Question about Norelco Rechargeable Cordless Men's Razor - Black/Gray
Help changing batteries on Norelco 5825/XL, please?
I would like to change the batteries on my 5825XL & I got new batteries and took the back off and I can't get the old batteries out?? Are they soldered in place & how do I replace them? Thank you in advance for your time.
  • reenactingfa May 31, 2009
    Thank you so much for answering my question. I really appreciate it:)
  • 276 Answers
Replacing the batteries is not an easy job. You need to have a special Torx screwdriver to undo the screws.
The batteries are soldered onto the Control Board (it's unfortunately not just a case of cracking open the case and putting in batteries in an instant). The batteries inside are 600mAh.
It may be worth speaking to your local Philips Service Center (refer to www.philips.com)
I usually recommend if you're replacing a shaver to spend a little more $$'s to get one that is mains and rechargeable so that when the batteries die, the shaver is still useable.
Posted on May 31, 2009
Norelco 5825 XL specifications
It's correctly, norelco 5825xl replacement heads is Norelco HQ5 blades replacement parts.
May 03, 2012 | Norelco Reflex 5825 XL Electric Shaver
I need a new battery installed in my Norelco 7845 XL, It's at least 10 yrs old, & has new blades in the head. Where do I send it, & how much.??
Hi jimkaem,
You can find valuable resources for the 7845XL including manuals and FAQ's:
http://ow.ly/5XMkD
The batteries for this shaver are built-in. Do not try to replace the batteries yourself.
If you have problems with the built-in batteries, take the appliance to your local service center to have them checked and/or replaced by a professional.
Aug 08, 2011 | Norelco Quadra 7845 XL Electric Shaver
Need to replace the batteries in a norelco 5821xl
norelco battery replacement NiCd two batteries pack for electric shaver philips norelco 5821xl replacement parts.
Feb 06, 2011 | Norelco Reflex 5821 XL Electric Shaver
Does the 5825 charge only on a single voltage (120 or 230 volts ac) or is it 100 to 250 volts usable everywhere.
Hello, It depends where you bought it.But now a days most of the power units come either in DUAL VOLTAGE (switchable ) or UNIVERSAL VOLTAGE ..USA (110 v AC) and European (230 V AC )..it works in between.The later one automatically accepts the plug in voltage without any switch.
If you look carefully his info should have been posted ( with tiny letters ) onto the power adapter.
Regards
Oct 06, 2010 | Norelco Reflex 5825 XL Electric Shaver
How to change batteries?
mcdevito75 here, There are 2 versions of batteries in Norelco shavers 1 system is where the batteries are soldered to a circuit board in which case you"d have to replace the shaver or find an appliance repair shop in your area, The 2nd is where you can replace the batteries your self but, you;ll need a set od torx screwdrivers available at any auto parts store, refer to Norelco online at Norelco.com for Battery replacement. Look for these torx screws on the back cover or by lifting the shaver head .
Jun 20, 2010 | Norelco Reflex 5825 XL Electric Shaver
Norelco 5825XL Replacement Blades
HQ5 is not compatible with HQ55. I've checked the Service Manual and HQ5 is the correct part. It's got to do with the driving mechanism for the head.
May 17, 2010 | Norelco Reflex 5825 XL Electric Shaver
How do you change the batteries in the Norelco 5801 xl or can I get a manual for the shaver
Start by removing the two screws on the back and remove the back cover. You will then be able to see the batteries. They are soldered to the back side of the circuit board. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
You will find batteries for model 5801XL at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
If you are not able to do this yourself, shaveroutlet.com can do it for you. See information link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Apr 29, 2010 | Norelco Reflex 5801 XL Electric Shaver
Shaver was running slow and then died. Replaced
Your original symptoms sure sound like dying batteries. Brushes can wear out. Check if it runs better if you change the orientation of the shaver. Does holding it upside down make it work better or worse? If the speed changes, its probably the brushes. You can buy new brushes, but the Norelco repair place will probably give you a hard time since they want to repair it for you so you have to insist. I have made brushes for the shaver by filing down brushes from some other motor, but this is messy and doesn't always work.
Jan 23, 2010 | Norelco Reflex 5821 XL Electric Shaver
Norelco Rechargeable Cordless Men's Razor - Black/Gray Logo
1,001 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
