Screen turns black when adjusting brightness
Laptop screen goes black when trying to brighten using ac power
  • Anonymous May 25, 2009
    Mine also turns black when I tried to adjust it. This happened since my lcd was changed becuase of another problem. The dell technician said i just need to install the OS. I tried it too, but the problem stay...
    Any help?
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Hi there.
    Please can you tell me what your doing to adjust the brightness and how your doing it.
    kind regards
IT-800-EC-35. How do I brighten the screen?
Adjusting Display Brightness You can use the following procedures to adjust display brightness to make it easier to
read under different lighting conditions.
Press the "Fn" key and then press the "5" key or "6" key after con? rming that "F"
is displayed in the lower right corner of the screen. Pressing the "5" key adjusts
brightness for a darker display, while pressing the "6" key adjusts brightness for a
lighter display.
In order to continue to make adjustments, press the "5" key or "6" key again after
? rst pressing the "Fn" key.
Brightness settings can also be made by navigating to the menus and tab in order of
Start ? Settings ? System ? Backlight.
The manual is here:
Casio IT 800 Series User Manual
Aug 04, 2015 | Casio Computers & Internet
Why laptop screen goes black after plugging battery charger?
Try another charger and then see or it might be a power options issue
Try this
SOLUTION: If you have a second computer, use Remote Desktop by choosing 'Run', type 'mstsc', type the name of the computer with a black screen, and connect. After logging in, open 'Control Panel', and choose 'Power Options'. On the left panel choose 'Choose when to turn off the display'. On the row labeled 'Adjust plan brightness', under the 'Plugged in' column, turn up the brightness slider.
Aug 10, 2014 | Sony SVE15135CXS - VAIO E Series...
Emacine is dim want brighten it up
Hi, click on your battery logo at the bottom right hand side of your screen.
Once clicked, select adjust screen brightness or more power options.
In the box of more power options, you can adjust the screen brightness with a sliding bar at the bottom of the box.
Hope this helps
Mar 09, 2012 | eMachines Computers & Internet
How do I turn up the brightness on a HP Probook 6550b?
PLEASE RATE ME!
go to the search icon under start. search brightness. it will tell you step by step what to do.
Every laptop is different, so adjusting the brightness or contrast on your laptop may vary from the steps provided on this page. However, understanding the process of how to adjust the brightness or contrast will help you change your settings.
Most laptops adjust their brightness and other settings using the function key in conjunction with another key. For example, pressing and holding the function key (abbreviated as "Fn") and pressing the up or down arrow keys as shown in the picture below, increases and decreases the brightness.
May 09, 2011 | HEWLETT-PACKARD HP ProBook 6550b Notebook
I have a dark screen with ac cable plugged in, when I unplug from back of laptop screen brightens back up like normal. What wrong? I also have a light on at top of laptop looks light the #9 within a...
your first step:.it sounds to me like your power settings for your AC go into control panel click on power options and check that your ac power profile has the brightness turned up enough , try pressing default configuration this should put it to normal, let me know if this works.
hope this works
Feb 03, 2010 | Dell Latitude D810 PC Notebook
Screen is dull while on ac power. When running on battery screen brightens up but battery does not last long. Power supply is supplying 19.17 volts which but on the power supply is written 18.5 volts.
ery adjusting your brightness via the function keys on the keyboard also under power settings see if screen is set to save energy when using ac power usually this is set to save power when on batteries it just might be reversed on your machine
Dec 12, 2009 | HP Compaq nx9110 Notebook
How do you make the lighting on the screen brighter without the charger in ?
The screen will automatically dim slightly when it is on battery power, this is to conserve battery power. For maximum brightness connect the power adapter into the laptop.
On the Thinkpad laptops you can adjust the brightness by pressing and holding down the blue Fn key plus the Home key to brighten or the End key to dim the screen.
Nov 26, 2009 | Lenovo ThinkPad T61 Notebook
Screen IS black, BUT EVERYTHING ELSE IS OK
there is a invertor in LCD. it makes your lcd bright white shine. if it doesnt work you can have dark view. i mean something going on the lcd but you cant see clearly. take to tecnic service your computer.
i hope it works.
May 27, 2009 | Dell Inspiron 1501 Notebook
Dell laptop screen goes blank when ac adapter plugged in
I believe I have found the problem with the 1525 that I am currently working on which has the same problem that you describe. Ultimately I think it's a problem with the inverter in the LCD. When the laptop is powered by battery the brightness is lower than full. When I plug in the power adapter the brightness goes to "full" and I hear a faint sizzle and the LCD's backlight goes off. Same as if you hold the Fn key and press the up arrow to brighten it, it will do the same thing when you reach near the full brightness. So for now I have fixed this problem by going in the Power Options and clicked on Adjust the display brightness on the left. Slide the slider to the left on the "plugged in" part and now when you plug it in it shouldn't make it go blank. I do want to note that I hear a faint buzz coming from the LCD when I plug it in. That must mean the inverter is faulty. WAY TO GO DELL!!!!!!
May 23, 2009 | Dell Inspiron 1525 Laptop
Display brightness
Ok on your keyboard there should be some way to adjust the brightness just plug in the laptop and adjust it to what you want then unplug the laptop and adjust it to what you want and it should keep that setting. if that does not work you can check the bios settings some laptop bios' have a brightness option.
Dec 06, 2008 | HP Compaq Presario R4000 Notebook
Computers & Internet Logo
1,111 people viewed this question
David Payne
David Payne
