Question about Saeco VIA Venezia
Saeco Via Venezia leaks water from front top overhang.
The espresso machine leaks (more like pours) water from the front top overhang when brewing the espresso. Water leaks a little bit from the same area while steaming or clearing the water circuit. Every function of the machine seems to be working properly. I just received the machine refurbished, this is my first espresso machine. Any info you could provide would be greatly appreciated!
    President:
  • 1,618 Answers
That is not normal, this tells me that the pump has too much pressure that it is forcing water through the brew unit, or the expansion valve(if your model has one was not set properly). Is there a high pitch noise when the pump is running. If yes then it is the expansion, if no then the springs and the valve pins in the brew valve(small white plastic piece behind the brew unit) needs to be replaced.
Posted on May 22, 2009
Is it worth it to get the machine fixed if the heating element no longer works?
Saeco Via Venezia - YouTube
? 3:10
www.youtube.com/watch?v=8L8vdfMOx2g
Nov 24, 2011 - Uploaded by TheSTiGUi
I dusted off my old Saeco Via Venezia, and wanted t. ... Quick run down of my incomplete modified Saeco Via Venezia Espresso Machine ... a start temperature of ~95deg C (obviously depends on boiler water temperature etc.) ...
Jul 28, 2015 | Saeco VIA Venezia
Last night I removed the brew head screen to clean it and then screwed it back in. (I did this because it was taking forever to get one shot of espresso). Now I can only get a trickle of water out of the...
HI
It sounds like you didn't get all the parts back in the head. The silicone head with the spring goes in first, then the screw. The spring has to touch the screw. Then the filter screws into the screw plug.
Jan 26, 2011 | Saeco VIA Venezia
After months of perfect performance, my via
HI I think you have a blown element in the boiler. You might have a leak that is shorting inside also.
Jan 26, 2010 | Saeco VIA Venezia
My machine seems to heat up, it runs like it is drawing water into the boiler and it will froth but it does not brew espresso now. What could be the problem?
Hi
If water comes out the head with out the portifilter in then its you portafilter or your grinds are too fine. If its not coming out the head then your pipe in the brew head are plugged with scale.
Nov 25, 2009 | Saeco VIA Venezia
My Saeco Via Venezia espresso maker broke; the screw that holds the metal filter into the machine will not remain there. What can I do?
HI
There is a large screw in the brew head that your screw screws into. You need to replace the big screw and you should be good to go.
Nov 12, 2009 | Saeco VIA Venezia
Wont brew coffee or steam
check steam valve sometimes valve make problem or steam wand is plugged
Aug 02, 2009 | Saeco VIA Venezia
Saeco espresso machine Isn't pulling water at all
Can you brew a coffee? If not then the problem is the pump might be blocked.
Jun 22, 2009 | Saeco VIA Venezia
Makeing coffee
No, these machines use a pressurized portafilter to make brewing espresso easier. Be sure your coffee is ground about the fineness of table salt. Just level the coffee in the filter and insert the filter as instructed.
Mar 08, 2009 | Saeco VIA Venezia
Coffee not pouring through portafilter
if your grounds are tamped down too tight, the steam can't get through it.
Dec 30, 2008 | Saeco VIA Venezia
Saeco VIA Venezia Logo
363 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
