Question about Campbell Hausfeld PW1750 Electric Pressure Washer
Do you have to use oil in the pump and if so type,how often.
Do you have to use oil in the pump on model CH pw1750 and if so what type oil, how often, and any other details associated with this model.
Water pumps doesn't require oil in the pump; but your engine does require. if the water pump is of "self priming" type, fill the pump casing with water before starting the machine to avoid damage to the water seals.
Posted on May 25, 2009
Does not have high pressure
Either the pump is bad or worn out or the pressure relief valve is stuck open and needs to be closed. No kinks in water line to unit?
Feb 24, 2016 | Campbell Hausfeld PW1750 Electric Pressure...
Littlle giant pump model 2e-ndvr what oil goes inside this pump
"pump oil" usually is a fire redardant mineral type , ive seen good uses of dietary mineral oil avail at local phamacy , but is sort of pricey if filling a total pump up with it (allways allow for heat expansion)
Apr 01, 2013 | Little Giant 5-MSP Water Wizard...
Oil pump does not work
Checlk the oil worm gear is driving the pump. If this isnt the problem then try the following:-
The type of oil pump fitted to these models is prone to getting blocked.
Remove the oil pump. The gear on top should turn freely, give the pump a clean and clean the oil pipe to the tank by removing the oil cap and blowing through with an air line. If the oil in the tank contains alot of dirt, empty/clean and replace. The filter on the oil is an open plastic cage type and often will draw large sawdust particles through it. Easily rectified tho.
Aug 24, 2012 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Do you use 4 cycle oil or 2 cycle oil for pressure washer EXH2425?
For your model pressure washer you should not be using 2 or 4 cycle oil. You need to use the following:
Model # EXH2425 P 2400PSI 2.5GPM 5.0HP HO
PUMP TYPE OIL TYPE OIL CAPACITY
**Annovi Reverberi (XMV) 30W non detergent 13.5 oz.
**Annovi Reverberi (RKV) 30W non detergent 18.54 oz.
Aug 15, 2011 | Garden
A CH pressure sprayer PW175000AV Ser# 00842 was electrically taken apart without noting how wires were to be reattached. There are 4 male spade connectors on rocker switch which works fine. Power has...
Hello Woodnflies,
I understand that you need to rewire your pressure washer. I understand that you already have the switch wired and the motor wired as they are working. You need to power the pump that has a white (common) male and a black (hot) female. You what spade connections do you have open to connect too.
You should have a black and a white that have nothing attached to them this is where the pump wires are going to attache in the circuit.
Thank you for choosing FIxYa.com
Justin
May 05, 2011 | Campbell Hausfeld PW1750 Electric Pressure...
My central heating pump does not switch off when the acl lifestyle model lp722 central heating timer switches both the hot water and c/h off. pump keeps running through the night
if you can turn off the hw and ch off , to the off postion and it shuts off then the acl lifestyle could needreplacing mine did the same on ch only so changed mine , or check the divtervalve is working and not stuck in the open postion , try turning hw on and off only then the ch see if valve works
Jan 08, 2011 | Heating & Cooling
Motor will not run i check gic plug it is not triped
I ahve had Washer for 9 years. I has worked nicely. Now, it will not pump with house valve on. It will spray under pressure when the valve is turned off. I have rewired the plug in cord.
May 21, 2010 | Campbell Hausfeld PW1750 Electric Pressure...
C/H 1750 Washer will not start with water connected. Electric motor will start without water connected.
HI I would think that your pressure switch has stuck.
You will need to remove the covers etc and check the internal pressure switch that will be situated on the outlet of the pump. It maybe stuck and just want greasing etc or may need replaceing.
Oct 30, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
Oil for submersible sump/effluent pump
I have a master plumber 1/3 HP model 539892 submersible effluent pump and was wondering if it takes oil and if it does what type of oil.
Jul 20, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Campbell Hausfeld PW1750 Electric Pressure Washer Logo
591 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
