Question about EliteGroup P4VMM2 Motherboard
Will not boot up
Power up from the front panel power supply fan come and CPU fan on but no Video no beeps
  • 155 Answers
Disconnect all the disks and CD, remove memory and everything else including all the added card (Video, network,etc..).
Power up with processor only and if you don't hear any beep you have a bad motherboard or processor.
If you have any beep power off and add the memory and try again. Keep adding one component at the time until you discover wich one is creating an issue.
PS Did you verify compatibility between motherboard and processor?
Posted on Oct 19, 2007
  • Massimo Ardito
    Massimo Ardito Oct 20, 2007
    Can you explain what you did?
Hi i have an r630 desktop and it did work but now i have no power to motherboard no fans cpu but i do have power to the hard drives and rom replaced power supply same problem
Maybe your motherboard is toast.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 30, 2012 | Computers & Internet
Continuous beep and the systems is not coming up {boot}
Hardware problem:
* dead RAM
* dead video-card
* RAM not fully "seated" in its slot(s)
* video-card not fully "seated"
* dead fan on top of the CPU/heatsink.
* failing power-supply.
Jul 12, 2011 | HP Compaq dc5100 Small Form Factor PC...
I have installed a new mother board from gygabyte: GA-MA77OT-UD3 when i turn on the PC i hear 4 long beeps and than it restarts and goes all over again. need help.
On the motherboard, connect all power connectors,video(if you have intergrated video at this time I would just use that),cpu,cpu fan,one stick of ram. Nothing else, you can connect the front panel power-on button just to make it easier to turn on. When you have all the basics connected try to turn it on and see if BIOS comes up and the beeps go away. Do not connect HD,USB,or any thing else. If you get the same thing , swap the stick of ram with another stick. IF you get BIOS , one at a time start connecting other components and starting the system back up to make sure it boots normally. If still no chage, then it lies in your power supply , cpu, motherboard(although I know you said it's new they do at times come D.O.A).
Nov 16, 2010 | Intel Motherboard
Packard Bell IMedia 5055: GA-8SIML will not post or boot. Removed all PCI cards,RAM,Hard drive, optical drives etc. Only CPU and mobo but no post/BIOS screen. CPU fan runs and front panel LEDs work. Do get...
Put just the ram back into the motherboard, the pc will not boot without processor, ram and graphics pluged into the board, check this, if it will still not boot and you still get 3 beeps its a memory(ram) problem, and you will need to replace the memory stick.
Feb 04, 2010 | Gigabyte GA-8SIML Motherboard
Optiplex gx280 won't boot and cpu fan goes faster
Sounds like a bad motherboard, I try resetting the bios , removing everything but the video , could be a bad power supply too (if you have one jump the wires in there as a test). you can buy those dell MBs cheap on fleabay.
Jul 30, 2009 | Dell Computers & Internet
. Led will light up but cpu does not power up.
Does the CPU fan rotate? And no monitor activity? Sometimes the hard disc has some kind of activity. This could be attributed to loose/failed in memory in the syste. You can try to reseat or clean the memory edge connector with clean eraser. But power down first yur unit and unplugged to wall socket no power connection shall be connected.
Sometimes it doesn't make any beep code. If beep is generated this could be video problem. But check first the Ram and video, before getting to anything.
Post an update.
Jun 03, 2009 | AMD Sempron 3100+ 1.8GHz 256k Socket 754...
Power to everything but CPU fan and case fan - won't boot
Hi this is tech crazy
The solution to the problem is as follows
The main reason for CPU fan overworking or not working is due to the load we put on the syatem while operating.So,the first reason for fan not working may be due to the SMPS malfunctionality.Better check out for it.The reason if fan is working but Overworking is due to viruses is system.So go in for format
Hope this solution helps you
Please do rate me on the above said solution
Feb 04, 2009 | Intel Motherboard
Not booting but RAM,processor,SMPS ,HD are fine.
Check without Video Card, Processor , Memory and beeps are coming
If no then this is motherboar issue, I had the similar problem. So went to the local repair shop and got the power capacitors replaced,
Jan 29, 2009 | Asrock P4i65GV Motherboard
remove ram memory - it should beep when you switch it on - if no beep then check CPU in socket and cpu fan spinning when on.
Jul 31, 2008 | HP Compaq d530 SFF PC Desktop
No Boot on 1600sc
The easy answer is: Did you ensure the CPU fan connector is attached to the PROPER motherboard CPU fan power pins? The 2nd easy answer is: Are you sure your CPU is properly placed inside the socket? Could it be tilted slightly up on one side? The more complicated 3rd answer is: I've seen people use the spray can of AIR, which, believe it or not causes a moisture problem AND can overly cool a component. Although the motherboard looks fine, it won't boot or power on until the part(s) rewarm to room temperature or the moisture dissipates. This is how I solve this problem. I remove the motherboard or open it completely up to clean it with 80psi of compressed air. (remove all components) If it had previously been cleaned with a can of AIR, I let it sit for half an hour. When putting the parts back together (leave the HD, the CD, the floppy disconnected), (oh...ensure your front panel connectors are properly on the correct motherboard pins too.) 1)take extra caution with both the video card and the memory chip slots!! Inspect the video card gold edge and video card slot for a few strands of carpet fiber or DUST bunnies wedged or attached to the card/slot (which causes the computer to not power ON) 2) Inspect the memory sticks and memory slots in the same manner. (I had to see it with a magnifying glass, to see the problem) Once back together, if it boots, I'm done. If it didn't boot, I replace the power supply. If that didn't solve it, I reposition or change the RAM memory. Attention to detail is the key to success. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | Dell PowerEdge 1600SC Server
EliteGroup P4VMM2 Motherboard Logo
74 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
