I purchased Bluedio I4 bluetooth headset a month ago and as I was out of town for a month the device was received by my mom and it was not unpacked. I unboxed it today and after putting to charge for 4 hrs I took of the charger and tried to turn on the bluetooth by pressing the call button but it does not turn on. However it works only when it is plugged to the charger? What could be the problem? Have I screwed the device or is it a device problem?
very simple....jst hold the on button(continuesly) then search for de device.....when it shows up press conect den press 0000 for de pair code...thats all and any thing u see jst press yes!!!.
I have the same unit. It does work PS3 just fine, but the instructions included with the Bluedio H9 are vague and poorly written.
First fully charge it. Then hold the mulit-function button down for 5 seconds or so. It will turn on (light will flash blue)...then keep holding the button down another 5 seconds or so and the light will go solid blue. Now you are in "discovery mode" if you don't get it into discovery mode, your PS3 can't find it.
Go
to the "Settings" tab on the PS3's cross-media bar and select the
"Accessory Settings" menu. From the new menu, select "Scan for Bluetooth
Device."
After you have added the Headset, you can control the Mic pick-up level (1 to 5) under Accessory Settings -> Audio Device.
very simple...hold the call button and the play/pause button while startin the unit up...the led will blink blue thrice and will continuously stay on confirming the reset mode...u can now view the headset as AV890 on ur phone or pc....the code is 0000...confirm it and the connection is authenticated...done...q.e.d
