Question about Panasonic PanaFax UF-7000 All-In-One Laser Printer
Paper tray behavior
We have UF-7000 as standalone fax that has the 2nd paper feed tray installed. Is there a way to make it automatically pull from the 2nd tray when the first is empty? Also, is there a way to default it to the 2nd tray? Any info is appreciated.
  • hhhranch793 May 26, 2009
    Unfortunately, we lost our user guide so don't know how to get to this menu option.
  • 2,005 Answers
Go into your "paper menu" and change the settings
Posted on May 22, 2009
Panasonic uf-7000 error message: change battery.
Remove the chrome scew on the side of the dark blue op panel and pull out the battery holder. The battery CR2032 is available everywhere
Jun 10, 2010 | Panasonic PanaFax UF-8000 Laser Fax
Regarding my Panafax UF-8000: Why does evrey page misfeed? I started with 24lb white paper and switched to 20lb, but still it is misfeeding.
clean the rubber feed roller/rollers that actually feed the paper from the paper tray.. clean soft lint free cloth dampened with water
Mar 31, 2010 | Panasonic PanaFax UF-8000 Laser Fax
How do I program my machine to automatically pull paper from the optional secondary paper tray?
I don't know which operating system you are running but in general you go to the printer's properties and change the device settings. On Windows XP, you would go to the Control Panel - Printers and right click on your printer and select Properties, then device settings. Good luck!
Mar 11, 2010 | Panasonic Panafax UF-880 Plain Paper Laser...
Paper jams as its feeding from the tray into the machine
Start with the paper itself. Make sure it is in the machine properly. Here is a short guide on a few things to check:
http://cincinnatiprinterrepair.com/paper-jams
Jan 27, 2010 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-880 Plain Paper Laser Fax - Info code 011
Remove the paper cassette completely, look in the cavity for a broken magnet or crumpled up paper. The machine thinks that there is no paper tray installed
May 08, 2009 | Panasonic Panafax UF-880 Plain Paper Laser...
Panasonic UF-7000 Fax - paper jams and noise
Sorry to say you probably have a broken gear on the fuser assembly.
Very expensive to fix.
Mar 09, 2009 | Panasonic PanaFax UF-7000 All-In-One Laser...
Fax uf 590
Pull open the bottom of the operating panel just above the paper tray one inch 1". Clean the small scanner glass with alcohol, it's hard to see. It's just above the first rubber roller at the black base of the machine.
Feb 19, 2009 | Panasonic UF-590 Plain Paper Laser Fax
Error 011 Panafax 585
The extension at the back of the tray has broken off, so the machine doesn't recognize that the tray has been put back in. Solve this by taking a piece of cardboard (business card works good), fold it up and insert it into the sensor at the far left where the extension would have gone when the tray is inserted. This will trick the machine into thinking that the paper tray has been inserted.
Jul 24, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Paper Feed Not Automatically Switching to Multi-Purpose Tray
Sounds like the paper out sensor for the cassette is either broken or jammed. Pull out the cassette tip the machine on its back and you should see a black arm hanging down. This should be able to swing back and fourth freely. Unless it is missing or broken.
Jun 08, 2007 | Canon LaserClass 2050 Plain Paper Fax
MESSAGE O A PANAFAX UF-790 STATES CHECK CASSETTE MESSAGE IN MEMORY
Check cassette means the paper feed tray. Pull out the paper tray, put in fresh paper. Close the paper tray and see if it starts to print. If not, let me know Ed
May 30, 2007 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic PanaFax UF-7000 All-In-One Laser Printer Logo
133 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
