Sata controller well I assamble a new cpu, wich I have a mobo ASUS MN32SLI DELUXE, and the hard drive toshiba 320 Gb SATA, I'm trying to install the windows vista but I can't because the hard drive does not appear, I've tried to install the driver with a floppy disk but it said: non-system disk or disk error.what I should do?
  • scotta01 Nov 20, 2007
    Hi, I am also having the same issue, whenever I boot up I either get a message that there is no system disk or it just hangs?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Computers & ... Master
  • 1,395 Answers
Try different disk
Posted on Nov 30, 2017
  • 10 Answers
SOURCE: First time connecting SATA hard drive to this motherboard - do I need special drivers?
You shouldn't need any drivers- as long as the drive shows up in BIOS and looks correct- windows will load the drivers you need to make it work. Then when it's running - load the chipset.inf driver and the LAN driver from the motherboard CD. This will get you on the internet so you can go to the ASUS site and download all the new drivers (Including the newest chipset and LAN drivers)
Posted on Nov 01, 2007
  • 5 Answers
SOURCE: How to install XP on pre loaded Vista in HP Laptop
I bought a cheap Compaq laptop that came with Vista Home Premium. The speed was horrendous! Anyway, I received the same no hard drive found error. To solve the problem, I went into the system config (BIOS) by pressing F10 on startup, and turned off SATA hard drive support (its supposed to make the hard drive run faster), I rebooted, inserted my Win XP Pro disc and viola, it detected the hard drive. I would say that the laptop runs a good 40% faster than before. Vista is a big no no when it comes to low end laptops built for word processing and internet browsing.
Posted on Mar 29, 2008
SteveRand
  • 210 Answers
SOURCE: Conflict between Promise Ultra133 and SATA RAID controller
Check that your RAID controller and onboard SATA controller aren't in a compatibility mode. You can put them in this mode while you have no SATA driver installed in Windows.
This tricks Windows into seeing the SATA drives as regular IDE drives. Your BIOS then has a spasm when it see's another IDE controller there, and just uses the card instead.
Make sure the SATA drivers are installed first, otherwise anything SATA will stop showing up. (and your Windows just won't boot if it's on a SATA disk and you take compatibility mode off) =-]
Posted on Aug 20, 2008
SOURCE: Device Manager shows VIA SATA RAID Controller with Yellow "!"
same problem.....for help contact dragosdogaru1985 yahoo messenger
Posted on Dec 19, 2008
SOURCE: how to install window XP without floppy disk on asus P5RD1-VM
@font-face { font-family: Cambria Math; } @font-face { font-family: Calibri; } @font-face { font-family: Tahoma; } @font-face { font-family: Segoe UI; } @page Section1 {size: 8.5in 11.0in; margin: 1.0in 1.0in 1.0in 1.0in; } P.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman","serif" } LI.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman","serif" } DIV.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman","serif" } A:link { COLOR: blue; TEXT-DECORATION: underline; mso-style-priority: 99 } SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline; mso-style-priority: 99 } A:visited { COLOR: purple; TEXT-DECORATION: underline; mso-style-priority: 99 } SPAN.MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline; mso-style-priority: 99 } P { FONT-SIZE: 12pt; MARGIN: 0in 0in 16.2pt; FONT-FAMILY: "Times New Roman","serif"; mso-style-priority: 99 } SPAN.EmailStyle18 { COLOR: #1f497d; FONT-FAMILY: "Calibri","sans-serif"; mso-style-type: personal } SPAN.EmailStyle19 { COLOR: #1f497d; FONT-FAMILY: "Calibri","sans-serif"; mso-style-type: personal } SPAN.EmailStyle20 { COLOR: #1f497d; FONT-FAMILY: "Calibri","sans-serif"; mso-style-type: personal } SPAN.EmailStyle22 { COLOR: #1f497d; FONT-FAMILY: "Calibri","sans-serif"; mso-style-type: personal-reply } .MsoChpDefault { FONT-SIZE: 10pt; mso-style-type: export-only } DIV.Section1 { page: Section1 } You need files in setup. Extract to floppy (all of them) F6 at setup. add a floppy drive.. or create another XP setup disk and place SCSI driver accordinly. You may have to take out the HDD - find the drivers for that HDD at western digical - m5287.sys
ULISATA.INF
ULISATA.CAT(optional)
http://www.techpowerup.com/downloads/408/ULI_SATA_RAID_Floppy_Driver_v6.2.2.1_Beta.html
copied those files in a floppy inside a folder "WIN_XP".. then during setup f6 for driver selection.. then i just located tat floppy for drivers and my drive thus got recognised
Posted on Jan 26, 2009
How do i know if it is a 2.5 in or not and will any sata external case work with it?
