Question about Cameras
When I press power button it starts to open then closes. Have checked battery.they are ok.Memory card in ok.
  • 3 more comments
  • carolwright6 May 22, 2009
    I Don,t know what caused it but the same thing happened last year and it was corrected with stronger batteries. Camera bought November 2007. Warrenty from shop where bought has expired.Not sure about fujifilm.
    Will full memory card cause this problem.I was told that the problem with my camera is a common one and is not worth money to repair it. Is this so?
    It is FUJIFILM,9.0 mega pixels, 4x optical zoom. Finepix A920.
  • carolwright6 May 23, 2009
    Shall I just buy a cheap camera and forget about this one.
  • carolwright6 May 24, 2009
    I have been advised by your expert to seek a second opinion.
    Batteries are good ones also rechargably
    Scholar:
  • 93 Answers
Many things can cause this but given the information you have provided it probally rules out the battery and memory card. A very likely common malfunction is that the lense housing has been hit and it has caused the housing to come off the gears so to speak and it is now misalligned. It does not take much to cause this to happen a firm rub when open is enough to take it off kilter and malfuction until fixed. The motor that slides open the lense housing senses the friction and extra force needed to open the lense and trips the circuit on the bord to close the lense to prevent further damage. Take it to a repair shop and have it checked out and you should be back in business.
Also sometimes a pice of foriegn material can become lodged in the lense housing giving the same results. Either way have it checked out. Make sure it hasent been dropped or have gotten wet as it may have done permanent damage to the camera's internal board.
Joe
Posted on May 25, 2009
    Brigadier General:
  • 5,158 Answers
When you test the batteries it's not under a "load" which it is when you power on the camera. you need to purchase a good set of rechargable batteries and charger and use them... you shouldn't have any issues with the camera after that.
please take a moment to rate this solution.... thanks
Posted on May 24, 2009
  • 13,433 Answers
Do you get a error message? the camera has most likely picked up a problem with the lens mechanism or another internal fault and it turns off. These are not easy to repair at home and I don't recommend taking small cheap cameras apart, as they can be a real pain to get back together.
Is it covered by warranty?
can you tell me more about the problem and what lead to it? / caused it?
Posted on May 22, 2009
  • 1 more comment
  • Ekse May 22, 2009
    it shouldn't , you can take the memory card out and try again. can you post me the brand and model of the camera I don't see those right now so I don't know what kind of problems it might have usually.
  • Ekse May 22, 2009
    actually its a pretty common problem in all of these digital cameras, its more like a symptom of a internal problem that prevents the camera from turning on.
    It depends and varies from brand to brand and model to model.
    you can get a free repair estimate from www.advancecamera.com/repair
    and from http://www.precisioncamera.com/
    get repair estimates from both and see if its worth the repair.
    if it was a memory card problem you could take the card out and reset the camera,
    Sadly the only reset function this camera has is in the setup menu. Or you can take the batteries out for a moment and try it again.
  • Ekse May 23, 2009
    No, I'm pretty sure it could be repaired, you can also ask other experts if you want, you have a repost button or something to that direction there which will post your problem to other experts.
    If you get advice from another expert that tells you to replace a part, I would highly recommend that you confirm it / get a 2nd opinion and I would recommend that you only accept a solution when your satisfyed or if you have gotten your camera fixed.
    Did you check with the companies I posted for you about the repair estimates?
My cannon power shot a75 will not focus. All of the manufacturers symbols are perfectly clear but absolutely no focus when taking a picture.
Have you tried any of the following?
Power Reset
1. Make sure camera is off, and then remove the batteries and memory card.
2. Close the battery door.
3. Press and hold down the on/off button for 1 minute.
4. Release the on/off button, and reinsert the batteries and memory card.
5. Power the camera on.
Settings Reset
Next reset the settings of the camera to the factory default.
1. While the camera is on, press and hold the menu button for approximately 10 seconds.
2. The screen should then display the message "Reset settings to default".
3. "Cancel" will be highlighted so move to the right and highlight "OK".
4. Press the SET button once "OK" has been highlighted.
5. The screen will say "busy" while the settings are returned to the default
Nov 28, 2011 | Canon PowerShot A75 Digital Camera
How to remove memory card from camera
Confirm the power-on lamp and the monitor are off and open the battery-chamber/ memory card slot cover. Be sure to turn off the camera before opening the battery-chamber/memory card slot cover.
Removing Memory Cards 1 Before removing memory cards, turn the camera off and confirm that the power-on lamp and monitor are off. 2 Open the battery-chamber/memory card slot cover and press the card in to partially eject the card. 3 The card can then be removed by hand. Do not attempt to remove the card at an angle.
Insert the memory card.
4 Slide the memory card in correctly until it clicks into place. 5 Close the battery-chamber/memory card slot cover.
Oct 08, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
How can i switch to a memory card?
Most digital cameras use either a secure digital (SD), compact flash (CF), memory stick, multi-media cards or XDcards.
