Question about Kenmore Dryers
Dryer will heat up then gas shuts off and will not re-ignite.
My kenmore gas dryer will come on and heat up for a few minutes then there is no heat. The igniter comes on, it has gas at the start but then it keeps trying to ignite, the vent is clean and there is lots of air flow. Please help.
  • bowvalley May 22, 2009
    The model number is 110.C74852301. How do you access the gas valve?
    Thank you very much, seemed a little too complicated for me so I called the repair man. He was done in 20 minute and charged me $240. Next time I will put more effort into it, at least the wife is happy now. Maybe it wasn't too much after all, ha, ha. Thanks for all your help, Ed.
  • Kenmore Master
  • 4,654 Answers
That is a sign that the coils that open the gas valve have become weak. The one sitting toward the outside has a 3 wire connector and works with the igniter. When worn out they may open the gas valve for about 3 second or sometimes not at all.If you look inside the door and get me the model number I will get the part number for you. Some people sale a kit of 2 each. Let me know, Sea Breeze
Posted on May 22, 2009
  • 1 more comment
  • John Tripp
    John Tripp May 22, 2009
    Here is a picture and a link below,
    http://servicepartstec.blogspot.com/
  • John Tripp
    You will need to use a flat head screwdriver or a butter knife to pop the left and right front corners. Then lay the top back against the wall behind. Reach down inside the front and disconnect the door switch wires. Then remove a couple sheet metal screws and with a little gentle pressure reach through the door and hold the drum up . Do the same when you put the front back on as the frame has some hard plastic slides for the drum to rest on while drying clothes Try not to disturb the belt on drum so the belt don't come off. From there you will see the 2 solenoids on bottom left.
  • John Tripp
    Check that number again Sears does not recognize it. I don't think it shold have the letter c in the number, Thanks
Ignites on start up ,but after initial heat cycle will not ignite again until I shut down for a few minutes then restart.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 07, 2011 | Kenmore 75944 Gas Dryer
My model 400 series Kenmore gas dryer has a heating issue. At first start I can hear the gas heater ignite and heat the dryer. After the dryer has ran for a few minutes the burner shuts off and fails to...
heatman101';
Jul 05, 2011 | Kenmore Dryers
Our kenmore eliite HE4 gas dryer keeps shutting off after a few minutes of running no mattter what heat setting we put it on. On air dry mode it works. Is this a high heat sensor problem? The unit is 4...
You didn't mention if the dryer is getting hot.
If is getting hot, then shutting off, I agree with you.
If it is NOT getting hot, I would suspect the IGNITER ASSY
Dec 13, 2009 | Kenmore Elite HE4 Electric Dryer
Gas dryer heat is intermediate
does the igniter glow white or orange? if it is orange you need to replace it. has to be white hot to ignite. if the igniter is white it could be the coils not opening the gas valve all the time - an intermittent problem.
Oct 04, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer heats at first but then stays cool.
Check that the air entry and exit passages to and from the burner are clear of lint or a stray sock.
Aug 23, 2009 | LG DLG5932W Gas Dryer
No heat burner comes on for a few minutes and then goes out
Check the following to address this issue.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Jun 02, 2009 | Kenmore 72062 Gas Dryer
Heat runs ten minutes than heat shuts off continues to run
I'm thinking the thermostat has failed, it get's too hot and the emergency over temp sensor kills the flame before a fire is started.
Apr 07, 2009 | Kenmore 63942 Dryer
Start gas dryer heat will ignite after a couple minutes no heat
That is usually a sign that the gas solenoids are weakening. Sometimes for some dryers you can buy a pair. Don't know your complete model number.Thanks, Sea Breeze (Visit my site)
Mar 23, 2009 | Kenmore Dryers
Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
May 17, 2008 | Dryers
Dryers Logo
156 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
