Question about Archos 705 WiFi Portable Multimedia Player
Archos av700 screen has yellow/green tinges
HI Am getting yellowing/greening where should be white on recorded dvds. Am i doing something wrong? They are genuine dvds.
I know this may sound weird but put it screen down for 24hrs i had the same problem after i did that it went away
Posted on Jul 08, 2009
I just hooked up my Flat TV to my Panasonic VHS-DVD recorder player and the screen only shows blurry Black and White when displaying or recording, The TV itself is fine.
Sounds as if you hooked up your player wrong. If you are using a composite hook up. You should have a yellow, red and white cable. Make sure it gets hooked into the same on the TV. If it is a component connection, then RED, Green and Blue. It sounds like you have your Yellow composite going through your Green component. If by chance your TV is a new Sony, then you might have to go into the user menu and turn component off and composite on.
Apr 05, 2011 | Televison & Video
I have hooked up all cables correctly however when i attampt to record of my xbox i get black and white record screen ive tried 3 diffrent record program im using the HD componet cable (blue green and...
Greets - You are mixing cables up. You need to connect the Dazzle yellow, red, white cables to the yellow, red white cables on the TV. You can't plug standard video/audio cables into the component (red, blue, green) connectors on the TV.
take a look at this diagram, just pretend the devices on the left are all connectors on your TV.
http://www.pinnaclesys.com/presskits/Dazzle/DazzleDVD_Recorder_ReviewersGuide_May06.pdf
Good Luck, Mikeywaf
Mar 03, 2011 | Pinnacle Dazzle DVD Recorder
Are there any updates for the AV700 tv
go to link # 1 and scroll down to Operation in green , click on How do i update the firmware on the AV700 TV? read it . this is the firmware update link # 2 KEY NOTE you might be able to find the problem you have on the first link
# 1 http://www.archos.com/support/support_tech/faqs/en/faq_AV700TV.html?country=us&lang=en
# 2 http://www.archos.com/support/support_tech/updates.html?country=us&lang=en
Sep 24, 2010 | Archos AV700 TV Digital Media Player
Dvd player plays with yellow tinge
If you are using a scart connection, check that it is plugged in fully & straight, also check for bent or missing pins.
Sounds like you have no green input.
Jun 06, 2008 | Televison & Video
Archos 705
Make certain the cables are going into "in" sockets, The Red (right audio) White (left audio) Yellow - video. If the TV has a scart socket on you can get a scart to phono leads with the same combination sockets red, white, yellow.
Oct 03, 2017 | Audio Players & Recorders
LCD screen stopped working
sounds like the LCD screen viewfinder may have been twisted or accidentally catched or got hooked or snagged on on something at one stage and pulled something, if the screen went yellow it means the three wires going to it are possibly broken or the small white clip was slowly coming undone inside the Viewfinder for the red and green to no longer work to complete the image also indicates why the buttons on the viewfinder are not responding, try twisting the viewfinder very lightly whilst on, but most likely the small white clip holding the wires has come off at the elbow inside the camera
Apr 22, 2017 | Sony Handycam DCR-HC21 Mini DV Digital...
AV700 wont even turn on
have you tried resseting the unit?
Mike
Dec 23, 2007 | Archos AV700 Digital Media Player
Too much yellow in picture
The problem with the set is that the blue gun has gone weak, and not emitting at par with red and green guns in your picture tube. Turn of the blue screen and get the grainy display on the screen (detach the cable) and enter into service mode to fine tune until you get a perfect or black and white grain pattern.
Dec 19, 2007 | JVC AV-27230 27" TV
Archos 700
1. Connect the archos to the TV ( using the 3 leads red/yellow/white into the TV or DVD player) and the other end of the lad, a single jack into the back of the archos mini set-top box. Plug the single jack into the "RV Output". 2. Then start playing a movie on the archos. 3. Then press down on the flat silver button on the top of the archos device. Your screen should turn black/blank. This means your sending your movie to your TV. 4. Tune your TV to find the Archos movie in the same way you would tune your TV to find another pay TV set-top box ( like cable TV or Satelite). Problem solved.
You can use the same steps to send archos music to your steroe. Just plug the audio leads (white & red) into your stereo instead of your TV.
Oct 09, 2007 | Archos AV700 Digital Media Player
Archos 705 WiFi Portable Multimedia Player Logo
80 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
