Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Screen went blank and now all that is left are the red, blue and green lines in the center of the screen.
  • Panasonic Master
  • 8,617 Answers
Thats a vertical deflection issue. Try replacing the vertical output IC
Posted on May 23, 2009
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
Green screen
If the lines you see are retrace lines, It means that the 200VDC are missing and not getting all the way to the video amplifier assemblies.
Did you touch the screen control settings by any chance before you replace the HV splitter?
Apr 14, 2008 | Proscan PS60690 60" Rear Projection...
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
I have a hitachi rptv model #43FWX20B and the picture has a red tint to it. Opened back up and red green and blue bulbs light up. red bulb stays bright while blue and green go dim to bright as tv plays....
Howdy;
Since you don't have any white lines with the red screen/picture I would say that the red bulb (CRT) is conducting too much. There is an adjustment control for that. The 'sceen' control is behind the speaker cover and service cover. Turn red screen control slightly to the left until you get a good black and white picture.
Good Luck, Big Irish.
Nov 22, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Red, bule, green lines do not line up together.
why is my projection tv screwed up on the left side with the color red only i tried to center it and it won't go any further.
Sep 05, 2008 | Televison & Video
Converence
green is fixed so you have to move red and blue to green.
by using the remote you may find a simple converge function and open this and using arrow keys move the blue or red first to center of screen, repeat for other color you should see the lines moving toward a a white center point.
if the lines do not move with remote try manual ...menu on the set. if still no movement you have a problem on the convergence board and need a tech to fix.
A service manual will explain complex convergence to the detail .
but this might take hours to get it right.
Aug 09, 2008 | Zenith R56W36 56" Rear Projection...
No picture
Sound like you lost Vertical Deflection.  Youshould not have a line across the screen because this could destroy the threeCRT Red, Green, and Blue (Picture tubes) if left on to long. There is a protection circuit built in to protect your CRT’s.    Check on the PCB-SIGNALboard (Tuner located on this board) transistors Q-206 Collector should be around 1 Volt Base and Emitter 0V. If the voltage atthis point is greater then 5 Volts the Vertical output IC-401 (Mounted on heat sink 7 pin inline IC) is bad, Part # LA7845.  Pin Voltages should be PIN 1= 0V, 2= 34V, 3= 32V, 4= 3V, 5= 3V, 6= 33v, 7= -6V.  Data sheet located at http://pdf1.alldatasheet.com/datasheet-pdf/view/40357/SANYO/LA7845.html
Jun 22, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Sony 65 inch screen tv
The lines you saw, i;m sure they are the ones called retrace lines but know the failure could be located on the red CRT board. Most likely the video amplifier is defective and not necessarily the CRT.
What is the model number of your TV?
Jun 17, 2008 | Televison & Video
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
101 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
