minutes to reach 250. I checked the lower element with a omp meter it read 20. Is that...
Hello there and than you for choosing Fixya
If your oven does not heat, does not heat enough or does not broil, a common cause is a burned out heating element. There are two elements, the baking element on the floor of the oven and the broiling element on the ceiling of the oven. They are about the diameter of a pencil and typically supported by metal stand-offs.
This easiest test you can do is to turn on the oven and observe the heating element. If it glows red, the element is working. When baking, the broiling element may come on to assist with preheating or to maintain the oven temperature. When set to bake, if the broiler comes on, but the baking element does not, the likely cause is a burned out baking element.
When set to broil, the broil element should glow red, but the bake element typically is not used. If the broiler does not glow, it is likely a burned out heating element.
There are other possible causes of these symptoms, refer to our diagnostic page for some other possibilities.
To test the heating element using a multimeter, follow the steps provided below.
  1. Unplug the oven or turn off the power at the breaker or fuse box.
  2. Follow the heating element back to where it goes through the wall of the oven. Remove the bracket that secures the element in place.
  3. Unscrew or unfasten any stand-off supports that secure the element to the oven.
  4. Pull the element part way out to expose the oven's wiring connected the element.
  5. Label the wires and secure them in place so they do not fall back into the cavity.
  6. Disconnect the wires from the element.
  7. Using a multimeter set to x1, touch one probe to each of the element contacts. Expect resistance in the range of 20 to 40 ohms. Infinite or kilo-ohm resistance usually indicates a bad element and it should be replaced.
  8. If the element tests okay, reconnect the wires, slip them back into the cavity and resecure the element.
Jan 26, 2011 | Frigidaire Ovens
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
Ge wall oven will not heat up on bake,boil or clean cycle
GE JKP86BF3BB COMBO MICRO/ELECT OVEN
NO HEAT ON BROIL OR BAKE ELEMENTS
CKD WIRING FROM PANEL OK
CKD TERMINALS AT ELEMENT HAVE 120V ON EACH ELMT
FAN COMES ON
THE ON INDICATOR SHOWS WHEN TMP &START PUSHED
MICROWAVE WORKS FINE
I ORDERED A NEW BAKE ELEMENT TO TRY-NOT HERE YET
STUMPED
Mar 16, 2009 | GE JTP15 Electric Single Oven
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
Ovens Logo
157 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
