Question about Craftsman Garden
KIck-back when trying to start
Craftsman Model 944.367301 with Model 143.976600 Tecumseh engine 'kicks back' when trying to start. It almost rips my arm off. What is causing it to kick back? It ran fine when stored away last fall (with fuel preservative). Did manage to get it running for a short period, but shut it down to top-up the fuel, and am unable to restatrt it. It doesn't even sound like it is firing, but since it is kicking back, it musty be firing. The valves seemed to be working corrrectly when observed through the side cover. Could it be a carb/fuel problem?
  • 376 Answers
Most likely your flywheel key is sheared throwing the timing off. Pull flywheel and inspect key.
Posted on May 22, 2009
Yardworks snow blower
Leaks are normally from bad seals or ones put on engine wrong. Many snow blowers leak oil, very common. Electric start needs to be taken apart. Rust is problem most likely. When you engage the starter it kicks out the gear to turn over engine. Carefully remove the starter from engine, try to start starter an if the pinion gear does not kick out from starter disassembly it an try to clean rust away from action. Dont break wires around electric motor careful about getting dirt an rust in winding. Try to lube spring an moving parts around gear. One other thing it could be a sheared off gear on starter also.
Mar 22, 2014 | Tecumseh Garden
I have hero honda cd deluxe 2006 model . It is only kick start and kick is jammed. whats the problem & how can I fix
If you are having trouble moving the kick start try removing the spark plug, rock the bike backward and forward then try pumping the kick start a few times. If it frees up put the plug back in and try starting it
Jan 03, 2014 | Motorcycles
Tecumseh 8hp snowblower engine kicks back hard enough to break plastic handle. I checked the key in flywheel ,I cleaned the carb,checked the flywheel, andcleaned magnets and coil pick up. I tried to start...
surging when running is most likely normal ,they have a governer that control's the carb & rpm so it wont over rev. It has a paddle near the fly wheel to pick up wind from it when running hooked to the carb with a small lever and held stable by a spring. Check to see if the spring is too tight or sloppy. 8 hp is a pretty big motor and a kick back is not really un expected. But a plastic handle is kinda cheesy, a rubber or a wooden handle would be better.Good thing you have electric start!
Oct 08, 2013 | Garden
I have a Tecumseh 8hp snowblower engine that kicks back and has broken the plastic handle. I soaked the carb ( engine surging) cleaned it all real good. I checked the woodrift key, no marks , fly wheel...
If you didn't replace the woodruff key, you need to anyways. Another option is the cam. Have you had your coil off.to.clean it and may have possibly put.it on upside down? It is definitely your timing, it is just a process of elimination.
My pull cord rips out of my hand
The string assembly should reach a point far enough out when you pull the cord that it lets it spin free of the engine. What you are probably experiencing is the engine kick-back, where the engine is compressing the air/gas in the cylinder, and the pressure pushes the engine back. The crankshaft is connected to the pull cord assembly, so it's pulling out of your hand. You may not be pulling hard enough, or the cord assembly needs replacing.
Aug 01, 2012 | 5.5 HP GX160 Engine
Mower starts and runs for 10 - 15 seconds, then dies. Will almost start again, but soon will not even kick over. After a while, it will start for a few seconds. This is a 15 horse Tecumseh that looks...
It sounds like a carburetor issue. The jets are probably gummed up from the old gas that was in it. Remove the carburetor and clean it out with a can of carb cleaner. Then reinstall.
May 22, 2011 | Tecumseh Enduro Vertical Engine 16 HP 1in...
I own a 10" craftsman tablesaw (model #
Wait for the motor to cool then try again..... you may use compress air to blow across the motor to speed the process.
Jan 19, 2011 | Craftsman 10" Table Saw
Very hard to kick start
i dont know what your timing is relevant to flicking the compression switch and kicking, but get the engine to the compression stroke and then as you go to kick it hard, flick the switch at that moment. timing is everything. i had an old yamaha tt 500 that kicked back so hard my foot slipped off the kick start and kick lever came up and took the skin off my shin.. it took quit a bit of time to get the timing but once i did, it was easy.. hope this helps.
May 19, 2009 | 2005 KTM 640 LC4 SM
Jamed kick start
Sounds more like a seized engine to me. When a kick starter breaks it will be when you're kicking it. If the engine died and the bike doesn't turn over with a kick it's probably locked up. Try pushing it back and forth in a higher gear and see if the engine turns over when you let out on the clutch,
Nov 10, 2008 | 2002 TM Racing E 125
Garden Logo
604 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
