Question about Craftsman Air Tools & Compressors
Sears compressor Model 919.155730 flywheel/motor shaft not secure
My compressor electric motor spins but the flywheel isn't secured to the motor shaft. I know there's a set screw but it won't hold tight to the motor shaft even though I've used the proper allen wrench.
Any ideas how to solve this?
  • Anonymous Mar 13, 2014
    how do you remove the flywheel from a compressor pump. Do you need to use a puller or can you just loosen the set screw.
    Problem Solver:
  • 13 Answers
It could be that you are missing a shaft key, look to see if there is a groove in the shaft and in the flywheel if so there should be a key in this groove to keep the shaft from slipping.
Your local hardware store should have one. You will need to Measure the keyway width and height to buy key stock of those dimensions then cut off the length you need.
If it is a Woodruff or Half Moon key Sears compressor Model 919.155730 flywheel/motor s - 2ea7913.jpg it might be harder to find the right one but a good hardware can do it.
Hope this helps.
Posted on May 22, 2009
The flywheel doesnt stay secure on shaft. Could it be wrong size keyway?
What type of motorcycle , what make and model and year are you working with?
Sep 16, 2014 | Motorcycles
2007 grand prix won't start but lights and horn work
Your battery is to low on power it needs a good charge, or replace it is the best option for a brand new one!
Feb 27, 2012 | 2007 Pontiac Grand Prix
I have a Sears 18 HP BS 31P777 Just got a long block moved every thing over and it will not turn over I get a spark on the plug and a backfire every once in a will but thats it Things I will check...
a simple way to set the gap is to use a couple of regular business cards (2) stacked on each other, loosen the magneto and let it fall onto the flywheel, with the cards in between, and then tighten the magneto hold down bolts, and spin the flywheel to remove the cards, with the gap you have the motor is fighting to fire and is doing so too slow, which is causing the backfire,
Jul 21, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Hi i have an Ingersoll rand 80 gal, 7.5 hp, model #2475 air compressor and the electric motor is arcing when trying to run then blows the breaker. Any ideas? thanks
It sounds like either a problem with the brushes in the motor or the engine shaft is jammed. Have you on many previous occasions run the compressor on that circuit with no problems? It may be as simple as the breaker is not sufficient for the power draw of the compressor.
If you have had the unit for awhile and it has been run lots and the engine shaft spins easily when turned by hand (unplug first) then it may be an issue with the brushes on the electric motor. Take the engine apart and replace the brushes with new ones from an electric motor shop. Take pictures as you disassemble the unit so you will be able to refer to them when it comes time for reassembly.
If the motor shaft does not turn by hand, remove the belt that connects it to a compressor and try again. If this works, reconnect the power and see if the electric motor now works with power on and the belt off. If the motor works and there is no short to throw the breaker, then your compressor is in need of a rebuild and that will cost money and time.
Mar 15, 2011 | Ingersoll Rand Electric Driven Two Stage...
My Craftsman 7&1/4 inch 12 amp Circular Saw(Model 315.108330) slips while cutting. The motor keeps spinning but the saw stops rotating. Can I Fix it?
Most circular 7-1/4 saws have a bolt and a compression washer that acts as a brake shoe that holds the blade secure but under dire circumstances will allow the blade to slip some rather than hold the motor shaft and allow burn out. The compression washer under your bolt has become worn and doesn't grip the blade securely. You can find a split washer that will fit under the blade and give you some more friction, or go to sears and order another compression washer for your saw.In the Sears Parts List found at: http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-32018780/0247/0744410/50035950/00001?blt=06&prst=&shdMod=
see part no. 44
Feb 23, 2011 | Craftsman Evolv 12 Amp 7-in Circular Saw -...
Will not go backfires
Check that your flywheel (magneto) is securely attached to the motor shaft. If it's not, that will give you erratic spark timing.
Access the top of your motor, remove any plastic covers surrounding the area where you can see the flywheel spinning. Remove the 4 or so screws attaching the cover and lift it out of the way.
Try lifting the flywheel off the motor. Make sure that top bolt is tight. Make sure there is a key between the shaft and the flywheel.
Gary
Dec 12, 2010 | Garden
Kenmore series 70 #11026732500 spin problem
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26732500&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
I'm assuming that you mean that the washer won.t spin with a load but will without one.
Two possibilities:
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
As an aside, the long pole (agitator shaft) shouldn't turn if you hold it when the washer is in spin mode. Basically, the oil "friction" within the gearcase is turning the shaft when in spin mode and if you hold it, it shouldn't turn.
When the washer is in spin mode, the "drive tube" which turns the drum is driven by the clutch.
Also see the following for how these gearcases work and how the agitator shaft is released by the "agitate cams" when in spin mode.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
May 27, 2010 | Kenmore Washing Machines
Washing machine won't reach full spin
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
TWO possibilities since it will spin:
May 08, 2010 | Kenmore Washing Machines
I have a Kenmore 80 series washer model number 110.29852992 it will agitate but will only spin with small loads
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.29852992
Also see the Whirlpool / Kenmore installation and maintenance manual for this type washer.
If it only spins with small loads, it is possible that the Motor Coupler is broken. This coupler has two plastic / 3 pronged pieces that mount on the motor and transmission shafts with a rubber 6 hole piece between them. It is designed as a fail safe.
If the holes on the rubber piece have worn, the motor may not be able to get enough power to the transmission to spin it with heavier loads.
It's also possible that the clutch has worn.
Please see this document on how to pull the cabinet and inspect the clutch.
Sep 30, 2009 | Kenmore Washing Machines
Craftsman air compressor bearing flywheel
Your local hardware store should have one. The model number will probably not help; you will need to measure the keyway width and height to buy key stock of those dimensions then cut off the length you need.
Hope this helps.
May 21, 2009 | Craftsman Air Tools & Compressors
Air Tools & Compressors Logo
259 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
