Question about Nikon N75 35mm SLR Camera
I forgot how to load the film
I haven't used my camera in a long time and I forgot how to put in the film. it usually auto loads once it is put in the right little cogs
  • 10,319 Answers
Battery contacts corroded? If so add a few drops of rubbing alcohol on the solder joints and the contacts. Let dry over night and try again with fresh batteries
Posted on May 23, 2009
I need a manual for Bell & Howell Lumina MX60 for an elderly person - need instructions how to load film.
Spec says it's auto-load. From what I recall of my own projector, you mount the input film reel on the front 'arm', extending it as necessary to give clearance, switch on the projector, then feed the free end of the film into the appropriate orifice at the front of the projector.
It then takes over, feeds the film through and wraps it around the take-up spool automatically. It may be necessary to cut the end of the leader on a diagonal to feed it in (not each time the film is loaded, just the first time.)
Once the film has fed through, switch on the lamp, focus and enjoy.
Dec 30, 2016 | Bell & Howell Cameras
Have Minolta 440si. It was 'dormant' w/o battery for several years. Wanted to use. Loaded fresh battery and film. No shutter operation at all. But,display is visible and auto film load and rew
If it has been stored for so long, the internal battery, which maintains the settings etc and is charged from the main battery, is probably defunct.
May 25, 2017 | Minolta Maxxum 400si 35mm SLR Camera
I have a 35mm nikon camera. I've changed the batteries but the film won't load. how can i load the film?
Here is what to look at: Custom Function number 8, "Auto film load when back is closed", default setting is 1 disabled on 0 it is enabled. If you have the manual for the F80 (same as N80) look on page 21 and page 72 and 73.If that is not the issue check the following: With the new batteries does the camera turn on, Can you focus, does the LCD light up? All that will let you know if you are getting power to the camera. If the answer is yes then the film should load so now check the inside of the camera back. Does it have the pressure are and roller next to the hinge. If that is missing then when you pull the film to the red dot, close the camera back there is nothing to put pressure on the film for it to load.
Aug 06, 2010 | Nikon F80 35mm Film Camera
Which buttons to push
1 You have to push the button to take the picture 2 Some of the cameras are auto loading. In that case once you take the picture it will move the film automatically. 3 If it is not auto loading then you have to move the lever to load film for the next shot
Nov 19, 2009 | Photography
Can't load the film
Turn the camera on. Open the back. Insert film, pull it across to the red mark. Close the back.
Camera should load automatically.
You can get the manual at http://www.butkus.org/chinon/nikon.htm
May 22, 2009 | Nikon N75 35mm SLR Camera
I loaded the film but display window shows a flashing zero
Go ahead and try anyway. A ruined film is far cheaper than a useless camera or a professional repair. In any case, if the film hasn't loaded properly it will only be the first short length of film which is ruined. As this is a newly loaded film you haven't any risk of losing any undeveloped photos.
Auto spooling film systems are great when they work, but sometimes are a real pain and some cameras seem really picky about having a film leader of precisely the right length. See if you can engage the the film onto the spool manually.
May 14, 2009 | Canon Prima Super 105X - Point & Shoot /...
Loaded film blank
Chances are the film had quite a bit of curl to it (often a sign of old film) and it was not pulled over quite far enough during auto loading, or perhaps too far and it had too much slack that the take up reel never grabbed it to advance it thru. You're not the first one this has happened to as the auto load is not as reliable as the older style where you had to load the film leader through a slot in the take up reel.
Dec 19, 2008 | Nikon F65 35mm SLR Camera
Fuji 35mm Camera (Model DL-400)
Dawn
remove the battery and check that it is good. replace battery and open back door, close the door and it should run the motor / transport. if so, load film up to the drive sprocket being sure film will catch on the sprocket.
or move the latch holding back cover, and open the door fully. check the pressure plate on the door, gently pull the plate up a little to increase pressure on the film. bring the holding lever out toward the latch and close the door to lock the lever back to position.
Jun 11, 2008 | Fuji Discovery 185 Zoom 35mm Point and...
Loaded film wrong??
I'm assuming you're not able to shoot pics. Its my best guess that the film just isn't getting loaded properly. Next time you attempt to load film there maybe a small red mark near the take spool (bottom edge where film goes) to indicate how far you need to pull the leader forward toward take up spool. I think the film isn't out quite far enough for the camera to do its auto load thing & when you close the back it goes thru its auto loading motions but the film just isn't getting loaded. Then close back & see what happens.
Apr 27, 2007 | Konica Minolta Maxxum QTsi with 35-80 lens...
Nikon N75 35mm SLR Camera Logo
123 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
