Question about Sony Playstation 3 (PS3) Console
Lines on tv and a buzzing noise when the ps3 is turned on
I have tried it on different tvs and different inputs. I even bought a new chord to plug into the tv and the same thing happend so it isnt the chord or tv
  • b2luek92 May 22, 2009
    thank you i figured that was probably it, but i was hoping not
I had the same problem and I needed to get an adapter for it to convert the plug from a 3 prong to a 2 prong. Basically to take the groud out and it works perfectly.
Posted on May 30, 2009
    Problem Solver:
  • 5 Answers
Then the only thing left to deal with is the system what you can do is send your system to the sony department and have them do a service check to see if anything is wrong with your ps3
Posted on May 22, 2009
    Problem Solver:
  • 8 Answers
You also could try making sure the tv is on the right settings and that everything is plugged in correctly
Posted on Jun 01, 2009
NS-LDVD32Q-10A buzzing noise
Try another input and another source such as a DVD player. If you still get the buzzing sound, you could have a faulty power supply output or a fault in the audio circuit of the main board.
Jan 27, 2013 | Insignia NS-LDVD32Q-10A LCD TV
Hdmi input not working
Did you switch the inputs to match the input you were on? The HDMI ports will be labeled 1,2,3 or something like that. With the remote select the input that you would like and that you are plugged into. That should fix the problem.
Oct 04, 2012 | Televison & Video
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
I have a 40" Apex LCD tv and for the past year
I dont know how to solve this but I have experienced the same thing. Two of my hdmi outputs dont work anymore.
Jan 08, 2011 | Apex Digital LD4088 LCD TV
I just bought a Singstar bundle but the mics provide a constant buzzing noise when activated. I've tried different usb hubs and blowing on the ports but didnt work. It is only when the mic's are activated...
We've had the issue since PS3 purchase. I read on another forum today about having plugged the PS3 in the same power extension block as the TV causing the issue. Though this was not the cause of our buzzing on the PS3, it lead me to the fiind the cause of my buzzing noise problem . The issue is caused by use of Power over mains ethernet adapters, in my case these are used to connect my BT Vision unit to the internet. As soon as the unit makes a data connection to it's master unit, the humming starts! We are just going to have to power the nearest adapter off when we wish to make use of the MICs on the PS3!
Jul 29, 2010 | Sony Singstar - PS3
My playstation will not shoe up on my tv..im at the hdmi chanel and its saying no signal??
hi def tvs may have 4 or 5 inputs for different things.
hdmi
cable
component1
component 2
try a different input on the tvs remote.or check where the x box is plugged into.
Jan 05, 2010 | Sony Playstation 3 (PS3) Console
PS3 hdmi only working on some displays
I have noticed using an HDMI cable that with some of the newer tvs you have to set up the tv also to enable HDMI for a game system. Like you said before internet tv and blueray dvd player work fine. Try adjusting the settings on the tvs themselves. I have a 50in DLP mitsubishi, and had a very troubling time getting my ps3 to work on that particular tv set while it worked flawlessly on other sets. And what I had to do was enter my tv setup menu and then power on my ps3 with both my AV and HDMI cables connected, it would pick up the AV first. Then I would alter the video settings on the PS3 for HDMI, and unplug the AV cable. Exit the tv menu and then reenter it. Then I had to setup my HDMI port from the tv to game in order for it to work, where you can set options ar usually like cable/dvd/sat, and so on. Without my TV being set to game that way it would not work. Try this and see if it helps. Good Luck.
Dec 21, 2009 | Sony Playstation 3 (PS3) Console
53" sony projection -picture washed out w/ green horizontal lines
It sounds like your Green CRT ( picture tube ) is shorted. That's the one in the middle. Sony had issues with there tubes in those years. Sorry for the bad news. Even if you could locate the tube, it will be a matter of time before the Red or Blue does the same.
May 03, 2009 | Sony KP-53S65 53" Rear Projection...
The Back plug of my 60 GB
Have you tried updating to version 2.2? It came out last night. Furthermore, can you try this on a different TV so that you can eliminate that as a variable?
Mar 19, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
195 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
