Question about Teac AD-600 3-Disc CD Changer
The CD player on my Teac AD 600 produces significant noise and distortion. The tape player works fine. I tried a cleaning disc but got no improvement. Any ideas?
  • mdiamond9 May 22, 2009
    All discs have the same noise and distortion (including the cleaning disc). Plus, I can't figure out how to get into the mechanism to see the lens.
    Brigadier General:
  • 3,614 Answers
HI there,
Have you try to test it by changing a different disc?
If the problem happen on all the disc played this can be a damaged optical lens on the unit, a scratch on the lens that makes the optical lens hardly read and causing this kind of problem.
Let me know for any further clarification.
Posted on May 22, 2009
  • micromaster
    micromaster May 22, 2009
    a.. Shut off the power.
    b.. Remove the housing screws either on the side or bottom or both.
    c.. Slide the housing away from the front panel. Some units require the
    removal of the front panel in order to reach some parts.
    d.. The tray front can then be removed
    e.. Check along the panels edges for any tabs or screws that secure the front panel.
2002 acura tl type s cd player works but sounds distorted, everything else plays and sounds fine?
thats a lazer problem in the cd usually a cd cleaning disk will sort that problem if not a its the lazer head thats distorted best this to do it put a conversion tape to ipod or iphone and play your tunes off those devices via your tape, there only cheap to buy.
May 04, 2014 | 2002 Acura 3.2TL
Cd tray stuck
The tray may be jammed, or the timing gear is out of sync, or a broken loaing belt.
Apr 26, 2012 | Teac AD-600 3-Disc CD Changer
3 disc Phillips cd player sometimes skips. It is
At some time in its life, the laser that reads the CD starts to get too weak to operate reliably. That's probably what's happening here. Unlike mechanical parts that can be inspected for wear, electronic parts tend to work fine one day, then the next, poof. The laser assembly is replaceable if you can locate the part and find someone to install it. An electronic service shop could give an estimate for repair. If you can provide the full model number, I'll see if I can find the part number.
Mar 08, 2010 | Teac AD-600 3-Disc CD Changer
Teac mcd78 cds spin but do not always play
The lazer unit in this stereo is hard to get at, 2 circuit boards have to be removed to access lazer lens to clean it. Do not attemt unless you feel up to the task.
When you get to lazer lens, spray a bit of window cleaning liquid on a cotton bud and flick off the excess. then gently wipe the cotton bud over the lens. next use the clean end of the bud and gently polish the lens.
This may solve your problem. If not, there is a "cheat" you can try to overcome this issue... on the side of the lazer assembly there is a pot for adjusting the lazer power. Carefully nudge the pot anticlockwise a tiny bit. This will increase power to the lazer to help overcome the problem. **NOTE: do not adjust the pot too much or you may damage the lazer beyond repair**
Jan 20, 2010 | Teac AD-600 3-Disc CD Changer
Why does Burn't Audio CD not play on some CD Players
because the codec's are different, if you have ever burned a avi file and it didnt play till you added say divx ir xivd to get it to play tech leaves out alot of the codec's so there system will work on most but not all cd's dvd's the only way around it is to find out which codec will work for that player to test what I have just told you take the cd to the store and try it on a different mechine and see if it works
Jan 14, 2010 | Teac AD-600 3-Disc CD Changer
Panasonic DMR E20 Produces a line of distortion along the bottom
Sounds like you see head switching from the tape. Most TV are over scanned enough to hide it.
Aug 30, 2009 | Panasonic DMR-E20 DVD Recorder
Cd doors won't open
Hi...Make sure its unplugged and take the top case off. Check for items that arent supposed to be there like a CD floating around inside.
Or a cookie.
I'm not sure if this unit uses a belt for the drawer but check on that whilst youre in there
May 08, 2009 | Teac AD-600 3-Disc CD Changer
Teac PD-1200 Compact Multi Disc Player
Hi
I think that we can get at least one of them going again :)
I suggest
  1. take the lids off both of them.
  2. load up some Cd's and close the drawer and watch what happens.
  3. does the disc begin to spin, is not, do you hear any noise as it tries to read each disc.
  4. can you kick start the CD when it first loads(clockwise direction)
  5. if not of these things happen, can you see if the transport loads the cd up off the tray.
While you are in there, with the front drawer open you should be able to see the laser lens. Use a cotton bud moistened with windex(glass cleaner) gently clean the lens in a circular motion and then also polish it with a dry one to be sure you have left no smears on the lens. Then.... try the unit again and see if the CD reads.
If you don't have any luck this far, please post back to me and we can try some other things. All this and you give me a FixYa... YAY :)
regards
robotek
Jul 04, 2008 | Teac CD-P1120 CD Player
CD will not rotate.
The spindle motor may have failed. Can you try 'starting it off' by hand after inserting a CD?
Jan 25, 2008 | Teac AD-600 3-Disc CD Changer
Teac AD-600 3-Disc CD Changer Logo
62 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
