Question about Nikon Coolpix 5200 Digital Camera
Lens error Telephoto lens stuck at about half retraction. Says "Lens error". Will not move.
  • Nikon Master
  • 4,738 Answers
The following blog outlines some repair options for a lens error:
Posted on Dec 23, 2007
batteries might need charging or try new batteries.
Jul 04, 2014 | Panasonic Pal Version Lumix Dmc-fz47/fz48...
Lens error
There is a possibility that a bit of grit or debris has got stuck in the retraction mechanism or the lens has been knocked out of alignment.
The camera will have switches inside to tell it when the lens is retracted or extended and if it doesn't make contact within the expected time then it will give this error.
If the there is no warrantee or you dont mind voiding it then I would suggest carefully disassembling the camera and turning the retraction motor by hand to see where the problem is.
Please comment again if you discover anything.
Good luck
Oct 19, 2007 | Nikon Coolpix 5200 Digital Camera
I have a Nikon AF-S 55-200mm 1:4-56ED. Focuses fine, lens goes in and out doesn't retract completely flush with the barrel of the lens. Is this a big problem?
I do not have that particular lens in my collection, but not all lenses do completely retract to a flush position. If your lens performs well at all focal lengths and takes sharp pictures, it is probably ok.
Aug 26, 2012 | Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S...
My Lens will only close half way.
Hi Natalie:
Lens stuck, is common defective that need new lens unit replacement or just repairable.
Causes of a Lens Error: There are a number of ways with which a lens error can be caused. Particulates might have managed to get into the mechanical bits that allow the lens to retract, a purely physical interference with the lens mechanism. If the camera was dropped, especially while the lens was extended, there's a pretty good chance something might have been knocked loose, such as the guide pins upon which the lens withdraws and retracts.
How to Repair a Lens Error: As scary as a lens error might seem, there are some easy fixes. Before trying any of them out, however, first take a good long look at your camera warranty and maybe have a chat with the company. If the lens error will be covered under the terms of the warranty, go for it. Even some of the simple fixes mentioned below might void the camera warranty. Frankly, however, it's unlikely that a lens error will qualify for the warranty.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 15, 2011 | Samsung Digimax S800 Digital Camera
Lens error. lens is currently retracted. will not open. nikon s8100 bought xmas 2010.
Had issue with lens stuck and not retracting on nikon s8100. first removed battery. then manually (gently) rotated lens counterclockwise until lens seated in fully retracted position. inserted battery, turned camera on and camera operational again. I suspect that root cause of lens jamming was turning off camera while simultaneously moving zoom lever
Mar 11, 2011 | Nikon S8100 Digital Camera
Hi i had an e18 error appear and the lens was stuck. the lens is now going in and out but the focus is compleatley shot every thing is blured any ideas?? thanks
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon. Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jun 22, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon Powershot a610 dropped, lens stuck half way, won't move, gives E18 whenever one puts it in the mode to take a picture, no view through lens. Is the camera toast?
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Nov 19, 2009 | Canon PowerShot A610 Digital Camera
Sony cybershot DSC-W170 lens malfunction
sounds like you have dust, sand of some type stuck in the retracting lense. Ive found someone to tell me to take out my batterys and SD card, then tap the bottom of the camera on a table top. Replace the batteries and power up. Doing this, I was told it loosens up the debri for the lense to retract to close and to open again.
Aug 24, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Kodak EasyShare M853 Digital Camera lens error 122,1,0,0
You will be offered a repair or a service upgrade.
To check on your options, go to
May 23, 2009 | Kodak EasyShare MD853 Digital Camera
Lens Error
Hey Joy_2008,
A lens error usually means something is obstructing the movement of the lens (i.e. sand). You could try blowing compressed air into the side of the lens to try and dislodge whatever is stuck in the lens. You could also try placing the camera on a flat surface with the lens pointed up. While holding the shutter button in turn on the camera. What this sometimes does is force the lens to move before the camera shuts down, and when the lens moves hopefully it will dislodge whatever is stuck. If none of this works I would have the camera looked at by an authorized service technician. I hope this helps!
Go Ahead. Use Us.
Jul 30, 2008 | Casio Exilim EX-Z77 Digital Camera
Nikon Coolpix 5200 Digital Camera Logo
336 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
