Question about D-Link DI 514 Wireless Router (DI-514)
Link 1 lit up and no more connection to internet
D-link DI 524 Router: Led on link 1 is lit up, but nothing is pluged in! When I plug ethernet cable to this port I can not connect to my router. Or other eth. ports seems to be ok! Any Solution? Today also I lost my internet connection over this router. I was connectin to a local provider over PPTP, but from today it does not work anymore. I called m provider and they say that everything is perfect on their side, and that they even can see my router. I really do not kno what to do! :((( Those two problems are with high possibility related! Some things i did but did not help: Upgraded Firmware Replaced Eth Cables Reseted Router Now I am online over my network card which MAC is also registred by local provider and it works! Please Help! I have 3 more computers that must be online! :(( THanks
    Problem Solver:
  • 3 Answers
You may have been hit by lightning or power surge which knocked out one or 2 ports. If the WAN port is out you may still be able to use your router as a hub provided your modem can be configured as a router (many newer ones can) . Connect one of your working LAN ports to the modem and others to your computers.
Posted on May 22, 2009
Dlink DI524 wireless problem: cannot access the router
If the Router is new proceed to Step 1. If the Router is used power on and press and hold the Reset button for about 10 seconds. It is located next to where the power cord is plugged in. Use either a pen or paper clip to push reset button.
Step 1. Connect one end of an Ethernet cable to the Ethernet port located on the Cable / DSL modem and the other end to the WAN port on your D-Link DI524 wireless Router. The WAN LED light will illuminate to indicate proper connection.
Step 2. Connect one end of an Ethernet cable to LAN Port 1 on the back panel of the DI-524 and the other end to the network adapter in the computer you are using to
configure the DI-524. The LED light for LAN Port 1 illuminates to indicate proper
connection.
Step 3. Once all pieces ar connected. Open your Web browser and type http://192.168.0.1 into the URL address box then press ENTER. Once the log-on pop-up screen appears type admin for the user-name and leave the password blank then click ok.
Step 4. Once you have logged in, the Home screen will appear and you should see a box called RUN WIZARD in the middle of the screen. Click that box and follow the steps.
Setup Step 1 - Click Next
Setup Step 2 - Create Password and click Next
Setup Step 3 - Choose Time Zone and click Next
Setup Step 4 - Setup wizard will try to auto-detect your Internet connection type.
Setup Step 5 - Select your Internet Connection. You will be prompted to select the type of Internet connection for your router. More than likely it will be Dynamic IP Address. Click Next.
Setup Step 6 - Click the “Clone MAC Address” button to automatically copy the MAC address of the network adapter in your computer. You can also manually type in the MAC address. Click Next.
Setup Step 7 - The default wireless settings for your 802.11g wireless network are: SSID = default Channel = 6. You can change the SSID name to whatever you like. This will be the name of your wireless network. Click Next.
Step 8 - If you wish to use encryption for your 802.11g network, the DI-524 is capable of two levels of wireless encryption - 64-bit and 128-bit. By default the encryption is disabled. You can change the encryption settings for more secure wireless communication. If you choose to use encryption, you will need to write down the encryption key so that you can connect your laptop or pc via wireless connection. Click Next
Setup Step 9 - Your is complete. Click Restart to save and reboot your router.
Setup Step 10 - Click Close to complete your setup.
Setup Step 11 - You will be returned to the Home tab. Close this window and wait for the Router to finish rebooting. Then relaunch your Web browser (i.e., Internet Explorer or Netscape Navigator), to link to your favorite Web site to test your Internet connection.
Here is the link to download all the necessary info to configure your router - http://www.dlink.com/products/?pid=DI-524&tab=1
Jun 21, 2009 | D-Link AirPlus DI-524 Wireless Router
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
I cant connect my laptop to my DI-524 router after I reset router
To configure wireless:
1. Open browser, type "192.168.0.1" under the URL and press Enter
2. Username & password will be prompt
Username = admin
Password = by default is empty
3. Once entered inside the router config, on your left u can see a wizard tab, just click on it and follow the on screen instruction.
Mar 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Di-524
- Update the firmware of the router.
Feb 28, 2009 | D-Link AirPlus DI-524 Wireless Router
DI-524 WAN LIGTH
ensure that the electrical plug is intact, if you saw no led light lit at all on all indicator check the adaptor itself, if you have a tester you can try to test the end connector to see if there is a DC power line that is coming out.
if not either the adaptor is defective nor the reouter itself is burned out
Nov 27, 2008 | D-Link AirPlus DI-524 Wireless Router
DI 524 and airport express
Yes, that is possible for as long the DI524 is already properly setup and can provide already internet connection everything should be working fine there....
Nov 10, 2008 | D-Link AirPlus DI-524 Wireless Router
Cannot connect to internet through DI-524
After you've rebooted your wireless router...make sure you reboot the cable-company (or DSL) modem while the router is connected to it and on. The modem seems to recognize the router properly only in this way.
Simply unplug the power to the cable-modem and plug it in again.
If the cable-modem has a battery back-up you'll want to remove that as well.
Feb 24, 2008 | D-Link AirPlus DI-524 Wireless Router
Connecting a DI-524 to a DI-604
This shouldn't really be any problem simply use a short "Uplink" ethernet cable to join the routers thru the uplink port, or any port really, and that way ya should be able to wifi and access the net, set ya router that connects to the net for DCHP and disable that setting in the Wifi router and ya should be good to go?
Jan 30, 2008 | D-Link AirPlus DI-524 Wireless Router
No internet connection through router D-Link DI-524
-Connect your router to the wall and connect your laptop to the router using a cable.
-Use Internet Explorer and type the following line in the address bar: http://192.168.0.1
-You should see a Username and Password Screen...type admin for the username and leave the password blank, unless of course you did give it a password.
-Next you should see the D-Link setup page with tabs across the top that say Home - Advanced-Tools-Status-Help
-Click on the WAN button on the left side of the screen
-Now you should see the WAN Settings Screen
-Click on "Dynamic IP Address" (You should not use PPPoE)
-Click on the Apply button at the bottom of the screen.
-Now close your browswer and restart your computer.
-You should now be able to access the Internet...through the router cable and wireless
-Let me know if you need more help with any of these steps.
-Good luck...and I hope this helps!!
Jan 14, 2008 | D-Link AirPlus DI-524 Wireless Router
No response from the DI-604 D-Link Router
The cable must be of parrallel type......(not cross)... connecting router and the modem or PC...
Dec 23, 2007 | D-Link DI-604 4-Port Cable/DSL Router...
D-Link DI 514 Wireless Router (DI-514) Logo
104 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
