Question about JBL EON 15-G2 Powered DJ Speaker With EQ Speaker
I have a set of cerwin vega ls-12 3way woofer works but tweeters
Woofer works but tweeters don't , is there any way to check if the tweeters are blown ? or if the crossover part needs to be replaced?
  • 3 Answers
There is an old cheap way to test any speaker. If you have a multi-meter, set it on OHMS. Then, while holding one lead against one speaker terminal, tap the other meter lead to the other speaker terminal. If the speaker is good, you will hear faint crackles. If you do not have a meter do not despair, you can do the same test using an AA or AAA battery with leads held to the battery.
Good luck! P.S. Nice speakers.
Posted on May 22, 2009
Thanks for replying so fast "oilcitycompu", i will do that .will let you know if it worked , thanks
Posted on May 23, 2009
Replacement woofers for Cerwin Vega HED 3way 12. Can I use woofers from the LS Series?
Absolutely, as long as they are the same impedance.
If you are unsure, use an ohmmeter to check the static impedance of the replacement speakers, and be sure that it is with in 2-3 ohms of the listed impedance of the speakers you are replacing (otherwise, your crossover points will be wrong).
May 14, 2015 | Cerwin Vega Audio Players & Recorders
I have a pair of Cerwin Vega LS 15-series home speakers. One of the subs stopped working but still has sound coming out of the voice coil. Do i need to replace the sub?
You need to check the connections on the cross over board and also Ohm out the speaker to see if the voice coil is open. If you cannot get the same woofer, then you should replace them in pair, try http://www.parts-express.com//index.cfm?
Feb 25, 2011 | Cerwin Vega LS-15 Speaker
My speakers are only playing through the tweeter
If it is happening with both speakers, I would look at the amplifier, or you could have two blown woofers. If it's only one, it may be a wire inside of the box is disconnected or a bad speaker.
Feb 25, 2011 | Cerwin Vega E-712 Main / Stereo Speaker
Left Channel Woofer not working. I suspect the
I suspect a "blown" woofer! What does the dealer have to say?
Apr 20, 2010 | Cerwin Vega LS-10 Main / Stereo Speaker
I have a Cerwin Vega E-315 speaker and the Woofer has stopped working. The Tweeter and Mid-Range still work just fine. I just do not get any sound from the Woofer.
Pull speaker so you can get to the terminals in back. Take an ohm meter and check the ohms of speake, a 4ohm speaker could measure up to 5ohms and still be good. If the reading is way off then it is blown. If speaker is good, then check the cross over thats in the speaker, some models put fuses on the units for protection, but mostley on the high frequency of the cross over, not the low.
Mar 06, 2010 | Cerwin Vega E-315 Speaker
Only voice from tweeter is coming, nothing from the mid-range and woofers. on cerwin vega v10f
bhurajiv,
Well it's a good thing that you are getting sound from the tweeter from the speaker cabinet with the problem, that eliminates one of the possible problems; your wires are connected!
If your other speaker sounds fine, the first thing to try is to swap your speaker wires with the one that sounds fine. If the problem speaker cabinet still only produces sound from the tweeter, the problem is within the speaker. If the problem goes away, the problem is from your electronics.
If the problem is within your speaker and it is still under warranty, find a authorized repair location (http://www.cerwinvega.com/service_center.php).
Problems within the speaker can only be one or more of the following: 1) The drivers not producing sound have been blown; played with either too much power and/or distortion. Distortion is created when you play your music too loud with a amp not able to reproduce what you are looking for in sound, the speaker itself can hear it before you can.
2) The speaker cabinet has a crossover inside which directs the proper sounds to the proper driver. This crossover can have components that have been broken be either #1 or from exsessive vibration.
3) There are wires inside of the speaker cabinet that have been disconnected. This can happen over time or if someone reaches inside of the cabinet through the port and pulls on the wires; like a young child or pet such as cats.
If the drivers in question just one day stopped producing sound, start with the easiest solution, #3 then #1 if you can suspect anyone could have played your speakers other than you.
To diagnose the problem, you first start by removing the woofer and confirm that all of the wires are connected and in good condition. While the woofer is removed, to eliminate that there is a problem with the speakers, temporarily connect the mid-range and woofer, one at a time, directly to the wire coming from your electontics, if they produce sound the problem is within the crossover network, if they do not produce sound, the problem is with the driver itself. Replacement parts should only be purchased directly from Cerwin Vega directly (http://www.cerwinvega.com/contact_us.php)
-Chris
Jan 25, 2010 | Cerwin Vega Cerwin-Vega V-10F Floor...
JBL EON 15-G2 Powered DJ Speaker With EQ Speaker Logo
907 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
