Need help on how to replace CRTs on RPTV
RCA HD52W67 When powering the TV, you can see the colors are out of whack and then the TV fades to black. I believe the CRTS may need to be replaced. Is there a manual or instructions on how to replace these CRTS?
  • 8,617 Answers
You can get replacement CRts which come with step by step instructions on how to do the installation
http://servicemanuals.vstore.ca/
Posted on May 23, 2009
I have an RCA HD52W59 TV that will turn on and picture is fine for awhile, then it will fade to total black. Still has sound and does not power off. Nothing will show on screen, not even menu options....
Thats a deflection problem which is causing the CRTs to shut down during deflection loss. The deflection board will need replacement. You can get replacement deflection boards from www.tvrepairworld.com
Apr 23, 2011 | RCA HD52W59 HDTV Projection Television
52" hdtv rca hd52w67
check that board where you replace the fuse on the back look very close at the transformer the big black one and check the soldering it is cracked resolder it and you should be ready to go.. just look very close they are smalllllll cracks need good light.. thats what i had on mine and works good..
Apr 08, 2010 | RCA HD52W59 HDTV Projection Television
I have an RCA HD52W67 and it just started to have
I'm having the same problem with my RCA HD52W67 rear projection TV and I've notice this problem is listed with my other owners of this product. I have no experience with fixing electronics. Sould I try this myself or take it to an expert? Has anyone fixed this problem? What is an estimated cost involved, if I take my set to an expert? Any advice with the HD52W67 is great appreciated.
Mar 19, 2010 | RCA HD52W59 HDTV Projection Television
RCA P52754AT POPPING SOUNDS. COLOR FLICKERS AND
It sounds like your high voltage block is arcing and causing the TV to go into protection shutdown temporarily. If that's the case, you'll most likely need to replace that HVB.
The other thing it could be if you're hearing "popping" (snapping ?), is that one of the CRTs could be arcing to ground, maybe the green one since you're getting too much green.
Good luck.
Nov 28, 2009 | RCA P52771AT 52" Rear Projection...
R52wh74 fades to one color then dark, then black
awewryte,
I have the same TV and now have the identical problem that you described. Did you ever get it fixed or find out what the problem was? If so, will you please pass the information on?
Thanks.
Aug 08, 2009 | RCA Televison & Video
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
Phillips
Hi. I had the same problem with my Philips RPTV and the fix is extremelly ease. You just need to open the back cover (mine uses torx screws). Inside the tv is very mechanic. You will find the three CRTs and most likely the lenses are dirty. You just need to wipe them off with a soft cloth. Also the CRTs project the image not directly to the screen, but to a big mirror and that mirror will be most likely dirty (like when you open the hot water in front of a mirror). Once you clean the mirror and the crts, your tv will like as the they you got it.
Jan 24, 2008 | Philips 55PP9502 55" Rear Projection...
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
