Question about Whirlpool Washing Machines
The basket won't spin the water out of the clothes
Basket won't spin
    Genius:
  • 1,122 Answers
I tihnk you have a bad lid switch,let me know-mike
Posted on May 24, 2009
Basket spins terribly uneven.
If you find no problems with the suspension rods and springs, you can remove that spin basket and check for an item that could be stuck between the spin basket and the plastic outer tub. Also, check the "balance ring" on the top of the basket. The should be fluid in it. You can check this my shaking the basket and you should hear water.
Nov 12, 2012 | Whirlpool LSR6232J Top Load Washer
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
Our Crosley washing machine (Model # CW5000W) will not spin all the water out of the clothes and is making a bad noise while it spins.
Three possibilities here,
One, you've overloaded the washer with clothes, throwing the washer basket on tilt because of the extra weight and force against the agitator. Remove the wet clothes from the washer and try continuing the cycle.
Two, One of the elastic/spring arms that centers the basket inside the washer housing has broken and is allowing the basket to simply flop around. Disassemble the washer and inspect the basket supports.
Three, The center post that the washer basket sits on is going bad - The most common reason is that the bearings have gone bad. Disassemble the washer and replace the bearings at the base of the basket where it connects to the motor.
May 04, 2011 | Crosley Washing Machines
Washer doesn't spin
let the machine rest for a long time (cool off) then with no water or clothes try spinning it...
no spin problem can be several headaches:
too much clothes (too heavy)
drive coupler broken
broken lid switch
basket freeze
pump locked
clothing in pump
clothing in between basket
clutch locked up
brake locked up
transmission seized!!!
it is hard to determine exactly without being there to help you...just check what you can... if you have additional questions let me know
Apr 07, 2010 | Kenmore 24032\24036 Top Load Washer
Spinning water out of clothes
not spinning all the water out of clothes
Dec 29, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Will not completely spin water out of clothes, must restart spin cycle to spin out
I do not know the model of washer you have but it sounds like your shock absorbers that dampen the baskets movements, are needing to be replaced. These limit the movement of the basket so that the motor is able to spin up to the proper speed. Otherwise the load is not balanced and the motor can not spin the basket.
Oct 23, 2009 | Washing Machines
Washer washes fine and the water drains but will only spin if you mess with the clothes making them perfectly balanced or you hand start the spin. Roper
sounds like the spin basket drive.. does it agitate ok? if yes get a new washer or change or get a repair man to change the spin basket drive.
May 02, 2009 | Roper RAB5232E
Will not spin, therefore will not drain
Hey Joe,
Let’s check to see if the wash basket will rotate CCW in Spin Only Cycle with no clothes in the wash basket
1. Open the lid and rotate the wash basket by hand Counter Clockwise, CCW. The wash basket should rotate freely with no restriction. The wash basket will not rotate Clockwise, CW by hand.
2. Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. Raise the top of the machine to observe the wash basket and tumbler action described in step 3. (See page 33 of the Service Manual for putty knife insertion point).
3. With the top raised start a Spin Only cycle with no clothes in the wash basket, observe the wash basket it should begin to rotate CCW does it?. Watch the tumblers, they should not rotate in spin cycle (maybe ½ turn at the start of spin cycle and that’s all). If the tumblers rotate while the wash basket is rotating you have a clutch malfunction. If the basket does spin CCW and the tumblers are rotating then you have a broken clutch spring. Let do those checks and observations and see what the next troubleshooting steps will be. Rich
Apr 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My direct drive washer spins slow
Always rule out first: Unsorted, too big or off balance load, too high or restricted drain, oversudsing or water not draining completely out before going into spin. Otherwise the brake could be not releasing fully or the clutch lining is worn. Pull the basket and transmission and check the basket drive.
Nov 11, 2007 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing Machines Logo
173 people viewed this question
Dan Webster
Dan Webster
Sal De
