Question about Konica Minolta magicolor 2300DL Laser Printer
Media jam tray- contiueous. if i lift tray up, it wotks
Media jam tray 1
I had a similar problem but not necessarily identical cause. Mine was due to the rubber rollers which grip the sheet of paper. I clean the rubber wheels with diluted alcohol 50/50 using cotton buds. That did the tricks for awhile & eventually had to have a new set of rollers put in.
Well, try the cleaning bit & good luck.
PS I came across this site by accident, I certainly will come back. Cheers
Posted on May 22, 2009
How do I get jammed paper out of the back of it?
This is from the user guide available on the HP.com website:
This section contains the following topics:
• Clear paper jams
• Avoid paper jams
Clear paper jams
Paper jams can occur either inside the printer or in the automatic document feeder.
CAUTION: To prevent possible damage to the printhead, clear paper jams as
soon as possible.
TIP: If you notice poor print quality, clean the printhead. For more information, see
Clean the printhead.
Use these steps to clear a paper jam.
To clear a jam inside the printer
1. Remove all media from the output tray.
CAUTION: Trying to clear a paper jam from the front of the printer can
damage the print mechanism. Always access and clear paper jams through
the automatic two-sided printing accessory (duplexer).
2. Check the duplexer.
a. Push the button on either side of the duplexer, and then remove the unit.
b. Locate any jammed media inside the printer, grasp it with both hands and
then pull it towards you.
c. If the jam is not there, push the latch on top of the duplexer and lower the
cover. If media is jammed inside, carefully remove it. Close the cover.
d. Reinsert the duplexer into the printer.
3. Open the top cover and remove any debris.
4. If you have not found the jam and have Tray 2 installed, pull out the tray and
remove the jammed media, if possible. If not, do the following:
a. Ensure the printer is turned off and disconnect the power cord.
b. Lift the printer off Tray 2.
c. Remove the jammed media from the bottom of the printer or from Tray 2.
d. Reposition the printer on top of Tray 2.
5. Open the ink cartridge access door. If there is paper remaining inside the printer,
ensure the carriage has moved to the right of the printer, free any paper scraps or
wrinkled media, and pull the media towards you through the top of the printer.
WARNING! Do not reach into the printer when it is on and the carriage is
stuck. When you open the ink cartridge access door, the carriage should
return to its position on the right side of the printer. If it does not move to the
right, turn off the printer before you remove any jam.
6. After clearing the jam, close all covers, turn on the printer (if you turned it off) and
resend the print job.
That's about as much as I can find for you. If you look in you user guide which is on a CD that came with the unit, you can go to page 152 through 154 to see diagrams that go with these instructions. Good luck!
Nov 13, 2014 | HP CM749A - Officejet Pro 8600...
The paper is jammed - Tray one
tires may be bald and not pushing paper,
replace tires
make sure guides are snug against the paper. not tight.
is paper lifting? can you hear motor when tray is closed?
tray 2
most likely bad motor , you could try swapping motors w tray 1
is there power to the motor? use a multimeter to test V,
Apr 02, 2014 | Canon for IMAGERUNNER C2020 C2050 C2058...
Paper jam
when coping or printing? make sure paper is in the tray the way you set it up in the tray settings on the control panel and the driver. paper size, orientation, and media type all make a difference. clean the roller and make sure the lift plate moves freely.
Jan 12, 2013 | Konica Minolta Bizhub c203 Copier
My HP 8500 a909a states there is a carriage jam. However there is not paper jam. I've tried resetting it and turning off, pluging into wall outlet, removing and replacing the printheads. I think...
Hi, please try this:
a. Push the button on either side of the duplexer, and then remove the panel or unit.
b. Locate any jammed media inside the device, grasp it with both hands and then pull it towards you.
c. If the jam is not there, push the latch on the top of the duplexer and lower its cover. If the jam is inside, carefully remove it. Close the cover.
d. Reinsert the duplexer into the device.
4. If you have not found the jam and have Tray 2 installed, pull out the tray and remove the jammed media, if possible. If not, do the following:
a. Ensure the device is turned off and disconnect the power cord.
b. Lift the device off Tray 2.
c. Remove the jammed media from the bottom of the device or from Tray 2.
d. Reposition the device on top of Tray 2.
5. Open the print carriage access door. If there is paper remaining inside the device, ensure the carriage has moved to the right of the device, free any paper scraps or wrinkled media, and pull the media towards you through the top of the device.
6. After clearing the jam, close all covers, turn on the device (if you turned it off) and resend the print job.
Aug 23, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My hp 8500 is saying paper jam but there never was one
This is based on the HP 8500 manual. I hope this helps.
Aug 22, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
241.10 paper jam- couldn't find any paper jam. How do I clear the message?
Error Code: 241.10
Page was not properly picked from tray 1
Possible Causes
Failure to feed possible causes include:
• Edge locking
• Worn or contaminated pick tires
• Overfilling of tray past the fill line.
Solutions
1. Fan media.
2. Turn media over.
3. Reduce amount of media loaded in tray 1
4. Replace pick tires.
Oct 29, 2009 | Lexmark T640 Laser Printer
Cannot see a paper jam even when the messages say there is a Medi
The paper tray should lift to present the paper to the feed assembly. If the paper tray does not lift then that will require attention and a fairly extensive strip down to replace either the complete tray or just the lift assembly.
Apr 12, 2009 | Konica Minolta magicolor 2300DL Laser...
False media tray jam
clean take up roller, chack that the printer is trying to take the paper and lifts paper up.
Nov 09, 2008 | Minolta 2430DL Color Laser Printer
I get a Media Jam Message
Hey folks! This solution worked for my "media jam tray 1" problem! Just took out paper, pushed down @ back of tray, reloaded paper, and bingo! Now to use some air to blow out any dust.
Thank you
Mar 23, 2008 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta magicolor 2300DL Laser Printer Logo
431 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