The Toshiba (MK3252GSX) hard drive is a 2.5 in SATA drive and it will fit into any 2.5 in USB hard drive case.
Dec 04, 2012 | Toshiba (MK3252GSX) 320 GB SATA Hard Drive
What jumpers are for slave Western Digital WD Caviar Blue WD3200AAJS - hard drive - 320 GB - SATA-300 SATA
SATA drives don't need jumpers. Just install the drive and the computer will assign a drive letter.
Jun 06, 2012 | Western Digital WD Caviar Blue WD3200AAJS...
Hi, cannot find the right set of drivers for the mobo A7N8X Deluxe. It does not recognise my SATA drive, even I've installed corresponding drivers After pressing the F6 key and installing the SCSI Drivers...
Connect your SATA on the first SATA slot to make it as the Master. Or maybe the BIOS settings is set only to recognize IDE device. If this is the case, try going to BIOS settings then Peripheral Devices, look for the menu Hard Drive and replace the IDE into SATA.
Feb 04, 2010 | ASUS A7N8X Motherboard
I cannot configure a SATA RAID 1 to mirror two WD HDD 1 TB
You sure you installed the ASUS RAID drivers when you installed Windows? Ya need to get the drivers off the ASUS disk, transfer them to a floppy, hit F6 when windows tells you to (during windows install...you only have a second or 2 to see the message!)) and use the floppy to install them. Might take a few tries to get it right.
Dec 26, 2009 | ASUS P5GD2 Deluxe Motherboard
I'm wondering if my ASUS K8V-X motherboard will support a 320 GB SATA hard drive.
Check is there ports available for connect SATA HDD. If yes it will support .
Thanks.
Oct 14, 2009 | ASUS K8V-X Motherboard
Will cloned Hard drive work with new MoBo and CPU
No, it's not true, but you will need to buy Partition Magic to clone the smaller drive onto the larger one.
The new MoBo and CPU might give you more trouble though. All of the windows drivers for the old MoBo will be confused when they see all new hardware. In the olden (WinNT) days, this rarely worked. Now in the WinXP SP3/Vista days, you'll probably be just fine.
Sep 01, 2009 | Seagate Barracuda 7200.9 500 GB ATA-100...
P4m80-m4 mobo not detecting SATA hard drive
go to bios setup,thn go to advncd settings thn u have to change the settings for hdd from ide to sata mode
Jul 23, 2009 | Seagate Barracuda 7200.10 320 GB SATA Hard...
2nd sata connected and xp won't boot
It seems you have not made the second SATA the slave of first SATA. You'll have to fix the jumper pin in the designated slot to make the second SATA the slave. a1d66e3.jpg
Jul 07, 2009 | ASUS A8N32-SLI Deluxe Motherboard
Upgrading my computer
Dear Fried its possible.. Go the Boot Menu at your BIOS ( For go the BIOS Press DEL at startup your system) there you may se Hard Disk Priority Option. There you can change Hard disk Priority... you may need setup your sata as first one..
Thanks...
Mar 26, 2009 | ASUS K8V SE DELUXE,...
Computers & Internet Logo
57 people viewed this question
Alun Cox
David Payne
David Payne
