Question about Maytag MFF2557HES Stainless Steel French Door Refrigerator
Maytag mff2557hes icebox not cold, freezer works.
This is a french door with freezer drawer unit. The cebox does not get cold .but the freezer works.also the folding piece that seals between the doors gets hot to touch, you can't touch it over 5sec.and the fan in the freezer turns very slowly. I have defrosted the unit over three day and there is no ice buildup.
  • Maytag Master
  • 4,655 Answers
OK, I will take you to the Maytag Service Library, You will need to put your refrigerator through some self diagnostic to locate the problem, click on link below and let me know when you are ready, Thanks, Sea Breeze
http://www.servicematters.com/maytag_library/docs/16025690.pdf
Posted on May 22, 2009
Ice builds up under the pull out freezer drawer then melts allowing war we to flow onto the floor
It is most likely that the defrost drain is blocked in the freezer causing the water to drain through the air vents. You will most likely have to remove the rear panel in the freezer and pour hot water in the drain trough until the drain clears up and the water drains down the drain tube.
Aug 16, 2014 | Maytag MFD2560HES Bottom Freezer French...
I have maytag mff2557hes fridge that seems to run more often than not. Freezer and fridge cool fine but it seems to run all the time. Is this normal?
Pull the unit out from the wall and check the coils at the compressor for lint and dirt buildup. The coils and fan should be free of any debris to operate correctly.
Nov 03, 2012 | Maytag MFF2557HES Stainless Steel French...
Model # MFF2557HES Top refrigator section stoped cooling freezer is working
You may have Ice buildup in the freezer. You freezer has a fan in the bak that sends the cool air to the fridge. Your fridge dial determines how muh cold air comes from the freezer. Try defrosting the freezer. You may have to pull the back panel off of the inside of the freezer to get the ice thawed. The ice build up is likely causing the air to not get to the fridge. Hope it works.
Aug 16, 2012 | Maytag MFD2560HES Bottom Freezer French...
Maytag Refrigerator MFF2557HES - won't stop running, everything frozen... despite adjustment to temp setting What to do, please and thank you?
Possible that the thermostat or the control unit is faulty as it fails to cut off the compressor.In some cases the frost or ice formation can reduce the connection or wire contact of the thermostat and so the function will not work. You need to remove the freezer rear covers to confirm if the wires are intact and also if the thermostat is working along with the auto defrost timer.
Sep 19, 2011 | Maytag MFF2557HES Stainless Steel French...
The bottom freezer works but the refrigerator will not get cold. model# MFF2557HES
Sounds like airflow fan needs to be replaced. Most fridges use a small fan that blows air from the freezer to the refridge. If that fan fails you get working freezer and non cool fridge.
May 06, 2011 | Maytag MFF2557HES Stainless Steel French...
My freezer is cold but my fridge is warm.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 06, 2010 | Maytag MFF2557HES Stainless Steel French...
My Refrigerator and Feezer are not cooling. mff2557hes
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
we
Aug 01, 2009 | Maytag MFF2557HES Stainless Steel French...
Maytag Refrigerator
Pull out your WIDE-N-FRESH Deli Drawer at the bottom, and when the lid automatically raises look to the right: you'll find a sliding temperature controller that most likely is all the way up. Slide it down towards the bottom and this will cut back on the cool. Worked for ours!
Jun 04, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
Everything in my Maytag model MBB1952HEW refrigerator freezes. It is running pretty much non stop now
You will need to replace the control board, which controls the temperature in both compartments, refrigerator and freezer.
Aug 12, 2008 | Maytag MFF2557HES Stainless Steel French...
How to examine MFF2557HES evap fan?
Yes, if you're not afraid of removing service panels and replacing parts, then this is something that you can probably replace without too much trouble. Very straightforward, just remove the fan motor assembly & screw a new back into it's place. And yes, that sounds very probable if you've already tried defrosting the machine first.
Aug 04, 2007 | Maytag MFF2557HES Stainless Steel French...
Maytag MFF2557HES Stainless Steel French Door Refrigerator Logo
601 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
