Question about Samsung PCL541R 54" Rear Projection Television
SAMSUNG TV MODEL # PCL541R bulb not working
Hello, seems like my samsung PCL541R needs a replacement lamp but I am unable to find it anywhere online. Any recommendations where to find it and approximately how much it will cost to replace the lamp?
Thank you.
    President:
  • Samsung Master
  • 1,779 Answers
With the model number you gave, it comes back to a 2002 model in which DLP sets were not out yet. That's a conventional projection set with 3 picture tubes. Check the model number again?
Posted on May 22, 2009
Lamp idiot light flashes along screen will not come on also went on and off for awhile before quiting completely on Samsung model hl-p4663w
does the TV bring out sound even as the screen display is dark?
How long have you been using this TV and have you ever changed the lamp/bulb? Problem should be from the TV lamp/bulb.
Have the lamp replaced and hopefully, your screen should be perfect as before.
Let me know if you need directions in replacing the lamp, even though it is very simple replace.
Yours sincerely.
Elect_Comp.
May 15, 2011 | Televison & Video
Hi, I have a Samsung DLP HLR5667WAX. My bulb just blew and it says it's a L620 BP61-01025A. I can't seem to find this bulb anywhere, does anyone know if the holder plus housing lamp is listed under a...
Hi,You won't be able to find that part # because its not a correct part # it's just one of the #s you can find on the housing.Your part # is BP9600826A and samsung was either putting a small and square lamp or big and round.You will need to pull it out and check which one you need.If you don't want to get lamp by itself simply buy it w the housing and it won't matter which one you get.You can find it here: http://www.discount-merchant.com/Samsung-BP96-00826A-Lamp-Enclosure-p/samsung-bp96-00826a-lamp-enc.htm?Click=48173
Apr 08, 2010 | Televison & Video
My samsung hdtv is really dark not matter how i try to adjust the tv.
Hello! In this case, it can be two things either your lamp si goping out, or the ballast is. They're not that expensive http://www.discount-merchant.com/SAMSUNG-9137-008-22705-Lamp-Ballast-Driver-p/1138029.htm/?Click=48427 Of course you need to get the right part number. http://www.discount-merchant.com/Samsung-HLN5065W-OEM-Replacement-LAMP-BULB-p/samsung-hln5065w-lamp-oem.htm/?Click=48427 also for the lamp you need to get the right one you need.
Dec 06, 2009 | Samsung Televison & Video
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung projection tv
This is most likely a convergence problem. Does the picture look like 3D? If so, please confirm that the model is PCL541R and I'll rpovide additional details and instructions.
Dan
Sep 24, 2008 | Samsung PCL541R 54" Rear Projection...
HLP5067W Going on and off
Sounds like the bulb needs to be replaced. With the tv you have the Bulb last about 6000-8000 hours. If you think that is about right then you it most likely is time ro replace. You should be able to find the replacement bulb from the manufacture and then find it online to purchase.
Sep 20, 2008 | Samsung HLP5067W Television
Bulk Life
Identifying the correct lamp code
Before placing an order online, you must identify which lamp code you need. The lamp code is located usually on the left side of the TV
http://fixyourdlp.com/blog/?cat=4
Jan 16, 2008 | Samsung DLP HL-P5663W 56" TV
Hot to test tthe lamp bulb Samsung tv
bad lamp will cause 90% of problems you can take it out to see if it is broken filament is usually shattered
Oct 07, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung PCL541R 54" Rear Projection Television Logo
292 people viewed this question
Henry  Thomas
Henry Thomas
