Question about Nokia Consumer Headset
No tone unless speaker is used.
My N95 gives no tone unless I use the speaker option on the phone when making or receiving calls I have a new nokia N 85, bought it Jan'09..everything was working fine but the last few calls I made I can't listen to anything on handset mode while making or receiving calls, no voices, sounds or dial tones.
I can only hear sounds etc if I switch on the loudspeaker.
What is wrong with it?
I also tried restoring it to factory settings. It didn't help.
Neither did changing the sim card, restarting the phone or taking out the battery and putting it back after a while.
Please help!
  • winwin1009 May 22, 2009
    oops...the 1st sentence is a typo! :)
Have you changed the fasica? if so you may have disposed of the speaker as it sits in the old fasica
where the grill is
Posted on Jun 01, 2009
No message alert
I dont receive alert tone and vibration when i receive any sms?
Jan 20, 2011 | Nokia E52 Smartphone
My n95 keeps making an engaged tone and saying 'diverts active'? how do i stop it?
Its showing Active diverts because your call diverts is active. May be you have set a call diverts where if you are unreachable your calls gets transfered to voice mail. To deactivate Active diverts. Go to Tools -> Settings -> Call Diverts -> Options -> Cancel all diverts
Hope this helps.
Oct 20, 2009 | Nokia N95 Cellular Phone
Distorted sound when using handset to answer calls
All you need is a new speaker unit, these cost between £2 and £10 on ebay. remove all 4 screws blow the screen slide bit, carefully pop of the screen surround and prise out the old speaker and insert the new one. Rebuild phone. Fixed.
Sep 27, 2009 | Nokia N95 Cellular Phone
Frozen N95
kindly reset like below or pls update ur phone firmware from NOKIA download update application from www.nokia.com for ur mobile N95 and it will help u in this software issue
but pls first try to reset the device like this it may resolve it
and RATE ME WELL !
Option 1
Press Call + 3 + * simultaneously during the bootup phase, forces the N95 to do a complete wipe of internal memory.
This will reset the phone back to 100% standard factory configuration.
Option 2
Master reset
1) *#7370#, then enter 12345 (This is the default security code unless the user has changed it) and then Yes. The phone then wipes all apps and phonebook contacts on the internal memory.
May 19, 2009 | Nokia N95 Cellular Phone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
N95 tones
Changing the dial/caller signal is not something you can do on your phone, only Network providers can do that.
Jan 28, 2009 | Nokia N95 Cellular Phone
NOKIA N95 openingand closing sound clips automatically
You can try to have your battery out for over 1 minute.
Reset factory settings.
Then there is an option for soft format which will erase all info stored on phone and reset phone to it's original settings.
If no go, Nokia might have a new SW for this issue, probably you are not the only one who experience this.
Oct 17, 2008 | Nokia N95 Cellular Phone
Speaker Active
when making a call just press the option and select speaker
Jun 14, 2008 | Nokia N95 Cellular Phone
Nokia Consumer Headset Logo
140 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
woodzowl307
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