Step 1: Power the camera off and determine what type of card your camera uses. You can check the owners manual, go to the manufacturer's site, or look on the camera to find out what card you use.
This is a picture of an "SD" card in a Digital Camera.
Step 2: Insert the memory card into the camera by locating the memory card slot on the bottom or side of the camera body. Open the memory card door by using an "Eject" button or sliding the panel to the side. Insert the memory card as advised by the icon on the inside of the door. Close the door and turn the camera on.
Step 3: Format the memory card for the camera. Many digital cameras will do this for you once the memory card in inserted and the camera is powered on. On some cameras you can do this manually:
Press your camera's "Menu" button, select "Tools," and find the "Format" feature. Select "Format" and press "OK" or "Set" to format the memory card. Press the shutter button to exit "Menu" mode.
To remove the memory card, open the camera as you were able to in Step 2. Then press the end of the card in and release. The card will slide out of the camera.
Some accessories may be required to transfer media to your computer. There may already be a slot in your computer for the card, if not, an SD to usb kit can be purchased online or from a local electronics vendor for a reasonable price.
May 05, 2011 | Cameras
Wii console won't turn on
If there is no LED on, then the most likely reason is, that your wii isn't getting power. So the problem, is with the plugs, and the power adapter. If you have a friend who has a wii, try testing his power adapter on your wii. Make sure your cords are completely plugged in, on both sides, (the outlet and the wii) then press the power button on the wii. If that do-sent work, try turning it on with one of yourwiimotes. If that dosent work, that means your wiimote is not synchronized with your wii. To sync. it, open the sd card cover on the front of the wii, press the red button above the sd card slot. Then open the bottom of your wiimote, (where the batteries are) and press the small red button that should be beside the batteries. Then hold the wiimote close to the wii,then after its done flashing, press the power button on the wiimote and also, try plugging your power cord into another outlet. If it still won't work, you've got a broken wii, so you better send it to get replaced or fixed, again as suggested. DON'T OPEN IT! You could loose your warranty if you open it, so it's safest not to. Hope you get it to work
Thank you !!
Jul 18, 2010 | Nintendo Wii Console
How do i remove memory card from my nokia
1. If the device is switched on, before you remove the card,
press the power key, and select Remove memory card.
2. When Remove memory card? Some applications will
be closed.
is displayed, select Yes.
3. When Remove memory card and press 'OK' is
displayed, open the cover of the memory card slot.
4. Press the memory card to release it from the slot.
5. Pull out the memory card. If the device is switched on,
select OK.
Regards,
Jeep Brainy
Sep 13, 2009 | Cell Phones
What does no card mean? Thank you.
"No card" means that either
  1. You have not inserted a memory card
  2. The memory card is not formatted, or
  3. The memory card is damaged and therefore can't be read by the camera.
How to insert the memory card:
  1. Open the camera’s battery door by sliding it downwards.
  2. Insert the SD card into the slot as shown inside the camera’s battery compartment. The SD card can only be inserted one way.
  3. Press the SD card completely into the camera and then close the door. Open the door and press on the memory card if you wish to remove it.
Note: There is only one way to insert the SD memory card into the slot. Do not force the card into the slot. This may damage both the camera and the SD memory card.
Before you can use the card, it has to be formatted:
  1. Insert the memory card into your camera as described above.
  2. Turn the camera on by pressing the power button.
  3. Use the multi-select button to select the "SET" option.
  4. Press the right arrow button to set "System" then press down key to select "Format".
  5. The default option is ‘Format’. Select this option by pressing the OK button.
  6. Select "Yes" to format the card.
If all this does not work it might be that your SD card is damaged. Try to replace it with another one. If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 08, 2009 | VuPoint DC-ST300-VP Digital Camera
Power outage last night - alarm sounded. Turned off computer - pressed the button to silence alarm. Five hours later, battery sounded a different alarm every 20 minutes that could not be stopped. Gr-r-r-r!...
hi..OK 1st step open the unit and find the memory from the board remove the memory then make clean the all pin connectors using a paper eraser.if u have video card remove too then same make a clean..good luck and have a nice day...Thanks
Jun 14, 2009 | Tripp Lite Lite OmniSmart 700 PNP UPS...
Fujifilm A700
hi use a fuji s5600 which is ok for my need's but also the batteries are very fast down, i checket it to contakt for the battery is not good my tip clean out the battery shelf and try to tighten up the small srews inside, may open it and close again and you can use a power messure if the power goes true or not. sorry my english...
Sep 22, 2007 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Camera stuck when using memory card
hi, i had a problem with my camera where i put in memory card and it said 'out of memory' i took the card out turned on camera went to set up mode and found one that said 'rest to factory defaults' pressed that and then put card in and all ok, might be worth a try :-)
Mar 13, 2007 | Nikon Coolpix 3200 Digital Camera
Cameras Logo
69 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
