Question about GE Refrigerators
My refrigerator is making a new buzzing sound every 10-15 min or so. It buzzes for about 10 sec and then makes a clicking sound like its trying to cycle on but cant. Its still nice and cold inside, but I wounder if its the compressor fan trying to turn on and failing. Its a Frigidaire model# FRT21NNCW
  • leslieh75 May 11, 2010
    It was suggested to check the capacitor...how do you do that? Where is it and how do you check it?
  • 6,784 Answers
Hi, there is a starter device on the compressor that is failing. you will need to replace this device soon. also, check the capacitor for its operational value. it will also make this sound when it is malfunctioning.
Posted on May 22, 2009
Amana fridge periodically makes a buzzing noise 4 times every 3 min for about 10-15 min then goes away for awhile then does it all over again
is your ice maker making ice sounds like water solenoid or the motor that turns the dump fingers is stuck this will happen if the heating element is not working, After ice is made the heating element comes on for a few sec.to release the ice from tray then motor comes on makes a full rotation to push ice out.
Dec 16, 2012 | Refrigerators
Refrigerator makes a buzzing sound for 10 seconds clicks and stops making the sound. This happens every minute or so
I believe that buzzing sound is coming from the start relay and the click is the overload clicking because the compressor is trying to start but cannot because the start relay is defective, You may have a run or start capacitor bad also, Thanks Sea Breeze
Model Number?
Nov 17, 2012 | Refrigerators
Freezer compartment no longer cools. Continuous defrost cycle?
Good day,
Sounds more like the compressor trying to start and can't.
Pull the machine out, remove the rear cover and see if in fact the sound is coming from the compressor.
Apr 08, 2010 | Whirlpool Refrigerators
Buzzing and clicking sound every few minutes
Compressor start relay - white plastic part - sitting right on the compressor, disconnect it shake it - u'll here it if it's damaged. :)
Oct 01, 2009 | Jenn-Air JCD2389G Side by Side...
My samsung rf266ab refrigerator is making a buzzing sound that lasts from five to ten sec. Althoug it seem to work fine is anoying, what is the cause?
Sounds to me the dual water control valve is becoming defective. Thats the sound when it sends a signal from the ice maker and the valve coil is just too weak to open the valve. Hope That answers your question, Thanks, Sea Breeze
Aug 15, 2009 | Samsung Refrigerators
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Refridgerator is clicking on loudly then buzzing and sizzling
I bet the Iemaker arm has been turned on allowing th eicemaker to cycle every 10-15 mins when the icemaker calls for water it causes the water valve to open. with no water connected to the unit the valve buzzes loudly causing your noise. make sure the icemaker arm is in the up position thus turning the i/m off thanks peyton
Mar 22, 2009 | Refrigerators
Maytag MFC2061HES Not cooling Either Fridge or Freezer
Replace the relay on the compressor and it should start working.
Jan 12, 2009 | Maytag MFC2061HES Stainless Steel French...
Freezer and refrigerator not cooling. Makes a buzzing noise
hello sbarrry2 it sound like the motor that is running continously is the condenseer fan and the buzzing and then the click would be the compressor trying to start up and going off on overlaod. shut the unit off at the swiutch, let it cool down (3) hours possibly and then try to turn it back on. this should work. Thanks for using FixYA
Dec 26, 2008 | Maytag MTB1891AR Top Freezer Refrigerator
Buzzing intermittent
It sounds like the ice maker. If you don't have the water hooked up, and the ice sensor bar is in the down position, the ice maker assembly will attempt to make ice continuously.
Solution is easy: raise the ice sensor bar until it clicks in the up position. It will lock in this position, and the ice maker will not cycle anymore.
May 04, 2008 | Amana ABB2227DE Bottom Freezer...
Refrigerators Logo
122 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
