Question about Nintendo Pokemon Pearl Version for DS
DS not connecting to action replay software
I loaded the sofeware from the disk but when I connect the USB cable to the PC and the Action replay the software doesn't recognize that the DS is connected. ARGG MY COMPUTER WON'T RECOGNIZE THAT MY AR IS CONNECTED HELP ME!!!!!
    Problem Solver:
  • 10 Answers
Try changing the port of your usb
Posted on May 29, 2009
Action replay doesn't let me add codes in custom code list!!!!!
Your Action Replay DS hardware may require resetting if you are experiencing any of the following problems:
* Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes.
* Code Manager PC software is reporting the console`s battery is low when it’s actually fully charged.
* Multicolored bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes.
* You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error.
If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased.
1. With your console powered off insert the Action Replay DS
2. Hold down buttons A+B
3. Turn your console on
4. With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down
5. Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen
6. If Action Replay DS doesn’t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again
Aug 03, 2009 | Datel Action Replay for Nintendo DS
My ds wont accept the ards. My other ards wont put any new games in the bottom screen it goes blue and red?My computer (windows vista)doesnt accept my ards
Your Action Replay DS hardware may require resetting if you are experiencing any of the following problems: * Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes. * Code Manager PC software is reporting the console`s battery is low when it?s actually fully charged. * Multicoloured bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes. * You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error. If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased. With your console powered off insert the Action Replay DS Hold down buttons A+B Turn your console on With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen If Action Replay DS doesn?t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again whats an ard? from code junkies
Jun 13, 2009 | Datel Action Replay for Nintendo DS
My action replay zeroed out.
the ds cartridge need to be reset.
do it by using this method.
you can tell if it needs resetting by;
Jun 09, 2009 | Nintendo DS Lite Console
Action Replay does not find DS Lite even though USB is connected
theres 2 little metal strips on the AR USB connector, you have to carefully snip them off their furtheest to the end on each side. that will fix your problem
May 03, 2009 | Nintendo DS Lite Console
My Ds Action Replay Went BLANK!
i have had a similar prob it wiped all the games andm then i could not put more on because it went multi coloured when i tried so i hap to reset the entire thing to do so(source codejunkies):
copyed from code junkies
Mar 20, 2009 | Datel Action Replay for Nintendo DS
My DS action replay is broken
If you hold A B START AND SELECT at the same time, with the power OFF, then turn it on with your thumb or something and let go when it says the product isnt endorsed with nintendo. hope it works good luck =)
Feb 06, 2009 | Datel Action Replay for Nintendo DS
Action replay when i plug in my ds and load code manager it says waiting for ds even though it is plugged in
IF you are running Vista 64, the issue is the driver on the disk is incompatible, thus the pc will never see the ds. However, I have found a workaround. First make sure the DS is on and plugged in and the Action replay Manager is launched. On the DS click on the mouse so it should read updating software. Then, go into device Manager via the Control Panel, there you will see NDS and an exclamation mark. Right click and choose to update the driver or properties. Then choose Browse My computer for driver software... then let me pick from a list... then fo the manufacturer shoose: Standard USB Host Controller and for the Model choose Unknown. It will pick it up instantlly. Voila.. Good Luck! and what a pain!! V
Aug 21, 2008 | Datel Action Replay for Nintendo DS
Can't get codes
I have just found the solution to the problem (2 minutes later XD)
Quote CodeJunkies' Support site:
Try resetting the Action Replay by following these steps:
  1. Insert the Action Replay into the DS
  2. While the Action Replay software is loading, press and hold all the following buttons: A + B + Start + Select.
  3. Release all of the buttons once the Action Replay is at the main menu.
The first screen should persist for much longer than normal, and when the Action Replay DS main menu loads, your hardware should be reset.
Once the reset has been performed, try connecting the USB cable to your PC, opening up the code manager software and transferring data again.
It won't return all of your games back, but it will allow you to start on a clean slate again. (Using the update feature will bring most, if not all of your games back
Aug 20, 2008 | Datel Action Replay for Nintendo DS
Well i had the same problem but i know how to solve this, at first when i plugged in the AR to the computer and press the update button on the DS, it wouldnt work and it would ust please connect... meanwhile on the AR manager it says, waiting for .... DS, the way i solved it is to unplug, not from the DS, but from the computer the USB and put it in to another one.... after that a window came up, u have to install itand then go on Ar manager, there should be something in the other window that says, NDS. this is where u drag the cheats... hope i helped :)
Jun 13, 2008 | Datel Ultimate Codes: God of War II
Nintendo Pokemon Pearl Version for DS Logo
137 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
