Question about PC Chips M871G Motherboard
Connecting Power SW ec..
I've a problem dealing with the POWER SW Pins etc..
Because i don't know how to connect them rightly.
I've got no manual, and nothing found on the internet what could have help.
May you help me out?
Kind Regards
BigEll
  • bigell1 May 22, 2009
    Hm that's the problem.
    My Motherboard named "M871G v.1.5" but it doesn't got those coloured pins , and they are labeled, either.
  • PC Chips Master
  • 4,806 Answers
Hi there.
On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW.
Have a look at these pictures for an idea >>>>>>
Please post back with the results and any more advice if needed.
Good luck and thanks for using FixYa!!
Posted on May 22, 2009
  • Lee Hodgson
    Lee Hodgson May 22, 2009
    Hello again.
    I have found the installation manual for you, just click on this link or copy and paste it into your browsers address bar and save the pdf document to a PC >>>>>>
    motherboards.xdrivers.info/?file=5&sort=1
  • Lee Hodgson
    This link will probably work better for you >>>>>>
    http://motherboards.xdrivers.info/?file=...
Dont know where i can put the power sw so how is going
Go to this link and download the motherboard manual. It will show what header pins on the board attach to your various panel connections.
ECS Web Site 945GCT M3 V3 0
Aug 18, 2014 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
H61H2M2 Motherboard F_panel
Hello the manual can be downloaded here:
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?detailid=1228&MenuID=0&LanID=0
Hard Drive Activity LED
Connecting pins 1 and 3 to a front panel mounted LED provides visual indication that
data is being read from or written to the hard drive. For the LED to function properly,
an IDE drive should be connected to the onboard IDE interface. The LED will also
show activity for devices connected to the SCSI (hard drive activity LED) connector.
Power/Sleep/Message waiting LED
Connecting pins 2 and 4 to a single or dual-color, front panel mounted LED provides
power on/off, sleep, and message waiting indication.
Reset Switch
Supporting the reset function requires connecting pin 5 and 7 to a momentarycontact
switch that is normally open. When the switch is closed, the board resets and
runs POST.
Power Switch
Supporting the power on/off function requires connecting pins 6 and 8 to a momentary-
contact switch that is normally open. The switch should maintain contact for at
least 50 ms to signal the power supply to switch on or off. The time requirement is
due to internal de-bounce circuitry. After receiving a power on/off signal, at least two
seconds elapses before the power supply recognizes another on/off signal
Good luck
Nov 24, 2012 | EliteGroup ECS H61H2M2 Intel H61 Sandy...
Where doe's power led,power sw,hdd led on my e-machine
You will need the user's manual for your machine to make sure that you are hooking the wires up correctly. However, most motherboards label these connections directly on the motherboard next to their pins.
Look for an area on the mother motherboard with two rows of six to eight pins. Next to them you should labels such as PWR_SW (power switch), RST_SW (reset switch), HDD_LED, PWR_LED, etc. You won't mess anything up connecting something to the wrong pins, but it isn't that hard to figure out as the wires are usually labeled in the same manner as the pins. So HDD_LED would plug into the HDD_LED pins, PWR_SW to PWR_SW, etc.
Jun 30, 2012 | E-Machines Computers & Internet
Hi sir the problem which i am facing is that i unplugged the 4 pins which are these rest sw,power sw, hdd led and + and - now i forgot how to place it back in right sequence so plz help me out thanks.
Hello myasinmalik,
this is a [Picture Diagram] of the {PIN Sequence], in the order of "Connections."
!Warning: "Before disconnecting, or connecting: Cables, Wires, Power Supplies, or Pins!"
"Unplug "All Power Sources" from {'Wall' AC - Power Outlets}."
This can cause "Injury to Persons, and or Damage to Equipment."
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Feb 23, 2011 | Mercury P4VM800M7 Motherboard
I need help connecting the power on cable and led cable as well as the hard drive light cable. for my emachine w3644
These cables are attached in the lower right corner of the motherboard. There are two rows of pins there. Probably 10 pins in all. They should be marked with letters something like hdled (hard drive LED), pwr (power light) pwr sw (power switch) spk (speaker) etc. Anyway, if you can't find markings, hooking the little plugs up to sets of the pins one plug at a time will tell you which works.You can't hurt anything by trying various combinations
Feb 13, 2011 | E-Machines Computers & Internet
I don´t have the foxconn motherboard manual "661m08"
Most mobo's have the connection points printed on them. Use a strong flashlight and look for some pins that have the following words printed near them (PW or PWR, RS or RST, HDD LED, etc) They should all be grouped together in the same corner of the mobo. Have you tried googling the motherboad name to find a manual? I have done that on a few occasions and got lucky.
Apr 30, 2009 | Intel Motherboard
I'd like to know the sequence to connect the following connectors:power sw, reset sw, power led, hdd led from the front panel to the motherboard (motherboard foxconn sis 651 m03. Thanks West
If your board is the one in this manual, the pins are located very close to the CMOS battery. Page 21 in that manual shows the diagram. Power LED is the top two left pins. Hard disc LED is the bottom two left pins. Power switch is the top two right pins. Reset switch is pins 3-4 on the bottom row. Pin 5 on the bottom is not used.
Apr 27, 2009 | Foxconn Computers & Internet
MY COMPUTER WONT TURN ON !!!
for connecting these sw
just see on mother board there you see nearabout 16 pins on right hand bottem of mother board
there you have an integation of connectorfrom right hand corner i.e 1-3 for reset sw, 2-4 for power sw and last switches for front usb and audio
if you have p-3 then you dont attech audio and usb cables on *********** board
Apr 07, 2009 | Computers & Internet
Connecting the case to my motherboard
Pin arrangment is Industry Standard Architecture.....
pwr led pwr sw N/C
X X X X O
X X X X O
hdd rst N/C
translated this is top row left to right ...... power led, power switch no connection
Bottom row is left to right........ hard drive, reset, no connection
Note: not all computer cases have a reset button, also the connectors for power led and hard drive produce a light, if the light does not show, power off the pc swithc the cable rooun 180deg on the connector pins and reconnect.
Dec 04, 2008 | Computers & Internet
PC Chips M871G Motherboard Logo
277 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
