Question about Brother MFC 210C All-In-One InkJet Printer
Brother 210C Printer won't print
I didn't use my printer for about one year and recently put new ink cartridges in it to start using it again. I ran the cleaning mode (both regular and power cleaning in maintenance mode) and it still doesn't print. The paper comes out and I can hear the head moving, but there is no ink printed.
    Problem Solver:
I had that problem and overcame it. I think I let it clean a few times and eventually, it worked. I think I also removed/replaced the cartridges.
Brother's solution Center might help.
Posted on May 22, 2009
I bought a Brother MFC 210C Printer - Fax - Copier a few years ago, when it ran out of ink I stopped using it for awhile. I just bought new ink cartridges, took the tabs off and put them in and they are...
Perform reconnection inspections on the printer. Attempt to printer documents. The computer should diagnose the condostion either as missing programs or malalligned printer ink or paper or compartments not closed appropiately.
Jan 29, 2011 | Brother MFC 210C All-In-One InkJet Printer
Problem with my Brother MFC 210C Printer won't print the colors.
Check your ink cartridge if they are properly installed.
Check your print settings.
Make sure your ink cartridge are not empty.
Replace your ink with the original Brother ink cartridge.
Sep 08, 2009 | Brother MFC 210C All-In-One InkJet Printer
My Brothers MFC 210C All-In-One Inket printer is printing blurry. It has been used in a year. I changed the cartridges and ran the cleaner but it still prints light and blurry. What can I do? Thank you.
keep on printing the catridges will satrt function well after few prints if they have ink and heads are ok , if not take out cartridges shake them well chek head are leaving ink on a tissu paper if not place cartridges under runing water tap clean their heads and dry them with tissue paper and place them again nowi think they will work i
let me know your reply sitehr@gmail.com
Aug 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
Borhers does not print
printer says cyan cartridge needs replacement, however when I replaced it, it says that there is no cartridge.
Betty
Nov 18, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C won't print
I have cleaned, retested and new ink and it still will not print Black
Jul 11, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC 210C NOT Not Printing Color Properly
If the cartridges were in the wrong slots, it shouldn't take very long for it to clear up. What I don't understand is how it even ran with them in the wrong slots, but that's not the point.
Having corrected that problem, Have you run many prints after that? You may just have some remnant ink not completly out.
If thats not it, remove the cartridges, unplug the machine and very lightly dampen a lint free cloth with some alcohol and clean all the contacts in the machine and one the cartridges.
Then again run all the set up modes and see if that helps.
You should in no way have ruined the printer my having the inks in the wrong place.
One other thing you can try, And I do this to ink jet printers but hesitate to mention, but it does work.
Unplug the machine and remove the cartridges. Place some paper towels under the print head where the cartridges and slowly trickle some soapy cleaner, Like Fantastic into that area, then flush it out with some rubbing alcohol. Dry the area gently as best you can, and let the printer sit an hour or so to let any slight amount of liquid remaining to evaporate. Those inks can build up and clog that area causing lots of problems.
Feb 25, 2008 | Brother MFC 210C All-In-One InkJet Printer
Black ink won't print at all
Run the cleaning process a couple of times.  The printhead might have gotten sucked dry.
Oct 30, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother mfc 210c printer
Check ink cart if it is well placed into the ink cart assy. Do the cleaning procedure by pressing INK skip the arrow-button down until CLEANING is displayed. Press start mono (blue button). After cleaning cycle you are asked by machine to print a quality test sheet. Do so and follow display instructions. Do the cleaning procedure a max of three times! When there still is no BK the printhead either is clogged or dryed out. Sorry, this cant be fixed anymore.
Oct 09, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
216 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
