Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite Smartwash
I have been getting all sorts of errors with this machine, but today, the door locked while open. If that makes any sense to you. A light on the machine is red next to Control Locked. The machine wont allow me to close my door, because there is a little white thing locked where it would close. Any help would be appreciated. Thanks
  • JLAnders5621 Nov 03, 2007
    They had to tear it apart and repair some connections. Thanks
    Scholar:
  • 146 Answers
Switch the machine off at the wall and leave it off for a few minutes. The door interlock should reset. If it doesn't, then you have a faulty door interlock or by the sound of what you have described, you might even have a board problem!!
Posted on Nov 03, 2007
Kenmore elite smartwash quiet pak 4
This video will show you how to change a door seal on this Bosch front loader washing machine
You can find more Bosch videos in our Bosch repair channel
Jul 22, 2013 | Kenmore Elite 45986 Front Load Washer
Kenmore smartwash error code dl and f? Won't start.
Hello and welcome to FixYa
DL f is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the problem is solved. Please get back to me if you have any other questions.
Kevin
May 26, 2011 | Washing Machines
Error code F35
f 35 is not in my info book . if you remove front panel 3 screws at bottom . inside there is a tec sheet with the fault codes. i would ck the clean out for the pump . it is right in front when panel is off . this may solve your prob .. .. mm
Nov 22, 2009 | Kenmore Elite HE5t Washer
Error "F6" on my Smartwash Quite Pak9
I believe the F6 code is a motor failure. I suggest you call a pro to come out and look at it.
Sep 22, 2009 | Kenmore Elite 45986 Front Load Washer
My kenmore elite smartwash flashes f and dl when i try and run the wash cycle
Hi
Thanks for using FixYa. Error fdl means a Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
It has occurred due to
1. Door lock mechanism is broken or removed from door.
2. Door switch/lock unit failure. To unlock it follow the steps—
a. Unplug washer or disconnect power.
b. Check door switch/lock unit.
c. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Please revert for further assistance.
Thanks
Rylee
Jul 21, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Smartwash Quietpak4 won't turn back on
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 11, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Smartwash HE 4T
door lock issue ck for broken door strike on door broken door lock button on door frame also possible connection at main control under top at rear..if moving wires fixes problem try shimming in place only sure fix would be new control..lock not hard to replace remove spring holding door boot on and roll boot back 2 or 3 screws hold lock to frame remove and pull lock to opening remove wires and replace lock
Sep 08, 2008 | Washing Machines
My kenmore elite smartwash/he4t (error code)
Try shutting off the machine. Switch off Usually the door opens in 2 minutes or so. Do not force open the door. There may be instructions in your book to open the door manually. It could mean unscrewing somewhere.
Apr 04, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
176 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
